VST Midi Driver Midi Mapper
Reply 280 of 283, by DragonSlayer
Wow, that's really cool. I didn't know it was possible to use a CLAP to VST2 wrapper in that way. I've just been testing out Nuked SC-55 in the new DOSBox Staging release and it is really impressive. I'm amazed at the quality of the emulation. Thanks for the tip.
"There are only 10 types of people in the world; those who understand binary, and those who don't."
Reply 282 of 283, by Falcosoft
VST Midi Driver 2.6.1 has been released:
https://github.com/Falcosoft/vstdriver/releases/tag/v2.6.1
1. Added workarounds in order Nuked SC55 CLAP plugin + CLAP to VST2 wrapper to work properly.
2. Fixed vstmidiproxy client list when MS Midi 2.0 stack is active.
3. Added option to hide the driver's tray icon.
4. Fixed port names of client list in vstmidiproxy.
Website, Youtube
Reply 283 of 283, by DragonSlayer
Thank you for the update. It's strange, but I get different results from Nuked SC55 CLAP depending on whether I play it in Foobar2000 or whether I play the same MIDI in your MIDI player. It sounds more correct in your player, but I find it strange that I would get different results from one player to the other. I guess I will have to play around with the settings and investigate further to try to figure out what's going on. Thanks again for the update to your VST Midi Driver.
