What modern activity did you get up to today?
Reply 1740 of 1744, by RandomStranger
Sometimes when I leave home I don't remember if I left the windows open so I added some contact sensors to my HomeAssistant setup. This way I'll know not to start my AC if I left the windows open. I also added an automatism to turn off the AC if I open the window.
Reply 1741 of 1744, by wierd_w
Just another day as break/fix IT.
Reloaded some workstations. Woopee for me.
Reply 1742 of 1744, by bakemono
yesterday while I was in the middle of surfing VOGONS, my harddisk self destructed. Today I'm restoring from backups 🙁
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 1743 of 1744, by Nexxen
bakemono wrote on 2026-09-05, 22:51:
Your drive was in the middle of some interstellar highway. 🙁
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 1744 of 1744, by lti
On the computer side, I was thinking about some mods to improve airflow in the Corsair 200R case that I put my Ryzen system in. It doesn't overheat (and actually runs cooler with a 120mm single-tower cooler than a lot of people on Reddit with 360mm AIOs), but the restrictive front panel, the location of the side vent, and the tiny gap between the power supply filter and desk seem non-ideal. I knew about the power supply air intake, but I never got around to putting taller feet on it.
I also remembered why I don't like writing software, but it's more microcontroller C code. I got the nRF24L01 working after about 11-12 years, and all it took was lowering the transmit power, switching the bulk cap I soldered onto the module to a low-ESR one, and sending some debug data over the previously unused UART. Also, the BME680 sensor suddenly started measuring temperature more accurately in the process (using it as a source of data to transmit to the receiving system).
