First post, by Paar
Hi! I'm trying GeForce 4 MX 440 on my Gigabyte GA-7ZM (Via KT133 chipset with 686A south bridge) but cannot make it work. First, the card doesn't work correctly until newer Hyperion branded chipset drivers are installed.
Once it seemingly works, the system freezes after a while whenever a 3D application is running. Didn't help: BIOS update, newer 4.56 Hyperion drivers, newer 45.23 Nvidia drivers, setting AGP driving value to EA, setting 2x AGP, disabling fast writes, disabling sideband addressing.
Maybe it's particular problem with my board, not sure. Radeon 7200 and GeForce 2 Pro both work perfectly.
Any ideas what to try? Maybe some specific AGP driving value?
Reply 1 of 9, by Paar
Ok, no one probably can help, so I did my own reasearch across various internet forums. It seems that this bug was quite common and is named "nvidia infinite loop bug" and happens from a certain version of Detonator drivers, probably 23.11 or so. Nvidia seemingly coded their drivers in a way that utilized some OS kernel stuff and that made some more unstable AGP implementations (like in this case) very sensitive.
Most people reported the problem on the Windows XP but it manifested on Windows 98 also. Via made some patch that set register 55 bits 5 to 7 to 0 but in Windows 98 you have to use wpcredit. I have checked by settings and those bits are already set to 0.
Tried various BIOS versions, various Nvidia drivers, multiple Via chipset drivers but nothing helped. Found a tip that in Windows XP you can manually override Via AGP driver with standard PCI-to-PCI driver from Microsoft and even though there is some performance hit (e.g. AGP texturing doesn't work) at least the bug doesn't pop up. Couldn't do it in Win98 as I couldn't manually select such driver. So I given up and changed the card, Geforce 4 MX and Via KT133 are not meant to be put together.
Reply 2 of 9, by FullYes
I think I had an mx440 in my jetway 663as-based Athlon thunderbird system back in the day. (Kt133 chipset, like yours) it was a very popular card and I’m sure the combination was/is widely used.
I use 4.43 via drivers and detonator 45.23 for the graphics on my kt133a system now, I have an mx440 but it is faulty. Bad caps I think. My two FX series cards work fine on this board.
Someone else with a kt133a board had issues with fast writes and/or sideband addressing. You may want to see if you can disable one or both of these features in turn to see if your stability improves
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
Reply 3 of 9, by gmaverick2k
I have a ga-7zm board too. A real dog to work with from what I can remember. Relegated to storage a long time ago. Gigabyte were really good with super socket 7 and 440bx but after that they were horrid until sandybridge I reckon
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4GHz/V3 3000/Vortex 2/ESS 1868f/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 4 of 9, by Paar
FullYes wrote on 2026-10-20, 21:59:
I have played with these settings, set AGP to 2x and even 1x, disable fastwrites and double checked with powerstrip that sideband addressing is off. Nothing helped.
gmaverick2k wrote on 2026-10-20, 22:18:
It's nicely made board but the limited AMI BIOS is a pain. There is no setting for disabling ACPI nor you can toggle L1/L2 cache (luckily the former is toggleable with setmul). However apart from problems with MX 440 I have to say the system is stable with Radeon or older Geforce cards. I have another KT133 board from Chaintech which uses Award BIOS, maybe it's worth a try. It needs recapping though.
Reply 5 of 9, by myne
I'd hunt for an old version of mats mods and test the card.
Especially memory
I built:
Reply 6 of 9, by Paar
myne wrote on Yesterday, 06:44:
Especially memory
What is mats mods?
Reply 7 of 9, by FullYes
There is also vmtce for testing GPU memory
Accurately troubleshooting video memory faults with VMTCE
Come to think of it, before my mx 440 stopped working altogher, the first sign of trouble was failure during driver installation. System would hang or show a blank screen until reset. I intend to have a go at repairing at some point. I just need some more equipment (esr tester)
Reply 8 of 9, by myne
Failing on driver load is classic bad memory.
Nvidia seem to be able to run in vga mode without memory, possibly using cache.
No real need for esr tester.
Just replace the caps.
Mats mods, and soldering.
I built:
Reply 9 of 9, by myne
https://www.google.com/search?q=What+is+mats+mods%3F
I built:
