From what I'm seeing, Voodoo 2 SLI only holds up against a Voodoo 3 2000, anything higher than that, and it starts falling behin […]
From what I'm seeing, Voodoo 2 SLI only holds up against a Voodoo 3 2000, anything higher than that, and it starts falling behind. I can't imagine what a 3500 would do to it, but it couldn't be pretty for the Voodoo 2's.
I think the moment 3DFX no longer had the market lead on 3D acceleration, they were doomed. A big reason why they used to kick ass so much in the Voodoo and early Voodoo 2 eras is because there was nobody else that could hold a candle to their performance, image quality, etc. (Voodoo v. Riva 128, for example).
When nVidia got wise and started with the TNT line, and ATi started gaining traction with the Rage 128, 3DFX was essentially having to deal with 3D accelerators that were gaining on their performance rapidly, then started showing superior image quality, etc. This isn't considering S3, which eventually got slightly wise, or Matrox, or the tonnes of video cards released, all of them kicking Voodoo and eventually Voodoo 2 ass, all while using non-propietary API's (or at least being compatible with non-proprietary API's).
However, Glide still manages to squeeze out more performance with less VRAM than a TNT2 32MB, albeit with higher core and memory speeds. I'm not sure what would happen if a Voodoo 3 3500 went up against a TNT2 Ultra.
Like I've said before, however, even the mid-range TNT2 32MB I have can move, and it's the most powerful "'90s" video card I've ever owned. Of course it has a '90s architecture, but was made in 2000, like every single TNT2 I own, except the M64 which was made in 2001- bleh.
