Mechwarrior 2 Decomp/Recomp
Reply 20 of 21, by Mikeyy00
MalekBrood wrote on Yesterday, 22:33:
I want to try this but I'm stuck when it comes to the 'copy the contents of your install folder'. I don't have one and the installer won't run on x64 machines as people know. How do I install the game/create the install folder? Many thanks in advance and also for creating this, it's awesome.
I can't link a folder here because reasons.. but you can either fire up dosbox, install it there, then copy the folder out. Or, you can poke around online for a prepackaged dosbox copy from an abandonware site and grab it there..
You could also just fire your ISO into your AI of choice, along with the zip of the source code off github and then ask it to extract the install folder for you...
Reply 21 of 21, by Deffnator
here is what i said about visual issues
when i tested first, it was fine, now with this update, is busted
