First post, by The_Retro_Jimmy_Club
Greeting!
I have found a good buy on ebay for a job lot of 3.5 floppy disks. They are all copies and he says they are for Amiga. As I don't have an Amiga, can I format them from there current format state to FAT using either windows of DOS? I mean will they ever work in IMB mode?
Thanks
Reply 1 of 6, by keropi
yes, you will be able to format the floppies just fine for PC usage
if they are standard amiga floppies then they will be 720kb DD disks on pc
Reply 2 of 6, by The_Retro_Jimmy_Club
keropi wrote on Today, 18:17:
OK thanks for that!
720kb is only half of the 1.4MB standard
DD is one sided right?
HD is bough sided?
If only half the capacity then probably not worth bothering with for my usage. but hear is a link to them anyway https://www.ebay.co.uk/itm/267763391716
PS, i remember a while ago someone hear telling me that the smaller type disks only had one whole at the top (cant remember if this is true or not though) they look like they only have the one
Reply 3 of 6, by Errius
Yes I have a big stack of blue DD ex-Amiga disks that I use with my XT that only has a DD controller.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 4 of 6, by keropi
The_Retro_Jimmy_Club wrote on Today, 18:53:
OK thanks for that! […]
OK thanks for that!
HD is bough sided?
there are very few 1.44mb floppies on that listing from what I can see...
as is expected for an amiga the disks are DS/DD 720kb ones ... you can easily spot them because they only have 1 square hole (HD 1.44mb floppies have 2 holes)
Reply 5 of 6, by Grzyb
HD is bough sided?
Both are double-sided.
3.5" Double Density = 9 sectors/track
3.5" High Density = 18 sectors/track
DD disks are precious for those with DD-only machines, eg. PC XT or Amiga.
PC AT (286 and above) support both DD and HD, so it's better to use HD.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 6 of 6, by DaveDDS
HD is bough sided?
DD is Double Density
HD is High Density
Original floppy formats were Single Density = one clock bit per one data bit (almost nobody uses SD these days and many PCs FDCs can't do SD)
Double Density encoded differently requiring 1/2 the bits.
High Density is different still and is at a higher transition rate (500kbbs .vs. 300kbps on 3.5")
5.25" was not quite the same - a 5.25" drive rotates faster at HD (making the bits spread out more) which is why HD 5.25" is only 1.2m .vs. 1.44m for 3.5
Almost nobody uses single-sided drives any more
PC DS/DD 5.25" drive is 360k = 40tracks x 2heads x 9sectors x 512 bytes= 368,640 bytes
My Altair had Shugart SA400s (one of the first 5.25" drives) SS/SD 90k = 35tracks x 1 head x 10 sectors x 256 byes = 89,600
Quite a differnce in capacity - For information on common floppy drive characteristics - I refer you to the ImageDisk documents/help screens.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
