MartyPC
Reply 620 of 627, by GloriousCow
superfury wrote on 2026-08-20, 20:31:
Cycle-accurate Adlib too (at real 49kHz, like with my emulator)? Last I checked nuked wasn't?
I don't know and frankly I don't really care. It works and sounds okay.
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
Reply 621 of 627, by GloriousCow
Working on cassette interface emulation. I'm not sure that anyone was exactly clamoring for this, but it checks the last box for complete IBM 5150 emulation.
It's got a fun pixel-art tape visualization with accurate tape spindle simulation.
The attachment martypc_cassette_01.png is no longer available
Reply 622 of 627, by superfury
GloriousCow wrote on 2026-08-27, 20:09:
Isn't tape just controlled just like a floppy, using the FDC?
Edit: https://theretroweb.com/expansioncards/s/ibm- … oppy-controller
UniPCemu Git repository
Reply 623 of 627, by BinaryDemon
Thats interesting, one of the distinctions I always draw in my mind between x86 machines and other early computers is the transition from cassette storage to floppy drive storage but I guess there were exceptions.
Reply 624 of 627, by GloriousCow
superfury wrote on Yesterday, 06:16:
Different tape systems.
The original IBM 5150 had an cassette interface port right next to the keyboard port with an identical DIN connector. The PCjr had its weird berg strip and they sold you a cassette adapter cable.
The cassettes used were ordinary audio cassettes. The cassette interface worked with decks that had motor control inputs, and were compatible with the decks for other 8-bit home systems. I use a tape deck originally for the TRS-80.
BinaryDemon wrote on Yesterday, 10:37:
You're not entirely wrong. The IBM PC tape interface was dead on arrival - the only two software titles known to exist for it are two versions of IBM Diagnostics. There is some indication IBM Typing Tutor was released on cassette but nobody has seen an actual cassette of it. There was no real use for the tape drive other than saving your ROM BASIC programs.
Reply 625 of 627, by keenmaster486
I have a Sony TC-100 (https://www.thevintageknob.org/sony-TC-100.html) and have successfully used it to store and retrieve BASIC programs with my IBM 5150.
World's foremost 486 enjoyer.
Reply 626 of 627, by DaveDDS
Always interesting doing a cassette tape emulation.
If you really want to get down in the mud, you could encode and decode audio streams via a sound interface - a whole lot of work for something few people will care that much about.
If you're "lucky" the tape interface will present as some sort of digital data at the software end.
The only tape interface I actually implemented was for my H8 emulator of the Heathkit H8 system.
Fortunately the H8-5 card (Serial/Cassette tape interface) just had tone generators and decoders on it so that the software just sees a serial data stream.
Implementing this in the emulator was pretty easy - just redirect reads/writes to the serial tape interface to a file.
I provided many of the common "tapes" that had been available from Heath as .H8T files, which you could mount and read the same way you would have read a physical tape on the H8.
Writing to tape was also supported to make/write a .H8T file.
This works well for "recreating the experience" but I never implemented actual encoding/decoding to/from audio to make it work with actual physical tapes.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 627 of 627, by GloriousCow
DaveDDS wrote on Yesterday, 19:00:
Should be fairly straightforward to pull audio from a recording input, although i might have to have some kind of control to adjust the volume. But as you said, there's already not a ton of interest in this as a feature and if you have a cassette deck hooked to a computer you can already just record a WAV with something. Hooking up the UI bits for selecting audio inputs and polishing that is already more than i care to do
