Reply 1940 of 1948, by NeoG_
Geriatric Danmaku wrote on 2026-09-05, 21:34:
Not yet getting Gameport support in Windows 95. It could be a Windows 95 corruption issue. After following alot of general advice, and not making enough progress...
The auto detection will probably not work, try manually adding a standard gameport using the add hardware wizard (usually filed under Microsoft in the driver list)
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 1941 of 1948, by Geriatric Danmaku
MONEY! We got this! It was all about setting the Windows gameport to port 201h. No Windows reinstall needed.
Now looking at the Windows games which work with current Sound Blaster emulation. Not all of them are working. But some of them are. More to come.
NeoG_ wrote on 2026-09-05, 22:40:
Reply 1942 of 1948, by NeoG_
Geriatric Danmaku wrote on 2026-09-05, 14:54:
What are some good games to try out CMS Sound?
Silpheed, Space Quest 3, King's Quest 4
Reply 1943 of 1948, by appiah4
There is a very good retroclone of pacman that has CMS sound..
Reply 1945 of 1948, by NeoG_
Geriatric Danmaku wrote on 2026-09-07, 05:58:
Since you inherited an existing SB16 configuration onto the PicoGUS, there is one specific thing that needs to be changed - The PicoGUS is an 8-bit card and is not capable of using high DMAs. Your existing SB16 was more than likely configured to use a separate low and high DMA as is normal for SB16 except for specific scenarios.
The hardware resources would need to be adjusted so that the low and high DMA are the same. Some DOS games won't let you use these settings and only give you the option for the High DMA being 5, 6 or 7 (for example Duke 3D), those need to be dealt with on a case by case basis by manually editing the game's config file.
Reply 1946 of 1948, by Geriatric Danmaku
No worries on this one NeoG... Found that discussion a few months ago, and made the adjustment.
It may have been too much to ask for all Windows 95 games to work with SB Emulation. Here's my results so far:
Balls of Steel and similar pinball: YES
Get Medival: YES
NASCAR Racing 1999: NO
Starcraft: NO
Diablo: NO
There was some talk a few months ago about covering Windows with.... Windows Sound System emulation. That sounds pretty awesome. What's the latest news there?
PicoGUS SB output is SUPER CLEAN. It's going to be hard to go back to the supplemental noise of the real SB 16.
PicoGUS Joystick emulation is not working while the real GUS is installed.
Has anybody tried out a real era soundcard WITH PicoGUS installed, and had the Joystick emulation work? Which card?
NeoG_ wrote on Yesterday, 02:17:
Reply 1947 of 1948, by NeoG_
Geriatric Danmaku wrote on Today, 01:21:
Starcraft: NO
Diablo: NO
I'm surprised by these because they are windows games and windows should abstract the sound device for pretty much all software, I assume they were all working with the original SB16 card?
I have an SB16 and PicoGUS (I want the hardware OPL still, PicoGUS OPL3 is probably 95% there. Plus I use the 15pin joystick port). I have to remove the JYEN jumper on the SB16 card for the PicoGUS joystick emulation to work. See if your GUS card has a similar jumper. Otherwise the GUS and the PicoGUS will conflict on port 201.
Reply 1948 of 1948, by LSS10999
NeoG_ wrote on Today, 01:41:
Starcraft: NO
Diablo: NO
IIRC Windows drivers for Creative SB are not 100% compatible with third party implementations. It's entirely possible for something different from official Creative SB implementation to break certain driver functionalities.
I think standard wave output of lower sample rates and bit widths should be very likely to work regardless of HW implementation, but there's a high chance that FM and/or MIDI will not work requiring hardware-specific initialization routines that official Creative SB drivers cannot handle.
