First post, by DoZator
Has anyone managed to set up the sound in Dune II like this:
The attachment Dune2.PNG is no longer available
so that the music is played on the MT-32, the sounds and effects are played on the SC-55, and the voices are played on the SBPRO? If so, could you please share and explain more about it? What do I need to do? What port should the MT-32 be on, and what port should the SC-55 be on? What should be written in the line "SET BLASTER="?
I noticed that the installer does not offer to manually assign ports for each device individually, and the game uses the same port 330 for both the MT-32 and the SC-55, as well as port 388 if ADLIB is selected. Is it necessary to modify the game's executable or configuration files, or is there a different approach to achieve this result (if it is achievable)? Thank you!
Reply 1 of 5, by BloodyCactus
there is a patch you need to use multiple sound sources. I know you can use mt32 for music and SB for effects+speach. not sure about 3 devices.
with 2, it uses a lot more base memory, with 3 I doubt you have enough base ram to run it properly. it also wont run if you have more than 16mb of ram.
Reply 2 of 5, by Linoleum
BloodyCactus wrote on 2026-07-29, 12:02:
If he was able to select a different sound device for each, this means it's already the patched version... The challenge is to actually change ports for any MIDI modules. I am pretty sure the games assumes it's 330 for both the MT-32 and SC55. So yeah, you most probably have to modify the EXE since there are no DRV file for each sound device that you could more easily modify.
The memory problem is specific to the amount of EMS, not total RAM in the system... I use "EMM386.exe RAM 8096" on a 64mb system and the game works fine.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 3 of 5, by DoZator
Yes, you're right, this is the "1.0" version of the game (US release) with the official sound patch applied. I've managed to set up ADLIB+SC55+SBPRO, and it works (because ADLIB uses port 388 and SC55 uses port 330). Now, I need to find a way to replace ADLIB with MT32 in this setup.
Reply 4 of 5, by NeoG_
DoZator wrote on 2026-07-29, 20:22:
It seems the game has only a single MIDI port definition, I doubt the game creators ever envisioned that someone would have both an MT-32 and SC-55 connected to a computer at the same time. So someone would have to go through the effort of modifying the game's executable file to render music and sound effects to independent ports.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 5 of 5, by NeoG_
NeoG_ wrote on 2026-07-30, 06:47:
It seems the game has only a single MIDI port definition, I doubt the game creators ever envisioned that someone would have both an MT-32 and SC-55 connected to a computer at the same time. So someone would have to go through the effort of modifying the game's executable file to render music and sound effects to independent ports. (E.G. MT-32 on 330 and SC-55 on 320)
