Cyrix appreciation thread
Reply 560 of 582, by rmay635703
elmatero wrote on 2026-04-25, 05:29:
There was also ultra rare 83x2 PR-233 produced by IBM .
https://www.cpushack.com/CyrixID.html
If we want to include early/very late/rare it’s important to note that many Cyrix chips with a specific physical speed started out one speed rating then moved up (or down) to another later. (See incomplete chart)
There is Some evidence that Cyrix overseas did some tall tales selling things with different markings compared to domestic
[as 95x2.5 (black top) was noted some places as existing as pr333] which as far as I know never existed in NA.
Good examples of the same chip being marketed as different speeds
PR266/PR300
PR333/PR350 ~366(at least it had a different FSB)
The historical PR400 had a different clock speed but I don’t think it was actually released when it was mentioned historically (it showed up early in the computer shopper but nobody had inventory )
Pr350’s of any variety are rather rare and worth documenting
The attachment IMG_8720.jpeg is no longer available
Back when I was on an old bravenet forum during the last 3 months National was in the Cyrix business insides (folks that bought a lot of Cyrix chips for pc business) were claiming they were selling all sorts of strange things, different colors, different labeling /typesets, wierd voltages and wierd speeds.
Now 26 years later I haven’t seen photo evidence of most of these, just verbal mentions here and there.
Makes me disappointed nobody from vcfed interviewed the Cyrix folk before they passed
Reply 561 of 582, by mwdmeyer
Yeah I have an IBM 6x86MX PR233 3x66MHz FSB that matches the MHz of the Cyrix MII PR266 - 200MHz
Reply 562 of 582, by weilun777
Hello. This is also the CPU used in my first personal computer(Cyrix 6x86 PR120).
I've always wanted to collect its best CPU.
Reply 563 of 582, by BitWrangler
weilun777 wrote on 2026-04-27, 07:01:
If the motherboard was fixed voltage, single plane, that might have been the PR 166+, if the PR120 was an L version and there was split plane, possibly PR-200+
but usually split plane would allow MMX/MII support, then you'd be hunting unicorns with us in the "do the 400 or 433 functionally exist?" realms. But the motherboard could have been limited by bus speed to maximum 233Mhz actual clock speed too, or by the strength of the voltage regulator to under 15W or similar.
Reply 564 of 582, by nickles rust
I bought a Cyrix 333GP 2.9v and did some quick testing to find settings that work:
2.0v 225MHz, 2.2v 237MHz, 2.4v 250MHz, 2.9v 285MHz. It would post at 3.2v 300MHz but it's definitely unstable. It works fine at lower voltage/speed, so I guess it's one of the 250nm chips despite the 2.9v label. As others have posted earlier, it probably takes one of the "2.2v" chips to get 300MHz and up.
Also, it was difficult to get the web site to work and post this. Something about dating robots? This may be one of my last posts if it's going to be this much of a hassle.
Reply 565 of 582, by feipoa
I'd like to know which Cyrix qualifying tests passed with the PR433, but not with the PR400. From my past testing, both appear to run fine at 3x100 with 2.2 V.
How far has one of these been overclocked, yet was still able to run a full suite of Windows games and software? In my tests, the PR400 ran fine up to 333 MHz. Almost everything ran OK at 350 MHz, except for the Final Reality benchmark. I didn't try overclocking my PR433 chip.
Reply 566 of 582, by appiah4
nickles rust wrote on 2026-04-27, 21:07:
Website works 100% fine for me.
Reply 567 of 582, by rmay635703
feipoa wrote on 2026-04-28, 03:15:
Unofficially my VIA pr433 2.2 volt easily went to 400mhz, my board didn’t go any further.
It appears I sold off the chip when I downsized circa 2010 (ish)
Reply 568 of 582, by feipoa
I was referring to the Cyrix MII-PR433, not the VIA C3 series.
Reply 569 of 582, by rmay635703
feipoa wrote on 2026-04-28, 13:45:
Mine was a “Cyrix” MIIv-pr433, date code was well after national was dead so made by via .
I don’t remember even having to fudge voltage , used it with a SIS 540 motherboard
Reply 570 of 582, by BitWrangler
I would imagine that someone on your ISP has been a naughty boy. If you don't have a static IP, then turning your cable/fibre/DSL modem off overnight one night might get you a "cleaner" IP in the morning.
edit: nope something else going on, discuss there .. Don't date robots?
Reply 571 of 582, by BitWrangler
rmay635703 wrote on 2026-04-28, 13:53:
Some sources have Via cranking those out well into the noughts, so I don't know where they all went. Developing markets most likely.
Reply 572 of 582, by feipoa
rmay635703 wrote on 2026-04-28, 13:33:
my... pr433 2.2 volt easily went to 400mhz, my board didn’t go any further.
Which Windows 9x benchmarks, games, or other software did you run at 400 MHz? From my experience, running the chip with difficult software at 350+ MHz caused crashes. I think if these actually ran well at 400 MHz, they would have marketed them as such.
Reply 573 of 582, by mwdmeyer
If someone has a Cyrix machine running, I've love if you could try my benchmark tool
https://starrts.vogonswiki.com/downloads/stwin072.exe Windows 9x
https://starrts.vogonswiki.com/downloads/stdos072.exe DOS
Designed to target 2D RTS performance. I really want to see how Cyrix compares to Intel for this benchmark.
Reply 574 of 582, by feipoa
mwdmeyer wrote on 2026-04-28, 23:45:
If someone has a Cyrix machine running, I've love if you could try my benchmark tool […]
I have a few Cyrix based systems setup, but put away. Do you have a table of results we can see for StarRTS? This will let me know what's lacking. I haven't been keeping track of all the new benchmarks being pushed on VOGONS.
Reply 576 of 582, by feipoa
How do we view the results of systems from the socket 3/4/5/7/8 eras? I was only able to view 10 entries from modern type computers.
Reply 577 of 582, by mwdmeyer
feipoa wrote on 2026-05-02, 00:58:
On the leaderboard page you can filter/sort. Most people seem to have submitted from new machines so lots of room for people with older machines to submit.
I am going to improve the filter in future.
I've also added a new memory latency test which should be interesting on Cyrix CPUs.
Reply 578 of 582, by classic_cola
Few days ago I took ownership of a 1996 Socket 7 machine.
First time owning a 120MHz 6x86 (although way back I had a 6x86MX PR300).
What surprises me about this chip is that its FPU performance is really quite serviceable; it's obviously not as good as a Pentium, but it's not *shockingly* slower, from my early benches I think mine behaves somewhere between a Pentium 75 and P90 in FPU heavy tasks. Which isn't amazing for its clock, but from the narrative you'd have thought these things play quake like a DX4-100 .
Reply 579 of 582, by FullYes
I had a cyrix mII PR233 (200MHz) which i did overclock to 225MHz on my pcchips m571! Some years later I did also buy for pennies a later one, not sure if it was a 300 or 333, but was disappointed it was basically the same clock as what I’d already had out of the pr233
I paired my cyrix with a 12MB voodoo2 and at the time I thought it was great. But I probably only had it for 6-9 months before upgrading to a k6-2 and a TNT2
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
