Grzyb wrote on Yesterday, 02:23:
I guess it would have been nice in early 80s, when a common setup was CGA with a composite monitor - or even a TV set! - where 80-column text wasn't legible enough.
May also be useful for 40-column palmtops, like Atari Portfolio.
Can it work under DOS 1.x, perhaps?
Hi there! 😃👋
On a small green monitor ("data display"), for example, CGA over composite was crystal clear; even in 80 column mode.
I've used that setup most of time here. It's basically RGB level, just in mono.
Also, I think, many European PCs in PAL land didn't have the NTSC colour-burst circuit installed.
So their AV out for on-board CGA was monochrome all the time.
If the colour monitor was good (modern SCART TV or Commodore 1084),
then the 80 column mode worked as good as on a real monochrome monitor.
IBM PCs with IBM CGAs or higher-end CGA clone cards excluded, of course.
They were sold internationally and had NTSC outburst circuit left intact.
Edit: Never mind, missed the point. Sorry, I was a bit too chatty again! 😅
