Reply 400 of 406, by FullYes
Calolo wrote on 2026-10-13, 17:09:Hello […]
Hello
I have flashed the BIOS of my KT7A v1.1 to A9 (modded for Athlon XP) to use a mobile Barton 2400+.
I need to press reset when the PC cold boot, then the CPU is well recognized but limited to 1666MHz (12.5 x 133).
Has someone found a solution/BIOS option to make it boot directly?
Also if I strap CPU pins to enable high multipliers, how can I access the 3x for DOS slowdown?
Thank you.
Since you have a mobile Barton. You should be able to use pciset (to make setmul work on a KT133A) and setmul commands in your autoexec.bat to make the multiplier whatever the CPU will allow
My XP-M 2800+ will only recognise multipliers up to 16x, probably because it’s a late one.
Link to my thread which has a link to the post about pciset
I don’t have a kt7a but I have same chipset on a board made by Soltek. It seems to have a lot of the same quirks
I can’t help with the reset trick. The Soltek board POSTs fine with a Barton installed. I used bios patcher to enable the board to recognise the CPU, but it still posted without this patch. Just said “unknown CPU”
in my experience, modifying the socket of the CPU to change the multiplier caused more problems; the system would only post with 17x multiplier, this was too fast for any CPU I had at the time. (2266Mhz) now I have an XP-M I can get to 2350-2400MHz with 16x multiplier by increasing the FSB
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
