First post, by lilylarceny
I have seen a few comments here and there about hooking two sound cards together by running the output from one into the line in of another. This makes sense in my head, but I'm not sure how to achieve this with my setup.
ISA/Dos Sound Blaster CT3670
PCI/Win 98 Aureal Vortex 2
I have the CT3670, but still trying to find the "best" Vortex 2 for this application.
The CT3670 has standard analog stereo out/line-in on the back. it also has an unpopulated digital spdif line out, which I understand just needs a pin header soldered to. I'm not sure if this matters, but thought it was neat. Also has cd-in on the board, and another connector labeled J4 - I don't know what that does.
The Vortex 2 has two analog outs (front/rear speakers). A line in, as well as a spdif out (either pins on the board or a connector on the back, depending on the version). I don't see any with spdif in-put. They also have multiple line-in/cd-in on the board, but it all seems to be analog connections. I did see the MX300 has an unpopulated output connector on the board, but I'm not sure if that's a clone of output 1, 2, or a different output entirely.
Ideal scenario would be that one card is connected to the other card inside the computer from pin headers to pin headers, then the second card is connected to the speakers with 2-channel stereo in dos and 4-channel quad A3D in windows 98. As well as a CD drive connected that works for game CD-audio in either dos or windows. Potentially an external midi device down the road. I realize not all of that may be possible, but I'd like to have it "just work" and not have to swap cables.
However, because the PCI card would not be initialized in dos, I assume the Vortex 2 would need it's output-1 connected to the line-in of the ct3670, and output-2 connected to the rear speakers, while the ct3670 is connected to front speakers. Would that work? Is there a better solution to hooking these together? What sort of mixing would I need to do in windows 98 to make this work and still have quad A3D?
Of course, I could get a switch box, and not bother with all that, but it's not my first choice for sure. Also, I am not concerned with EAX on this computer, as I have a second 98 pc with an Audigy 2zs.
Reply 1 of 1, by NeoG_
For Live and Audiggy1/2 cards there are mixer init tools for DOS that allow you to open the line input of the card without the full driver set. I did find something like that for the Vortex 2, but it's unclear if the card needs to be fully initialised with drivers before the mixer app can work
https://www.philscomputerlab.com/aureal-vortex-2.html -> AU30MIX
Release -New Aureal DOS Mixer Util-
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
