First post, by darkronin
Hello, a lurker here, actually first time post. Be easy on the newb 😉
Quick question - are there any Midwinter 2 fans out there? this game (on Amiga) has been a part of my childhood. With all the annoying loading times.
I've enjoyed it on dosbox as well, but the transition times were atrocious, and the music... mediocre, and not what I've remembered.
Long story short, I've been able to prepare a patch (for the original exe file) to:
- allow for custom files modification (disable checksum check)
- auto configuration of CPU/sound/steering device (needed below)
- eliminate long transition times
- fix mouse instability
- make steering more modern (WASD + mouselook) No more pressing F1 to interact... (well, technically one can - old keys remain functional)
AND
- ported the original amiga soundtrack for the use in dosbox. (by using custom soundfonts files on Roland driver)
Would anyone be interested to give it a try (and is it allowed to be posted)? Or I'm just the only one with fond memories of this game?
DISCLAIMER: I won't provide the modified (nor original) exe file - just the python byte patcher for use with your own copy, and the custom created MIDI files. However, obviously, the original aMiga music score and samples remain with Dave Lowe, and I have no intentions to infringe on that or claim my own composition. Just porting it over.
Reply 1 of 4, by RetroGamer4Ever
Not to burst your bubble, but I suspect that the Official Fan Remaster of M1 that is being developed and coming soon, is going to lead to the same for M2, so you should probably just leave it alone or try to get involved with the M2 efforts, if and when they begin.
Reply 2 of 4, by darkronin
I've already seen the progress on M1, and shared there 😀 But that's for a remaster, something entirely different/bigger, on an entirely different engine. The music might get useful, nevertheless.
I've just prep for myself a simple modification which works on the original game files with dosbox, as a fun exercise. This is already done and working. If nobody else needs it, that's fine too.
Reply 3 of 4, by ludicrous_peridot
Hello, @darkronin
While I never played either of the parts when they were originally released (nor ever owned an Amiga 😉 ) I have a slight interest in the game. PC version was one of the first titles I picked up on floppies when I started gathering physical copies of old games (which happened fairly recently to me), and I then was able to also get the manual. While the game appears to be quite ambitious, I never really got into it. To me if felt more like an electronic version of a pen and paper role playing game with modern times espionage settings, than an actual adventure. Graphics sure look great (although I can't help thinking about Abrams Battle Tank for some reason), but are still abstract to the point this do not help suspension of disbelief at all - well, at least in my case.
I can run it on my PC unmodified with sufficient slow down factor applied and can in principle move around and control stuff. With OPL music the opening theme is great, I sometimes run the game to simply listen to it in background. Roland version of the theme, unfortunately, seems to be abridged. Never tried it with an emulator.
It would be cool to learn from a fan how one can actually have fun in Midwinter 2, at which point your patch may be quite handy.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - X3MB - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - YMF740 - MT-100
https://archive.org/details/peridot-26
Reply 4 of 4, by darkronin
Hey!
Well, for me. nostalgia googles play quite a part (and that's why I tried to port the music) - well, suspension of disbelief is doing some heavy lifting there, given the game nature.
I might be having quite a leap of faith, but for me, this game/series is spiritual (if not mechanical) prequel to the Just Cause series (which is actually a sandbox playground of just going nuts with mechanics). So if I want a"quick" (well, now it can be quick when the waiting times are eliminated), I just usually pick an island at random and either try to:
- follow the plot like in an RPG, hopping from person to person in a linear sequence, doing their quests until i finally arrive to the objective
- explore the map (usually plotting a route between settlement dots to actually populate the map with POI on its own)
- go on a frenzy with enemy units (not keeping eye on the timer, the nice point of this game is that there is no "you are killed" message - it's just losing a lot of time when you are injured.). sometimes with some challenges like "no shooting, just jumping from vehicle to vehicle until enemy runs out of them" 😀
Also, in 90's this game had a fun point of giving you some abstract "reward item" for each island (fixed, but distinct) and I kinda collected them like modern day achievements 😉
okay - /rant off
