First post, by stanwebber
i'm trying to get glidos working in win98se with the following games: blood, tomb raider and redguard. i can get all 3 games working with dgvoodoo, but glidos completely eludes me. i've read all the glidos guides i could find online, but i must be missing something so elementary simple that no one ever thinks it's necessary to mention.
i installed the win9x/xp version of glidos 1.61 and configured each game to run in windows mode. to start: the dynamic game.bat file that glidos generates attempts to modify the path to use its default install location (c:\program files\glidos) without using quotes or the 8.3 filename which continually breaks the game launch process. once the path is corrected manually--glidos ultimately fails to launch all 3 games showing an error along the lines of...fatal error: unable to load dll (which normally indicates the absence of glide2x.ovl)
what the hell? what step did i miss? am i supposed to copy any files to the game directory? any glide2x.ovl file i copy there is automatically deleted by glidos on game launch so how the hell am i supposed to if required? i don't want to use dosbox mode for performance reasons, but that doesn't work either anyway (with the same error). i just feel stupid at this point.
Reply 1 of 10, by Glidos
It's not your fault. What you have done should work. Having said that, I'm not surprised Glidos has problems on win98se. I haven't had a win98se installation to test on for years, so years of changes haven't been tested there. On the other hand, people quite recently have reported having it work (which surprised me).
The Glidos.bat problem is very odd. That's something I wont have changed and so will have worked at some point in its current form. Can you maybe send a screen shot of the error.
Also, how close to this is your installation directory:
The attachment Screenshot 2026-09-08 092840.png is no longer available
Reply 2 of 10, by stanwebber
i got it sorted. installing to the dafault program files location (or any location with spaces) breaks glidos under win9x. the dynamic .bat files that glidos generates don't use quotes for any the paths. i moved the glidos folder directly under c:\ to resolve.
that being said, i still can't get glidos working on my system for any of the 3 games in either opengl or d3d mode due to some incompatibility (presumably with my radeon 9800). the games do sort of start, but quickly crash (often the entire system) when any 3d rendering is attempted. there might be some magic combination of settings to make it work, but i haven't found it yet.
Reply 3 of 10, by stanwebber
is glidos more than a frontend for openglide and psvoodoo? could i attempt to get (older) versions of those working independantly and integrate them back into glidos or is that too simplistic? (i suppose i will try older releases of glidos as well.)
there's no uninstaller for glidos. it appears everything is done in ini & bat files so is the installer only copying files to the install directory and creating shortcuts on the start menu & desktop? no registry or windows folder modifications?
Reply 4 of 10, by Glidos
stanwebber wrote on 2026-09-09, 08:07:
It's a little more than a frontend. OpenGlide and psVoodoo are for WIndows-based Glide games. DOS games cannot use them. Glidos uses a replacement Glide2x.ovl to receive the DOS game's graphics commands, serialises them, sends them down a data pipe and calls into OpenGlide or psVoodoo. It also does the texture, FMV overriding if you want TRX textures and the higher quality cut scenes.
I installed W98SE on 86Box, and sort of got it working with TR I, but it was a fiddle:
The attachment Screenshot 2026-09-09 114837.png is no longer available
, As you mention there's a problem with install locations with spaces in. Must have worked at some stage because the first version of Glidos was 98/95 only. Looks easy to fix. I'll have a go sometime soonish.
Reply 5 of 10, by The Solutor
In my experience Glidos 1.59+ doesn't work reliably in Win 98SE (and earlier) while seem to work correctly in WinME (both in OpenGL ad D£D), no matter if you're using VMware or Virtualbox.
If one wants rock solid experience the solution is to use a version that doesn't came with DOSBOX like 1.35, 1.41 .... (easy to spot given the installer size difference)
Strangely enough I never had troubles with spaces, but I noticed that the installer doesn't obey to the localization setting.
The installer (by default) installs in \program files\Glidos instead (say) \programmi\Glidos for the Italian version.
Obviously you can change that manually, but it's easy to get distracted ad not notice the problem, a problem that's bigger than appears given the 8.3 name which become progra~2, and may lead to unexpected consequences in programs other than Glidos.
Reply 6 of 10, by The Solutor
In my experience Glidos 1.59+ doesn't work reliably in Win 98SE (and earlier) while it seems to work correctly in WinME (both in OpenGL ad D3D), no matter if you're using VMware or Virtualbox.
@stanwebber
Anyway did you select windows rather than dosbox in the settings (dosbox is meant for the NT branch of the windows family)
Reply 7 of 10, by Glidos
I was fooling myself before. It looked like I had it working because the emulator had a voodoo graphics card. It's actually all sorts of broken. v1.32 seems to work though, so I'm hopeful to be able to work out how I broke it.
Reply 8 of 10, by stanwebber
i installed glidos v1.41 and achieved partial success in win98se. the games are completely playable under both opengl & dirrct3d except for 1 issue: the command prompt window (or fullscreen) is not capturing any mouse events so i'm stuck with keyboard control only. is there an easy fix for this or do i have to go looking for more compatible glidos versions?
Reply 9 of 10, by The Solutor
Glidos wrote on 2026-09-09, 22:39:
Just use VMware or Virtualbox + SoftGPU, both work perfectly
VMware doesn't play the initial blink video (black or striped screen) but is more convenient because the vmware tools can be installed (custom install, exclude the vga driver).
You can even have the FSAA enabled , if the application ask for it.
On my, not so powerful, Ryzen 2400G with it's integrated VGA I get 16~20 FPS in D3D @1400x1050 or 30 FPS (the upper limit) @1280x1024, using custom textures.
P.S. speaking of FSAA would be a nice improvement to have a flag to enable it.
P.S2. I'm not sure about the status of 1.31 or so, but maybe it didn't yet understand the new style custom textures, better to use something newer like 1.4x.
Reply 10 of 10, by The Solutor
stanwebber wrote on Yesterday, 23:20:
What mouse are you talking about? It's Tomb Raider not quake, there isn't mouse support.
