First post, by Hiddenevil
- Member
Hi all
So I had a little issue earlier today, I upgraded from MS Word 5 to 6. Deciding how much nicer it was, I decided to delete the old Word5 install. Only could I delete it? nope, it turned out there was a hidden protected file in the folder, msdos.sys i think. But that isn't why I'm posting, it's the utter pain in the butt it became to delete said file.
I'm a little rusty with DOS, but all my efforts to get remove/delete the folder failed, Win3 file manager wasn't much help either. So I thought, wait wasn't there a really good file manager back in the 90s for DOS?? Norton Commander? why not give that a shot and while I'm down the rabbit hole, why not try Xtree Pro.
The Sharps 7200, is a 286 with CGA graphics, if you can even call it that, the screen do the machine any favors 🤣
So Xtree was like nothing i'd ever used before and while it DID solve my issues. The more i messed with it, the more i realised I hadn't a clue what the heck i was doing. I couldn't even change the volume from C: to A: (if anyone knows, please do tell me)
I then decided to move on and try Norton Commander 3, it loaded and then froze the system, I then tried version 2.0 and then 1.0 and they all both froze up. I don't know if me running DOS 5.0 has any bearing on this, but I thought it worth mentioning.
So I'm a little confused what is going on and thought, why not post my woes here and see if anyone has had similar experience.
There's an old android saying which I believe is peculiarly appropriate here. In binary language it goes something like this: 001100111011000111100, which roughly translated means: "Don't stand around jabbering when you're in mortal danger!"
