First post, by TELVM
- Oldbie
Revision 5.2 of this board has a jumper (JP13) to switch AGP VCC3 from the onboard linear regulator to the PSU's +3.3V rail:
That sounds like a very good idea to me.
Unfortunately my GA-5AX is Rev. 4.1, and lacks said jumper:
I've read some allusions to a mod that bypasses the linear regulator by soldering a wire directly from a 3.3V pin in the ATX20 connector, to get the same effect that jumper JP13 does on Rev. 5.2 boards. But I can't find detailed info or pics.
Could some Vogoner with knowledge on this mod please shed some light on the subject?
Let the air flow!
