Reply 59640 of 59928, by Dothan Burger
Trashbytes wrote on 2026-09-08, 00:33:
Well it did come back as the Core Uarch which was a mash of Pentium M, Netburst and a bit of new tech. Netburst was not all bad it did have some good features buried in the core and they moved these to the Pentium M core and threw is a few new ones and well the rest is history.
This then carried Intel a long damn way . .all the way through Skylake.
Pentium M was just the shot across the bow, it was Core 2 Duo that sunk my battleship. E6600 was my first intel processor.
Reply 59641 of 59928, by Trashbytes
Dothan Burger wrote on 2026-09-08, 01:05:
Core 2 was amazingly good, my favourite bit of kit to tinker with.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 59642 of 59928, by Repo Man11
Pentium M CPU's are great overclockers. A nice thing about the rarity of desktop boards for these is that the CPUs are still (or at least were, I haven't checked lately) pretty cheap. I was able to buy the 780 I have for a little over $20.00 IIRC.
Reply 59643 of 59928, by Dothan Burger
Repo Man11 wrote on 2026-09-08, 02:46:
Weirdly the 400 FSB high multiplier parts are expensive now.
I was going through my collection of boards that need a recap and found a P4C-800E rev 2.0 non Deluxe. Was excited for about 5 minutes until I realized I couldn't get the CT-479.
Reply 59644 of 59928, by H3nrik V!
Oh, maybe I should look into getting some more fun than the 735A for my CT-479/P4C800 then ... (not even sure it the 735A will run in that)
Reply 59645 of 59928, by oldGPU
Dothan Burger wrote on 2026-09-08, 00:28:
My first crack at a Pentium M retro build was this i915 ITX industrial board. […]
Nexxen wrote on 2026-09-07, 23:00:
I've been looking for a 479 board myself but prices have always been ridiculous.
When I saw benchmarks I was impressed. Strange times we lived 😀
The attachment IMG_1665.JPG is no longer available
Planned on using an adapter from mini PCI to full-size PCI for a sound card so I could fit it all in a Fractal Ridge. It all fell through after dropping hundreds $$$ on the Amfeltec solution that wasn't compatible with this board.
I really wanted either the Aopen 855 or the Kontron 886/ITX board, But that's life.
Love an ITX build!!
Reply 59646 of 59928, by Lomax
Double post due to server error.
Reply 59647 of 59928, by Lomax
Reply 59648 of 59928, by Lomax
Dothan Burger wrote on 2026-09-07, 18:03:
Picked up this Kontron 886LCD mATX board for pentium M. I love Industrial boards for some reason.
Love the Pentium M, and industrial boards, and Kontron 😀 I've got a very cool little "EBX" form factor PIII board , and a Kontron KTQ45 Flex-ATX with a Core 2 Quad CPU.
My most recent retro hardware acquisition is a Cherry G84-4100 PS/2 mini keyboard, which made me go squeee when I first saw it IRL; so tiny and cute, yet perfectly formed! I also picked up two Microsoft mice, one optical, one ball, which were incredibly filthy and disgusting, but also free. They cleaned up beautifully after disassembly and a bath:
The attachment Vintage Microsoft Mice 1.jpg is no longer available
The attachment Vintage Microsoft Mice 2.jpg is no longer available
Reply 59649 of 59928, by oldGPU
Lomax wrote on 2026-09-08, 11:33:
Wow those cleaned up REALLY well!!
Reply 59650 of 59928, by schmatzler
I got a CRT monitor from the 80's for my old consoles. It works, but the green color is a bit too bright and there are loose connections on basically every switch and jack. So I still have some work to do fixing it.
The attachment IMG_20260908_125751691.webp is no longer available
Reply 59651 of 59928, by Lomax
oldGPU wrote on 2026-09-08, 13:08:
Yeah, surprised me as well. Wish I'd taken a photo of what they looked like before, because they were really quite gross and sticky. I disassembled them and let everything apart from the PCBs soak in warm water and washing up liquid, then cleaned each piece with a soft sponge and rinsed. The ball and the scroll wheels then got a quick bath in 99% IPA, as did the PCBs, and after drying I applied the absolutely tiniest amount of silicone oil on a cloth and gave everything (apart from the PCBs, obviously) a quick wipe with it. This should help protect the rubber parts from drying out and cracking, and gives the hard plastic a perfect shine. It also helped soften up the cables, which had become a bit stiff. The white plastic is a tiny bit yellowed, but that only adds to the retro vibes if you ask me 😀
Edit: I do need to source a couple of "skids" for the IntelliEye mouse, since the original ones were missing, so if anyone has any ideas for that...
Reply 59652 of 59928, by Lomax
schmatzler wrote on 2026-09-08, 13:35:
That's a nice JVC monitor, though it could do with a clean... The clear acrylic front can be polished with Novus to get rid of the scratches, or I guess you could just remove it altogether?
Reply 59653 of 59928, by a_h_adl
Trashbytes wrote on 2026-09-01, 13:46:
Finally got my hands on a Asrock 775i65G Rev 3 board ! […]
Already got a CedarMill 661 P4 3.6Ghz CPU for it or a QX6800 I can drop in there too if I want more grunt. Not sure if Ill throw a 6800 Ultra in it or the 7900GS, I guess it depends on how the P4 does with each one, I suspect itll handle the 6800 Ultra better.
I do have a Ti4600 and a FX5700 Ultra I could drop back to for better compatibility but I doubt Ill need it, not going to be playing older titles on it !
The attachment Boxed.jpg is no longer available
The attachment 775i65G.jpg is no longer available
The attachment Asrock.jpg is no longer available
The fact it is from Phil makes it more precious! 😀
Reply 59654 of 59928, by oldGPU
Great pickup. Looks perfect with the fat PS2.
Reply 59656 of 59928, by Shader_BiH
Wow... I've never seen one of these. It really has the Vibe. I hope you manage to buff it to shine 😀 I would really enjoy hooking up an old console... like Megadrive 2 on this one.
Meanwhile... I managed to get two more video cards...
Reply 59657 of 59928, by Shader_BiH
The second one...
Reply 59658 of 59928, by SlowA
Ati X1800/1900 was its golden era.
Reply 59659 of 59928, by Shader_BiH
SlowA wrote on 2026-09-09, 13:21:
Yeah... I remember my Radeon X1600Pro allowed me to use HDR and AA at the same time. I did have to use lower res. but it was still a treat. Nowadays my collection is actually mostly centered around 9000 series, X800 and X1800/X1900, and this 1900XT I bought just because of Ruby 😀
