Wipeout 2097 3dfx mode
First post, by arcofreccia
Good morning, I’ve installed Wipeout 2097 on my first PC (as mentioned in my signature) and the system requirements should be spot on. My question is: does the game already support 3Dfx out of the box, or do I need an additional patch for 3Dfx mode? I’m asking because the animated 3Dfx logo doesn’t appear when the game starts. Also, before the game starts, I get this screen, but is it normal for ‘Direct 3D HAL’ to be selected under ‘Device’? Shouldn’t the 3Dfx card be displayed there? Incidentally, I’ve tried launching the game in 800x600 mode but it won’t start; it only works in 640x480 mode. Thank you for your help.
Pentium200MMX/Ram64Mb/Hdd 6,4 Gb/Floppy 3.5"/ESS1868F/Matrox MillenniumII+Diamond Monster3D(3Dfx Voodoo)4 Mb/Win98SE
Pentium III-S1,4 Ghz/Ram512 MbPC133/Hdd Maxtor80Gb/IomegaZip100Mb/Floppy 3,5"/SoundBlasterPlatinum/3DfxVoodoo5/Win98SE
Reply 1 of 8, by jh80
I'm not too familiar with the game, but it doesn't support glide at all, does it? If it's not running glide, it won't display the splash screen as I recall.
The bottom of the box (that I looked up on ebay) says it uses Direct 3D. So you can still use the 3dfx card, it just won't be glide.
Reply 2 of 8, by marxveix
Wipeout 2097 has some kind of PowerVR support (version), but its also over Direct3D only, there is no glide.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 3 of 8, by arcofreccia
During installation, it asked me whether I wanted to install the Direct3D version or the PowerVR version. I selected Direct3D, partly because when I tried to install the PowerVR version, the game wouldn’t start as it required a PowerVR graphics card. I’ve seen the box on eBay too, and the front states that it requires a 3D graphics card. On the back of the box, it says that 3Dfx graphics cards are supported, so it should run in 3Dfx mode. Therefore, the base game supports 3Dfx Glide
Reply 4 of 8, by marxveix
arcofreccia wrote on 2026-10-31, 11:47:
Wipeout 2097 has no Glide, its Direct3D game. First Wipeout had ATi3DCIF version.
WipeOut 2097 / WipeOut XL System Requirements (1997)
Operating System: Windows 95
Processor: Intel Pentium 133 MHz (Pentium 166 MHz recommended)
Memory: 16 MB RAM
Graphics Card: 3D Accelerated Card with 4 MB VRAM
Supported chipsets: 3Dfx Voodoo, ATI 3D Rage, Matrox Mystique, PowerVR, Rendition Verite, or 3D Labs Permedia.
Hard Drive Space: ~30 MB (minimal install)
CD-ROM: 2x Speed or faster
Sound: DirectSound compatible card (e.g., Sound Blaster, Gravis UltraSound)
Reply 5 of 8, by arcofreccia
That’s right, so 3Dfx is supported as a chipset. As I have a Diamond Monster, I wanted to find out if the game runs in Glide mode
Reply 6 of 8, by jh80
3dfx cards have Direct3D support, so they can still work as accelerators on games that only support Direct3D. That's why the 3dfx logo is on the box. There is no glide support that I know of.
Reply 7 of 8, by darry
arcofreccia wrote on 2026-10-31, 12:06:
Glide is a 3D graphics API, as are Direct3D, OpenGL, PowerSGL, CIF, etc. There are (mostly were) quite a few others. There versions and feature levels of most of these, tgat a given hardware implementation may or may not be able to support fully or at all, either in hardware (usually faster) or in software (usually slower). Let's set aside versions and feature levels for now.
3Dfx based cards support Glide, Direct3d and OpenGL (initially just a "miniGL" subset implementation of it).
A 3D game with 3D acceleration support has to support at least one 3D graphics API.
Some games supported more than one 3D accelerated graphics API, either out of the box or through later released patches. Some games had no 3D accelerated graphics API support until a later patch added that feature. Some games were released in multiple versions, each with support for a specific 3D graphics API (more common in the early days, bundled with supported hardware).
Wipeout 2097 supports Direct3D and a PowerVR specific API (probably PowerSGL). Of those, a 3dFX based card supports Direct3D, so that is the only way to get 3D accelerated graphics with Wipeout 2097 on the 3dFX hardware you have, to the best of my knowledge and what generally reliable sources I could find online [1].
[1]
https://www.mobygames.com/game/3134/wipeout-xl/specs/
Reply 8 of 8, by NeoG_
It doesn't run in glide mode, 3dfx cards are "supported" via Direct3D
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
