First post, by 5a796d
The fix corrects the game's internal calculations to use 64-bit arithmetic (which doesn't overflow for hundreds of thousands of years), and also applies a small "realignment" every 30 minutes that prevents the value from ever approaching the critical limit, without any noticeable disruptions in the game.
Tested stable for over an hour of continuous gameplay, with no framerate drops, speedups, or side effects on physics, animations, or tire wear.
Tested on 64-bit Windows 10.
It may or may not work on systems older than Windows 10.
https://community.pcgamingwiki.com/files/file … sfreeze-fix-v2/
Reply 1 of 10, by 5a796d
Version V2, DLL injection is no longer required.
Reply 2 of 10, by Pavel 69
Hi! Is it possible to make such speedup fix for 32-bit system?
Reply 3 of 10, by 5a796d
Pavel 69 wrote on 2026-09-03, 06:36:
You can try the fix, but I can't guarantee it will work.
Reply 4 of 10, by Pavel 69
Ok, I will try this version. I just read note that it for 64-bit OS so didn't try.
Reply 5 of 10, by 5a796d
Pavel 69 wrote on 2026-09-03, 13:02:
I made a quick test on XP 32-bit; there don't seem to be any issues, but it needs thorough testing. If you're up for a session of at least an hour to make sure everything is okay, please let us know—thanks!
By the way, regarding the 64-bit arithmetic: I was mistaken in thinking it wouldn't work on 32-bit systems. It's just a mathematical calculation, not a conversion of the executable to 64-bit—something 32-bit systems are perfectly capable of handling.
Reply 6 of 10, by Pavel 69
5a796d wrote on 2026-09-04, 10:50:
I'm back with report. It works! Main tests were with Win 7 32-bit, but I also run game with Win Xp 32-bit just to see it can be start there. So I spent whole evening yesterday playing GP500 with your fix. No issues were spotted, no frame drops or speedups. Game run smoothly. I was able to complete full distance race at Brno! Finally! Thank you very much for this fix!
One more question. I'm playing GP500 with steering wheel. When I enter game, go on track I have force feedback. But as soon as I crash somewhere force feedback is gone. So I have to restart GP500 to return FF back. It looks like some bug in game.exe and it existed before your fix. Maybe you can help with this too?
Reply 7 of 10, by 5a796d
Pavel 69 wrote on 2026-09-06, 07:57:
Good, I'm glad it's working! As for the FFB, you should look for a DirectInput or XInput wrapper, depending on your steering wheel model. It’s almost certainly not an issue with the executable itself; rather, the old DirectX 6.1 components are emulated on NT-based systems, which causes problems. You’ll definitely find something useful on GitHub—it’s similar to the graphics situation, where you need to use dgVoodoo to get it running correctly.
Reply 8 of 10, by Pavel 69
Thanks for the tip! I will try wrappers for DirectInput.
Reply 9 of 10, by trjp
Hi. The person modifying GP500.exe must have a solid understanding of GP500; it would be useful to determine where the game retrieves the track length and lap count data displayed on the track selection screen for the original circuits.
It would be great to be able to see the length and required number of laps for the new circuits as well.
Reply 10 of 10, by 5a796d
trjp wrote on Yesterday, 10:19:
What you're looking to do is game modding; I created the fix to resolve issues on modern systems. I don't intend to include your requested feature in the fix—if it's feasible, that will be up to modders. Besides, there's no guarantee that the thing you want to modify is even in the .exe file.
