First post, by Lylat1an
I'm trying to play a game using a SNES controller connected to my parallel port.
I've configured the keys I want to match the controller buttons, and I have enough conventional memory to load SNESKey and the game I want to play, but the game doesn't respond to the SNES controller.
Does the parallel port need to be set to a specific mode? None of the documentation I've read mentions that setting.
Reply 1 of 16, by Asaki
The way I have it set up, I have the SNESKEY.EXE in with my other DOS utils, which are loaded in "path". So I put a BAT file and the INI file in with the game I want to run...BAT file just loads SNESKEY.EXE, the INI should point to the game I want to run and the keybindings (ProgPath = ultima.exe, for example). Running the SNESKEY.BAT should automatically load up the game, never had any problems.
If you're still having issues, are you sure your adapter is working properly?
Reply 2 of 16, by Lylat1an
The version I have has a BAT file called GO that loads SNESKey, but otherwise seems identical to yours.
This is my first time using the adapter, I ordered it from Raphnet.
Reply 3 of 16, by Asaki
I didn't order mine, I built it myself. Have you tried it with any Windows drivers?
https://www.zophar.net/joy.html
I think Direct Pad Pro was the one I used.
Reply 4 of 16, by Lylat1an
My Windows 98 drive failed, waiting on a flash card to IDE converter to arrive before reinstalling.
In the meantime; I installed the DOS version of ZSNES since it supports the SNES adapter without needing a driver, but the controller still isn't getting through.
I noticed that my motherboard supports a few different modes for the parallel port, some of which have DMA access. May I ask what settings you're using?
Reply 5 of 16, by Asaki
Hmm...honestly, I wouldn't know how to figure that out. I know the laptop I usually use has allmost zero settings that can be configured in DOS. I assume you don't have another machine you can test on?
Reply 6 of 16, by Jinxter
I am using Sneskey with the gamepadLPT (serdashop), it workes fine. But i hade to set the printer port to SPP in the BIOS. When it was ECP the computer froze when using the keyboard and joystick at the same time.
I got Sneskey from this site: http://arcadecontrols.com/Mirrors/www.csc.tnt … ork/default.htm
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
X: https://x.com/Retro_Erik
Reply 7 of 16, by Jinxter
I have tested the gampadLPT on 4 portable computers.
Tecra 500CDT:
MS-DOS 6.22
Printerport set as SPP (SPP = bi directional)
Atari 2600 joystick works fine
Spinner does nok work
Genesis does not work
IBM Thinkpad E600
Windows 98 DOS (MSDOS 7.1)
Was not able to set printerport type in BIOS.
Nothing worked.
IBM Thinkpad 390
Set the Printerport as Bi-Directional i BIOS
Atari 2600 works fine
Genesis3 works fine. I tried with an original Sega megadrive controller (3 button)
Genesis6 works fine. I used a copy-genesis controller called retro-bit. All buttons worked.
The Genesis controllers ONLY worked when Jumpers was set for Atari mode! No power was needed.
Atari spinner does not work
IBM Thinkpad I Series 2611
MS DOS 6.22
Nothing worked.
Tried to set the printerport as Standard, bi directional and ECP
They all run with emm386 /NOEMS.
I tried with and without +5V
Reply 8 of 16, by matze79
Did you run sneskey DOS unter Windows 98 ?
Does Windows Version of sneskey work for you ?
Here is also a 9x Driver for LPT Joystick
The attachment PPJoySetup.zip is no longer available
Reply 9 of 16, by RegTheEvil
Hello, Lylat1an! I also made an adapter myself very recently. I made an LPT adapter for four SNES-controllers. I had issues first with europe-SNES controllers. My japan-controllers worked fine through diode-version of the LPT-adapter so I modified the adapter to have USB-power instead of diodes. After the mod, both my japan-controllers and europe-controllers worked perfectly. I consider the ZNES DOS-version to be a very good testing utility for SNES controllers since that program has native support for them through LPT port.
I don't know why my controllers behaved this way. I didn't find this info documented anywhere but this is what I experienced myself. I just read somebody mentioning that some laptop parallel ports only suply about 3 volts. I can't remember the exact voltage mentioned. Nobody mentioned about any possibility for japan and europe controllers to behave so differently.
If you try to use an europe-controller through your LPT-adapter, then maybe that's why you are experiencing the problem. I remember Raphnet using diodes in their LPT-SNES-control-adapters.
Cheers!
AT2 & other music made by me + miscellaneous stuff
Comics made by me
Reply 10 of 16, by Asaki
RegTheEvil wrote on 2021-03-06, 20:05:
Yeah, that does sound familiar. I remember reading before that European SNES controllers have slightly different circuits.
Found it: https://gamesx.com/wiki/doku.php?id=controls: … _con_region_fix
Reply 11 of 16, by SETBLASTER
i did the mod many years ago
https://www.instructables.com/SNES-to-Paralle … EcPtzHTklBl-JxY
http://arcadecontrols.com/Mirrors/www.csc.tnt … MK7rhHhER9-hLl8
sneskey.ini had some type of 4dos.com wich i took from http://www.dcee.net/Files/Utils/?fbclid=IwAR1 … zFRDfC0y6awE5xs
it was pretty straightforward and super awesome to use the snes controller, its even better than any other controller you can buy for a PC.
I configured it so each press had a keyboard letter like UP = K , down = L , etc.
then when i open each game, i went to the setup of the game, and configured what keyboard keys each action had, and the rest was using the gamepad.
It emulates pressing a keyboard key.
Reply 12 of 16, by ldare1000
Hi, I know it's an old thread but wondering if anyone is still familiar with SNESkey? Cant quite get it working.
Error doesn't specify which ini file, I believe there are 3!!
Reply 13 of 16, by Harry Potter
A long time ago, I had a few PC joysticks. I was trying to learn how to read the joystick from a DOS game and found that PC joysticks are noisy and required me to literally lock the computer up while polling the joystick. I currently have a Win98SE tower at my mother's house, but unfortunately, she's homeless now, and the computer's in storage. 🙁 I'm wondering if I can get a SNES controller for it and other PCs and, in fact, if it's even worth it and the price. For the other computers, I need a USB connection. BTW, I live in New York, U.S.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 14 of 16, by ldare1000
Hi, Good to hear from you. I am in the UK. I played DOS games in the 1990s and ideally I want to re-live my times. I have a Compaq Elite laptop which is perfect for me needs in terms of 486 processor and 20mb ram.
I feel like I have understood the set up of the 3 ini files and set up the wiring correctly, but it's not working.
I think part of the issue is that the docs are trying to support a wide range of retro controllers. It's great the utility can support various pads, but it would have been useful to have separate manuals for each pad rather than one manual jumping about.
There are 3 ini files. The error I get with the testing mode: sneskey /X doesn't specify which is an issue and all 3 seem to be correct to me so I think I'm probably just a small syntax error away from success.
Thanks
Louis
Reply 15 of 16, by ldare1000
SETBLASTER wrote on 2021-03-15, 02:16:
i did the mod many years ago […]
Do you still have the 3 ini files? If so would you mind copying and pasting or uploading each please?
Reply 16 of 16, by debyl
Hi, I designed a PCB that allows you to connect 5 SNES controllers to the parallel port (and one for NES controllers also). This design draws zero current from the parallel port (I burned out a parallel port trying to source too much power from it). I can share the PCB design and parts list if you are interested. It works with SNESKey, ZSNES and DirectPad Pro also. You can check it out here:
https://www.youtube.com/watch?v=vAtDsqLM-78
