Hawk370 slot1 adapter
Reply 40 of 89, by shevalier
megatog615 wrote on 2026-08-18, 22:44:
rasz_pl wrote on 2026-08-14, 22:52:
Shponglefan wrote on 2026-08-14, 15:50:
Current price of 370 Pin socket is about $10 USD from what I've seen not including shipping, tax, etc.
afaik PCBWay charges $0.05 per tht wave soldered pin = ~$20 just for soldering the socket
this is a sponsored product so likely there is a discount here
Discussing someone else's product pricing is certainly interesting, but ultimately pointless.
It costs whatever it costs.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 41 of 89, by shevalier
BitsUndBolts wrote on 2026-08-17, 18:13:
Hey everyone!.
Q: .
How did you work around the 25mV/VID4 signal issue?
On Mendocino, it's needed for 2+ volt supply, while on Tualatins, it's present on certain models.
I have a 1.475V Pentium III, which means the signal on this pin is active.
Given that in some (or most?) PWM controllers VID signals aren't latched but change dynamically, a CPU like this will request 2.3V at boot.
Reply 42 of 89, by BitsUndBolts
shevalier wrote on 2026-08-19, 05:18:
How did you work around the 25mV/VID4 signal issue? On Mendocino, it's needed for 2+ volt supply, while on Tualatins, it's prese […]
By default, VID4 is grounded. This way, anything above 2.05v is disabled. There is a 0 ohm resistor on the PCB that can be removed if one really wants to mess with overclocking and higher voltages, but you have to remove that resistor.
Manual Voltage Selection:
There are four jumpers for voltage selection on the HAWK 370. For Mendocino and Coppermine, you could set those jumpers to AUTO and use the CPU defaults (they don't use VID4).
Tualatin MUST be set manually using the four voltage jumpers as those chips use the new VRM8.5 instead of VRM8.4 used on most Slot 1 boards. The table for manual voltage selection is printed at the back of the PCB.
VID4 was introduced with 2.0v chips (Deschutes / Mendocino). Grounding VID4 encoded voltages below 2.1v.
Reply 43 of 89, by myne
BTW BUB, you know that in theory it's not impossible to create a dual socket slotket?
After 50 days of headaches getting the distances right...
Just wire one socket0 BREQ1<> socket1 BREQ0
The schematics and datasheets seem to indicate that BRQ1 is managed by CPU0
Just planting seeds....
MWUHAHHAHAHAHAHAHAHAAH!
I built:
Reply 44 of 89, by maxtherabbit
That would be wild to make any old board into SMP
Reply 45 of 89, by myne
Power would be a headache. You'd need to build a VRM onto it.
Might be easier to just build a board. See sig. I have more converted designs.
I built:
Reply 46 of 89, by Big Pink
myne wrote on 2026-08-20, 03:15:
Is this even rarer than Tualatin slockets?
I thought IBM was born with the world
Reply 47 of 89, by marxveix
Any help on getting 440ex/lx to support up to Celeron 766MHz 66fsb cpu on one of these adapters or is it only for440bx?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 48 of 89, by douglar
marxveix wrote on 2026-08-20, 19:35:
The PowerLeap PL-iP3 was able to work on those systems, no? If that worked on those systems, I suspect that this slotkey should handle them too. I suspect that it works fine on the 440zx & gx too.
Edit as pointed out later on in this thread, the 440lx and 440ex cannot do SSE instructions , and so have issues if a Coppermine processor tries to run those instructions. More info here: 440LX and Coppermine
Reply 49 of 89, by zuldan
QDI Twin Magic. This one looks like it was actually in use.
The attachment IMG_0422.webp is no longer available
The attachment IMG_0423.webp is no longer available
More pics from QDI TwinMagic
The attachment IMG_0424.jpeg is no longer available
The attachment IMG_0425.jpeg is no longer available
Reply 50 of 89, by marxveix
douglar wrote on 2026-08-20, 20:01:
The PowerLeap PL-iP3 was able to work on those systems, no? If that worked on those systems, I suspect that this slotkey should handle them too. I suspect that it works fine on the 440zx & gz too.
I have two generic slot->370 adapters, one of them works and it boots up with Celeron 766 and bios detects it correctly, but voltage or something else dont like it and it hangs booting to win98.
Reply 51 of 89, by rasz_pl
Seen on vogons people having problems with AGP not working on 440LX and coppermine. No idea how would that even be a problem, but it was.
Reply 52 of 89, by myne
Big Pink wrote on 2026-08-20, 19:03:
Wow.
I would say so.
I didn't realise they existed.
Or if I did, I forgot long enough ago that I think I didnt.
I built:
Reply 54 of 89, by douglar
rasz_pl wrote on 2026-08-21, 01:17:
And the south bridge PIIX4 on those early boards was an early revision that could be quirky to down right buggy depending on what cards you used.
Reply 55 of 89, by shevalier
Nobody is stopping you from getting them running on any slotket. But on the very first SSE instruction, you'll get a BSOD.
For Coppermine, you need at least a ZX.
This is specifically a chipset issue, and it cannot be fixed with any adapters or BIOS patches.
Reply 56 of 89, by Big Pink
PC Hoarder Patrol wrote on 2026-08-21, 01:33:
I figured there was a catch with these, because if dual Socket 370 was so easy it could be engineered into a slocket then the Abit BP6 motherboard wouldn't have been so notable.
Reply 57 of 89, by aVd
Probably something like this could (partially) justify the price of about 100 € for a ready-to-use product. And then again remains the question about motherboard's compatibility.
what comes around goes around
Reply 58 of 89, by Postman5
DangerMouse wrote on 2026-08-14, 06:28:
It's too expensive and a pain to assemble. It's easier to just mod a regular slotket. And there's no need to drill anything - that's a barbaric solution. Instead of drilling, you just stick a thin enamel-coated wire into the hole - for example, from earbuds.
The issue with AG1 raised in the video is way overblown - it'll work just fine even at 1.6V. Besides, some slotkets already have a linear voltage regulator on that line anyway.
easy path:)
Reply 59 of 89, by bofh.fromhell
I don't get the criticism of projects like this.
Original hardware is getting rarer and rarer and more and more gets hoarded away.
Having a brand new available alternative that's also potentially better then the originals is just awesome!
Now if we could just get this gang to do a Socket 8 to Slot 1 version with various biospatches I'd be in heaven.
I know there already are new made versions, but the gatekeeping on those is just........
