First post, by jgf
Previously I've run this sim in everything from XP to Win7 with no problems at all. Never even had to reinstall, just copy from one system to the next.
Now I'm stuck with Win11, and trying to get games working in it. There are three installs of NR2003 - one default and two of the GTP mod (one converted for open wheel cars). When I start any of them the main menu appears normally but immediately there is a popup about "This program does not appear to be completely installed. Reinstall and try again." No idea if this is a Sierra popup or a windows popup, have never seen it before. In either of the GTP mod installs I "OK" that popup, it disappears and the sims run normally, good graphics, sound, control, no problems. In the main install the game shuts down after clicking "OK" to that popup. In another forum someone mentioned if you immediately click anything on the main menu screen after okaying that popup the game will continue, well that works, but in my case navigating the menus now takes an excruciating time. Select anything, "Opponent Manager" for example, it will take a minute or so for that window to appear, select a car, another minute for its data to appear, and in the preview window, instead of the image slowly revolving, it stutters and jerks, occasionally pausing for 20-30 seconds. Click "Back" to return to the main menu, and a minute or so later that menu appears. All this time Fraps is showing 300+ fps. Once in the car on the track everything is fine.
I have compared the cfg and ini files between the three installs and see nothing to account for this idiocy.
Reply 1 of 17, by Speedwarrior956
That's weird. It should be running as smooth as butter on Windows 11 with the newly decrypted v1.2.0.1 executable.
Can you elaborate on your PC's specs for starters? Just wondering if something went amiss during the game's installation process or if some software is creating a conflict in between.
Greetings.
Reply 2 of 17, by jgf
Well, the last time I installed NR2003 it was on an XP system, ca. 2005. It has been copied from system to system ever since. The new system is Win11, i7 something or other (8 core, 3.6gig), 256gig NVMe, 16gig RAM, GTX1070 8gig; I moved my entire games drive (2tB WD Black SATA) to the new system. All my other sims (GPL, GTL, GTR2, rfactor, RBR, Rally Trophy) worked with minimal tweaks beyond calibrating and assigning controls (had to get a new wheel also, no W11 drivers for my old one).
Reply 3 of 17, by Speedwarrior956
Pretty good specs right there. Unfortunately that particular GPU -GeForce GTX1070- just went deprecated by nVidia since November 2025 with the latest Game Ready Driver being v581.80 and its latest GeForce Security Update Driver being v582.66 from June 16th. It might work fine nonetheless....
One thing you can try is to rerun the NR2003 Graphics Setup Utility to set the rendering method -Direct3D being the best one-, resolution and color depth. Can also look for the Core configuration file inside the main game folder and set the following parameters accordingly:
*[FileLRUCache]
CacheSize (It should read as "14194304")
*[Memory]
MaxBlockSize
PoolSize
(Those values must be the same exact ones. Minimum is "524288" IIRC.)
....followed by either the Rend_DXG or Rend_GL configuration files:
*AnisotropicLevel
*TextureSetSize
....finishing up with your Player profile configuration at either....
C:\Program Files\Papyrus\Nascar Racing 2003 Season\Players\Your_Name (x86 Windows)
C:\Program Files (x86)\Papyrus\Nascar Racing 2003 Season\Players\Your_Name (x64 Windows)
D:\Games\Papyrus\Nascar Racing 2003 Season\Players\Your_Name (x86/x64 Windows)
....and scroll down to the following:
[Graphic Options]
*draw_ahead_distance=100
*draw_behind_distance=100
*enable_CarMegaShader=1
*enable_ShadowVolumes=1
*texture_quality=100
Don't forget to 'load and apply the Large Address Aware Patch to the game's executable; It allows for better compatibility of 32-bit softwares and games on 64-bit versions of Windows.
https://ntcore.com/4gb-patch/
Happy Gaming from #TheEnchantingIsland
Reply 4 of 17, by jgf
System is brand new, delivered at end of May; so I assume has the latest drivers (of course we're dealing with Micro$oft - your system is antiquated if it hasn't been updated within the past 15 minutes; and I intercept a dozen requests per day of MS processes wanting permission to phone home). Vid driver is 32.0.15.6603, dated Oct 2025.
Core.ini is fine, same for all three installs; cache size is normal, blocksize and poolsize are 2097152.
Rend_dx is the same for all,
AnisotropicLevel=0
TextureSetSize=2114306048
My player ini files are in the players folder in the N2003 install folder(s), values same as yours except draw distances set to 60.
All my older games have the 4gig patch; I've even encountered a few that must have affinity set to a single core to run properly (Thief3, for example). And I've found over the years most of my games run better in D3D; GPL is variable depending on system, try everything and settle on what looks best (for example, on my Win7 system, color was best in D3D, but OSDs were in black boxes; in OGL the OSDs were just text on screen, but shadows on the track were purple).
The main issue is why all three installs throw that "incorrectly installed" popup. The two GTP installs run fine once I OK that popup. The default install will close when I OK that popup unless I immediately click any menu option on the main screen; then responds very slowly throughout the menus (even though Fraps shows over 300fps). But once in a car on a track all three run normally (depending on track and number of cars, fps is 120-320).
Reply 5 of 17, by Speedwarrior956
AFAIK, FRAPS hasn't been developed or updated since Late February 2013, which renders it's compatibility with modern versions (8.1/10/11) of Windows quite dubious. As for that "Incorrectly Installed" error, you should try the now-current v1.2.0.1 No-CD for Windows 10 & 11 on all of your installs, apply the 4 GB (aka Large Address Aware) Patch and set compatibility to Windows XP-Service Pack 2/3 with administrative privileges on all of them.
*Also, disabling some in-game settings such as "Vertical Synchronization" and "Frame Limiting" can make a world of difference in terms of overall stability.
*Assuming that you've installed said game thorough physical or emulated media, it's always a good idea to either reapply the v1.2.0.1 update and it's corresponding No-CD/No-DVD/No-DRM or reinstall it altogether -as to ensure good file integrity-; Most often, it's the former step that works the best, specially on the main insallation folder.
(Apparently there's a digital release of said game that was available "once upon a time" thorough Steam & GoG....which, for the time being, remains as an absolute oxymoron.)
Our cool friend TheBenCrazy has prepped an in-depth guide for said game. #500%Recommneded
NR2003 Setup Guide: https://www.bencrazy.com/guides/nascar-racing-2003
Hope this helps to enjoy The Best Racing Simulator Ever.....
-Green. Green. GREEN!!!!
Reply 6 of 17, by jgf
Yes, Fraps is "old", but so is N2k3; once on the track the default N2k3 fps counter and fraps agree within a couple of digits.
I've seen numerous new exe files the past few years (I assume Kaemmer dropped his ban on them), but without knowing who created them, or what is different from default, I've been leery of using them.
Always use XP compat, always run as admin (which seems useless in W11, UAC still pesters you ...I'm on the verge of disabling it). Never use VSync, better to limit fps to 60 in the vid drivers; and it's usually better to use any vid options in the driver settings than in a game.
I've not "installed" N2k3 in years; as far as I know it makes no registry entries so have just copied the entire sim(s) from system to system; in the current case I just pulled the secondary drive from the old system and hooked it up in the new. I do know my copy works in W10, copied the entire thing to a flashdrive for a friend a couple of years ago and it ran fine on his W10 system.
Am familiar with the BenCrazy site, in fact I tried that before coming here. Had to twist the arm of W11 just to get the installation to run, then got popups about something in W11 "blocking the app" when I clicked the shortcut, more tweaking. Finally got the menu screen to appear but when I selected anything it dumped me back to the desktop; don't know if the game crashed or the OS shut it down, result is the same. And this was just the base game, without all the extra stuff in my copy.
This is most perplexing, N2k3 has previously never given any trouble at all no matter what OS.
Reply 7 of 17, by Speedwarrior956
It sounds like either User Account Control or Data Execution Prevention right there. It could be permanently disabled thorough an elevated command prompt on previous versions of Windows. but not on them latest ones as those will require the final user to disable Secure Boot thorough the MoBo's BIOS beforehand.
-Yup. #MicroSlop being #MicroSlop alright....
As for those "banned" .exes, those definitely were created, at first, to break the Disc Check Systems of the time, but it gradually switched to modifying them to accomodate different sets of physics, depending on which series expansion you had installed ATM, either GTP (Sports Prtototypes), OWR (Champcar/IndyCar/Formula 1) or CTS (NASCAR Trucks), for example. There was a major court case on that subject which the developers ultimately won. Look up for Redline Developments v/s iRacing. is a pretty interesing read....
Reply 8 of 17, by jgf
I know DEP had to be disabled in Vista and Win7 to run the GTP mod, but can't see where it's blocked anything in Win11 (so far). In the two GTP installs, once I OK that incomplete install nonsense, everything is fine, I've run several cars at different tracks with no problems, even ran a few laps of a race with 24 opponents (which means "incomplete install" is ridiculous).
FWIW, I was a beta tester for Sierra through the GPL era, before Vivendi bought them. There was a sequel to N2k3 in the works, better physics, tire models, etc.; but Vivendi wanted it "dumbed down" to appeal to a wider market, Kaemmer balked (his reputation had been built on better and better sims since the early "Indianapolis 500: the Simulation", arguably the first true sim); he left, got backing, and bought the rights to the N2k3 core programming, which became the basis of iracing. Naturally anyone editing the N2k3 physics could easily create something in direct competition to his plans, so they were banned
(the NoCD exes were no problem, Kaemmer didn't care about them, the CD check was a Sierra decision, like most games on CD then). What disturbed most people was not the ban but his aggressive, mean spirited, attitude towards a large community which had supported him, even revered him, through a series of some of the best sims ever. The GTP mod was allowed to continue because it was so far along in development and because its creators contacted Kaemmer and got his input on the final design (redesign the loader and suggestions for setup options and handling tweaks). All other mods were dead in the water, and the people walked away from N2k3 entirely; legally now about all you could do was make tracks, sounds, and liveries. There were some interesting mods in the works; I worked with a group on a "vintage" NASCAR mod - the early days, late forties, ten year old "jalopies" with hot-rodded flathead V8s running mostly on dirt tracks; the strangest was a speedboat mod, "tracks" marked by buoys on lakes (have the remains of both on DVD buried somewhere ...if they are still readable). There were at least four open wheel mods; two were converted to PTA physics and released, one had the F1 style physics about halfway done but was barely driveable, the last had absolutely gorgeous graphics but still running on cup physics and no paint kit. The OWBeta is the one I converted from PTA to GTP, with two carsets - '78 F1 and '88 CART (I'm astounded it still gets one or two downloads a month).
But these issues in W11 have me perplexed, if they didn't run at all - ctd when loading or when going to track - it would make more sense. I appreciate all the input and remain open to ideas.
Andretti stalks Pironi at Clermont, not too shabby for a twenty year old sim -
The attachment gtp_f1.jpg is no longer available
Reply 9 of 17, by Speedwarrior956
WOW!!!!! A speedboat mod for NR2003?! That would've been way too crazy.
Just tested the Pro/Stock mod already. -Runs good but them car models need some serious work though. Got to work on those grip levels also....-
(Apparently there was an early Pro\Stock mod that required the original disc to run. #CheckingOnThat)
As for the original Open Wheel Racing mod, It's an absolute blast to race, complete with the 1978 F1WC Carset. -The base mod was apparently based on the old CART Series....-
#StayTuned
Reply 10 of 17, by jgf
Is this the '78F1 set you have?
The attachment 78_2.jpg is no longer available
The attachment 78_1.jpg is no longer available
Reply 11 of 17, by jgf
FWIW, this is the CART '88 set. (Seems a million years ago; first posted on the old RSC site.)
The attachment cart88_1.jpg is no longer available
The attachment cart88_2.jpg is no longer available
The attachment cart88_3.jpg is no longer available
Reply 12 of 17, by jgf
When DEP interfered in Vista or Win7 it blocked the GTP mod from running at all; would get the main menu, select a mod and track, then "drive" and be dumped back to the desktop. But it never complained about the default install (DEP considers editing the exe, as done by the GTP loader, the work of malware).
So I'm thinking the issue is with N2k3 itself, which runs fine once past that "incomplete install" nonsense (though there remains the slow menu response in the default install).
If I try to whitelist n2003.exe I get that ridiculous popup, "You cannot disable DEP for this program. This program must be run with DEP enabled." The latter phrase must be the most idiotic in windows history, since the program, at least in Vista/Win7, will not run with DEP enabled. On my current system both GTP installs work with DEP set to "windows only".
Reply 13 of 17, by Speedwarrior956
jgf wrote on 2026-07-28, 15:29:
Yup. The same one. Currently hosted @ Google Drive -From user Bryce084's Carset Guide- (https://docs.google.com/spreadsheets/d/1050T1 … dit?gid=0#gid=0)
*Every team and every driver that contested the 1978 Formula-1 World Championship is faithfully represented. An absolute blast to drive
As for said CART88 Carset, it was formerly available at the old RaceSimCentral site; Currently hosted thorough the new AllNR2003 'site.
*Have yet to test it; Based on the defunct CART Series.
About that DEP issue....
It can still be disabled thorough Windows Security on Windows 10/11. It's on the System Settings tab under Exploit Protection. No system restart required as opposed to the good old Command Prompt method.
(My OS language is set to Spanish-Mexico but this method works on them USA/GBR/AUS English distributions as well.)
There are more missing carsets out there which were intended for different mods that went missing to modding website closures.
Its relentless search continues....
Reply 14 of 17, by jgf
Both carsets are my work, first uploaded to the old RSC site (RIP); also available from a link on the old NRTracks site (also RIP); didn't know they were still floating around. Only link I currently have is to my custom GTP series folder which uses them. Both were originally done for ICR2 and only available on AOL and Compuserve, still run into them occasionally (plus a nice conversion to a new 3D model for ICR2 done by someone in Italy about twenty years ago); for the OWBeta mod they were redrawn from scratch. The CART set contains around fifty cars, used the 1988 CART yearbook as reference so any car that started any race is represented, even if it only completed a couple of laps; two driver lists included, one for the Indy500, the other generically for the rest of the season (if all the original documentation is included it sorts this out).
Disabling DEP entirely varies with version of Win11; on some systems it is tied to SecureBoot, you must first disable that then disable DEP, but ... on some systems Win11 will not start without SecureBoot. Micro$oft continually screwing with us. (Fortunately SecureBoot is not enabled on my system. I'd still rather have Win7, 🤣.)
Reply 15 of 17, by Speedwarrior956
Yeah; That's right on the money.
Windows 11 currently relies on the infamous SecureBoot for safety and security, which also requires the dreaded Trusted Platform Module v2 for "added security". Quite annoying but necessary, i guess....
#OhYeah AOL, OKA "America Online" used to be the absolute king as an ISP, providing us with all sorts of information and services such as news, sports, mail and way more, all thorough a monthly subscripton. It is currently under the aegis of Bending Spoons and it's CEO Luca Ferrari -Yup, from the world famous sportscar making family-.
As for the RSC site...they're back, but as a file hosting site specialized in racing simulators, from the mid 80's up to the most current and advanced ones.
*The ONLY way to redeem #MicroSlop aka MicroSoft from it's impending doom would be that both the corporate board and the investors finally decide to have #SatyaTheJerk -their current "CEO", that is- unceremoniously SACKED from the company "thorough the service doorway with a torpedo launcher" for putting said company in major disrepute. #JustDisgraceful.
-Let's stay Awesome!!!
Reply 16 of 17, by jgf
Well I hated America Offline and loved CompuServe, my ladyfriend of those years hated CompuServe and loved AOL, so we had both. Years before that we had Prodigy (remember them?)
RSC was founded by Tim Wheatley in the late nineties; by around 2009 he was working with some software company and considered his owning a race sim site might present a "conflict of interest" so he sold it. The new owners dropped the ball in early 2010 (not sure what happened, malware attack? massive hardware failure?), the site disappeared for a week or so, when it returned most of the d/l libraries were gone and forum access was spotty; we were told they were working hard to restore the site from old backups. A month later it disappeared again, never to return. Later that year a new RSC site appeared, all new forums, no downloads ...RSC in name only. Don't know who owned it at that point but it disappeared in a few months. For the next couple of years seeking "RSC" got you a black page with the RSC logo in the center and "coming soon" below that. Then that was gone. Somewhere during this time Tim Wheatley bought the site back and reopened it as a marketing site for sim hardware. Tim is a great guy who was instrumental in preventing the SRMZ site from being lost recently; he accessed the backup files and transferred them to his servers then worked with the admins and moderators to find a new home, so SRMZ is alive and well.
Micro$oft? The best thing that could happen to the computer world would be for them to have viable competition so they lose their monopoly. A new OS that would run existing programming on existing hardware from a company strong enough to resist MS attempts to buy them out or bury them in legal proceedings. (If I could easily get all my games working in Linux the only MS left on my computer would be FlightSim.)
Reply 17 of 17, by Speedwarrior956
Prodigy? I've looked that up....and that particular ISP never became available down here.
*Originally was a experimental joint venture known as Venture One between the Columbia Broadcasting System -Yup. The famous TV Network- and AT&T where they tried to implement their service thorough the Videotex system, which would allow the end user to acces all sorts of informantion thorough their TVs. But then it, along with other similar offerings, went torpedoed by a cold footed Federal Communications Commission. Both Wikipedia entries on such subjects are pretty good reads though.
-BTW, here's how those things actually looked back then....
https://en.wikipedia.org/wiki/Prodigy_(online_service)
https://en.wikipedia.org/wiki/Videotex
*WOW! What happened behind the scenes @ the old RSC -especially its disastrous first owner change- is nothing short of insane. Thankfully, its original owner got it back, along with the Sim Racing Mirror Zone and running as inteneded.
(The latter started hosting files for several early racing sims such as Grand Prix Legends, for example....)
*If a new OS that could rival Windows goes live, It would be an absolute blast. Better for #MicroSlop not to go the Nintendo way though. Or else....
