Reply 80 of 252, by LSS10999
gsos wrote on 2026-09-23, 07:16:@LSS10999: Ideally, I’d like RetroOS to handle the motherboard setup and ISA PnP initialization itself, so configurations like […]
initialization itself, so configurations like yours wouldn’t require DOS utilities
before booting.Your HDA should likely work also, retroos would emulate the soundblaster there.
I know of HDA support which may be useful for some of my other systems on which it's being actively used.
But on that target system I need to disable it because it's the only way for me to free IRQ7 so the CT2950 card behind dISAppointment can use it.
gsos wrote on 2026-09-23, 07:16:The problems addressed by EGAFIX and NEWAX are also worth investigating. RetroOS already provides its own BIOS services for DO […]
already provides its own BIOS services for DOS programs, so some equivalent fixes might
fit there, but I’d need to examine what those utilities change before judging the work
involved.
The source code for these are available and are written in assembly.
I think they're specific to affected nVidia cards and not universal.
Other vendors may also have issues with certain VGA/VESA functionalities, but then they'll need their own methods to fix them.
gsos wrote on 2026-09-23, 07:16:Just to confirm: does the new image still hang at exactly the same point?
Yes, it still hangs at the same point, at least with no visible difference.
