Reply 40 of 58, by OzzFan
Not sure if I got the Screen Thief fix in, but I fixed up the progress bar and the renaming of short names. I made a bunch of UI changes including adding the file browser and text viewer. Version 1.4 attached to the original post.
One thing I haven't addressed is when trying to view a text file that's inside an archive within an archive. XArc wants to extract instead.
Hobbyist Developer : https://www.shelteringoak.com/du/
Reply 41 of 58, by OzzFan
DaveDDS wrote on 2026-08-28, 23:08:
Oh, believe it or not, i'm well aware that we've not been talking about DOS conventional memory. Wether or not you consider XMS as part of DOS (it's an add-ons shipped with DOS) is a matter of opinion (I don't particularly - but many people disagree) - but even with "normal" XMS you can'y go beyond 4G (and even >2G is tough) [...]
Fair point. I'm personally in the camp that believes DOS is nothing more than IO.SYS, MSDOS.SYS, and COMMAND.COM (or IBMIO.COM, IBMDOS.COM, and COMMAND.COM for PC DOS). Everything else bundled together is just an optional, extra utility not required for DOS to operate.
Reply 42 of 58, by DaveDDS
OzzFan wrote on 2026-09-08, 04:58:
I for the most part agree .. but I tend to expand my view slightly to consider tools provided that are essential for most "normal" use.
You don't technically need ATTRIB, COPY or many of the other things provided with DOS (and in fact I have replaced many of these things in my own working systems).
For that matter, you don't technically need COMMAND.COM if you are either using DOS to run a non-interactive system or have replaced it with a better option.
Having fairly in-depth experience with many dedicated/embedded systems, I tend to think of an OS as a "processor", "memory" and "storage" manager, and everything else just an application program.
TSRs, XMS drivers etc. are more of a grey area as they integrate into the operating environment in ways "normal" applications don't - I personally still consider them "system level" add-ons, but many people disagree.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 43 of 58, by ntalaec
OzzFan wrote on 2026-09-08, 04:37:
XArc 1.4 tested. Before XArc, to extract archives with long file names, I had to list the files of the archive, redirect the output to a BAT file, EDIT every file with long names in BAT file, execute it and finally extract the files. And this only worked if the command line in BAT file was shorter than 128 characters (DOS limit). Now I'm able to not only extract without all the hassle but to read the text files inside archive to check if it's worth the extraction. Many thanks for this!
Bugs found:
-Random crashes with Screen Thief 2.04 loaded stil persist. It happens trying to extract, viewing a file or doing nothing.
-At DOS statup, I have 618K of conventional and about 64K of XMS of memory free. In a DOS Shell session with Links Web Browser loaded, according MEM there's 360K of conventional, 15K of upper and 0K of XMS memory free. XArc is able to run with this amount of free memory. But, if I open a compressed file inside XArc, when I exit XArc there is 258K of conventional and 0K of upper memory free. When I return to and exit from Links Web Browser, the memory restores to 618K. XArc does not free the memory used after an archive has been loaded. This does not happen if I only view a text file inside XArc.
-When extracting files inside a long file name folder, if Extract Pathnames and Auto-rename to 8.3 are off, XArc asks for a folder name. Pressing Ok will extract the files without creating the folder. Pressing Skip or Cancel during folder rename dialog will cancel the extraction.
-Items in status bar also count [..] as an item.
Suggestions:
I see you did not implement all of my suggestions. I will assume you did not agree with them and I will not comment about them.
-Change F3 to view text file (as in Norton Commander), use F7 to test integrity.
-Keep the [..] to return to previous level when inside a file and remove option F2 return to disk.
-Change [..] to ..
-Maximize view text file window or, at least, show 80 characters wide to be able to read a file without the need to keep scrolling left and right.
-Show archive comment: add to menu Options Auto-show comments (off by default; if on, a text window will pop-up showing comments when opening an archive with comments), reuse text window to show comments with "Archive comment" in title, F2 will show archive comment if exists or will show a message box indicating that there are no comments in file, show in Archive info: Comment: Yes/No.
-Allow uncompress of password protected archives: when trying to extract, show a textbox to enter the password, show in Archive info: Password: Yes/No.
-Allow multi-volume archives (in RAR is: .rar, .r01, .r02...): when open any volume file, show all the files in all the volumes, show in Archive info: Volumes: [number].
Reply 44 of 58, by NeilKnows
OzzFan wrote on 2026-08-30, 20:43:
I've fixed up the XMS memory detection to try XMS 3.0 first before falling back to XMS 2.0 calls. Hopefully this should resolve the memory issue for you.
I also fixed the inability to extract to the root of a drive. This was caused by a double backslash when putting together the full path, e.g. C:\\MYFOLDER\.
The rest of your UI suggestions should now be implemented. Thanks for the feedback!
Thanks for taking the time to code such a utility.
I wouldn't get too hung up on whether the utility works with 3G+ of memory - that seems to be a very edge case scenario for most users of DOS (unless it helps understand a more general use issue/bug). A machine with >1GB RAM probably has other ways to unzip a 7ZIP file?
Thanks again...
Reply 45 of 58, by zyzzle
ntalaec wrote on 2026-09-12, 09:30:
-Change F3 to view text file (as in Norton Commander), use F7 to test integrity. -Keep the [..] to return to previous level when […]
-Change [..] to ..
Thanks for all of the improvements! v. 1.4 is now a really great program.
I agree with implementing the above. Viewing of .txt files within archives should definitely be on an 80-column screen with pgdn/pgup being able to scroll a full page at a time.
Multi-volume archive handling would be nice, but probably hard to implement and / or would increase the size of the .exe too much. We don't want XARC to become too bloated.
Reply 46 of 58, by OzzFan
Glad to hear it!
Suggestions:
I didn't disagree with the rest. I'm still working on the locality/region code to show group separators. I want to re-use this code for my Dobson Utilities suite too.
The only suggestion I was hemming and hawing over was renaming the .INI file. XArc is my guinea pig. All these features are getting ported to a Win32s and an OS/2 version with the full name XArchive, and all programs will work with the same .INI file.
-Change [..] to ..
I can do these. The hardest one is the password protected archives. 7Zip and later versions of .Zip use AES 256 encryption which is going to kill a 386, performance wise, but it is doable.
Thank you for the bug reports. The memory leak is particularly worrying to me, and I think I found it based on your report of viewing text files doesn't seem to trigger the leak. I'll get to work fixing and coding these suggestions. I appreciate it!
Reply 47 of 58, by OzzFan
NeilKnows wrote on 2026-09-12, 10:20:
Thanks for taking the time to code such a utility. […]
Thanks again...
I really appreciate hearing it. Thanks!
Reply 48 of 58, by OzzFan
zyzzle wrote on 2026-09-12, 20:46:
-Change [..] to ..
That's great! Glad I can contribute something to the community that people enjoy using.
Reply 49 of 58, by ntalaec
OzzFan wrote on 2026-09-12, 23:46:
In the last release you did implement some suggestions and others don't. You did not say why, so I thought maybe you don't like them. I always try to suggest what it seems more useful for XArc but in the end all are just personal preferences.
About XARCHIVE.INI or XARC.INI, I didn't know you were developing XArc to other platforms. If you plan to use the INI file for any platform it should have the full name, but it's more useful in DOS to type a short name (XARC) instead of a long one (XARCHIVE).
Reply 50 of 58, by OzzFan
Posted version 1.5 with support for password decryption and VGA graphics mode.
Reply 51 of 58, by NeilKnows
OzzFan wrote on 2026-09-27, 19:40:
Thanks for the update (in both senses)
Reply 52 of 58, by Yoghoo
Just tested it for the first time. Works nicely with password protected archives. Are there plans to also add the ability to create ZIP and 7Z archives in the future?
One thing I missed in the interface was a tree view or something like that to select a directory to extract to. Typing it in feels a bit awkward when using an interface. Other than that I'm impressed with how it works.
Reply 53 of 58, by OzzFan
Yoghoo wrote on 2026-09-27, 21:43:
I've debated it with myself and haven't arrived at a conclusion. I'm starting to lean toward adding compression too.
You're right. I'll work on adding that.
Reply 54 of 58, by zyzzle
OzzFan wrote on 2026-09-28, 19:09:
Perhaps add in the libdeflate compression library:
https://github.com/ebiggers/libdeflate
which compresses much better than zlib while still remaining 100% compatible with the .ZIP deflate standards.
Perhaps add in .7z LZMA2 archive compression with filetype detection (audio, text, images, and executables). Allow to adjust LZMA2 dictionary up to the limit of system RAM.
Reply 55 of 58, by OzzFan
Version 2.0 posted in the first message.
It's so nice to have a week off work so I can focus on this hobby. 😁
Reply 56 of 58, by zyzzle
Late review, but I tested v. 2.0 and the compression features work well. XArc just keeps getting better and better. A few questions and a bug I noticed.
When I try to compress a 2047.9 MiB file to a zip, I get the message (files of over 2 GB are not supported), but when I try to compress a 2000 MiB file, the error screen doesn't show. It's a bug in how you're computing file sizes. ZIP supports files of up to 2GIB-1 bytes = 2048 MiB. Please correct this, enable files of 2000 - 2047.9 mb to be added to .ZIP archives).
I noticed that ZIP compression is only mediocre (about the same as the DOS version of Pkzip v.2.04 and less than plzip v. 2.50 option -ex or -exx), even when libdeflate is available and much faster and with ~10-15% better compression ratio than regular deflate. libdeflate library should compile for DOS just fine, as it's straight C: https://github.com/ebiggers/libdeflate and is 100% compatible with zlib and PKWare's Deflate streams, and very heavily optimized for speed and space savings.
7zip compression works well, however what dictionary size and options are you defaulting to? Is the dictionary dynamically calculated based on the sizes of the files and available system memory? How about giving us the option to change the compression level from fast to extreme (the range -mx=1 to mx=9) and alter the fastbytes (from 8 to 273 in LZMA streams) for .7z archive creation?
Reply 57 of 58, by OzzFan
zyzzle wrote on 2026-10-19, 08:52:
I think you're right. I'll look at my file size calculations and confirm and fix.
I've aimed for PKZip 2.04g compatibility and default to -ex level compression. libdeflate requires a C11-compatible compiler according to its README.md, which no DOS compiler that I'm aware of is compatible with.
The dictionary is dynamically chosen based upon available memory size. I was trying to keep everything simple and easy-to-use since I think most people don't really care about all the nerd knobs.
Reply 58 of 58, by zyzzle
OzzFan wrote on 2026-10-20, 00:17:
You're right, and thanks for confirming dynamic dictionary sizing. That works well for most archives, but you may want to put in automatic file-based compression into the next release. For example, automatically detact .WAV files (audio) and .EXE files (x86 or x64 delta compression), as .7z has much better compression filters for these special files, and .7z archives may contain a mix of compression filters. The same for images like .BMP or .TGA files.
