First post, by ekkiller
Hi VOGONS,
I recently picked up the WaveBlaster-compatible card in the attached photo.
file.php?mode=view&id=249012
It is marked:
E-MU GM Module
SAMICK R&D
Rev.G1 KSS-PP-00901
Main ICs I can see:
· E-MU EMU8000 (CT1971-Q, 0052 A18359.1)
· Motorola MC68B50CP
· 2x Samsung K6X1008C2D-GB70 SRAM
· MIDMURO SME9964000
· TM T224160B-35J / 83 MHz
· Motorola MC68EC000FU10
· 2X WINBOND W27C010P
· 2X ATMEL ATF16V8B
· TI 42AC8FM HC08
· TI TL074C
· PHILIPS DA1545A
· 45.1584 MHz crystal
· 26-pin WaveBlaster header
How does it compare to the CT1910?
Thanks in advance!
144KM……
Reply 1 of 5, by ekkiller
CT1910
file.php?mode=view&id=249013
144KM……
Reply 2 of 5, by BloodyCactus
its a waveblaster ii, a cutdown waveblaster (less rom). 2mb vs 4mb.
that board looks like a fake to me. no other board has a MIDMURO SME9964000 chip. and ive never seen one with an QFP 68kEC chip (always PLCC), the samsung ram is date coded 2013.
I've also never seen an EMU8000 marked like that, and its dated coded 2000 and creative were not making them at that point.
the card might work, but its totally a fake knockoff.
Reply 3 of 5, by ekkiller
BloodyCactus wrote on 2026-09-12, 15:40:
its a waveblaster ii, a cutdown waveblaster (less rom). 2mb vs 4mb. […]
Thanks for the skepticism — fair points.
This board is the internal module from a Genio MP1000 (a Korean piano mute/auto-play unit), not a Creative retail product. That context explains the unusual parts:
· SME9964000: a custom logic chip used specifically on this module, not a Creative part.
· QFP 68kEC: I've seen other Genio MP1000 modules with the same layout, so this is a real production variant, not a one-off fake.
https://www.alldatasheetcn.com/html-pdf/3121/ … 8EC000FU10.html
· EMU8000 date code 2000: E-MU/Creative continued producing EMU8000 chips for OEM and embedded customers well past the peak AWE32/64 era. A 2000 date code on a niche OEM module is plausible.
· Samsung RAM date code: I don't see evidence of a 2013 date. The marking is SAMSUNG 419A. Samsung SRAM/DRAM date codes typically use a 3- or 4-digit format where the first digit(s) indicate the year and the remaining digits indicate the week. So "419" most likely means 2004 week 19 .
Functionally it's Wave Blaster II–class: EMU8000, 2 MB ROM, and it works in a standard WaveBlaster header.
file.php?mode=view&id=249139
If anyone has a Genio MP1000 service manual or another unit to compare, that would help settle the remaining questions.
144KM……
Reply 4 of 5, by ekkiller
I've now pulled a second module from a Genio MP1000G8 and it's a completely different design:
· MIDMURO SM9708F (PN: PB-00057, Rev. C, dated 2006.04.10)
· Dream SAM9708-LQ synth chip
· SAMSUNG K4S641632H
· SPANSION S29GL512N10TF101
· 12.288 MHz crystal
file.php?mode=view&id=249142
144KM……
Reply 5 of 5, by BloodyCactus
thats pretty cool. didnt know they kept making things well past date, but makes sense if they have an oem market to sustain.
i poked around on the net and saw there is one where the midmuro chip is renamed samick.
https://stat.ameba.jp/user_images/20250408/21 … 15564157229.jpg
