First post, by CkRtech
I've been working with a lot of VLB cards over the last year and noted that several of them should be able to take advantage of interleaving when their RAM is upgraded. So in addition to acquiring any new resolutions, color depths, or refresh rates, performance in existing modes will improve.
The S3 Vision868 is one such chip, and it is present in this Diamond Stealth 64 that I have. So let's see what sort of difference an upgrade from 1MB to 2MB will make.
DX4-100 Overdrive on SiS 471 motherboard. L1 write through. L2 write back + alter bit. 24MB of RAM.
Windows for Workgroups 3.11 with generic S3 drivers 1.5B4
No BIOS settings were changed between benchmarks.
First - Winbench 95 Graphics Winmark, Wintach, and Winspeed 1.0 were used. Here are the overall scores for Winbench 95 & Wintach + the video score for Winspeed for both RAM configurations as well as the percentage change in score.
The attachment Benchmarks Overview Stuff.png is no longer available
The attachment Benchmark Percentage Gained.png is no longer available
Second - Details of individual GWM scores for 256 colors (640x480, 800x600) and 64K colors (640x480)
640x480 @ 256 Colors 1MB vs. 2MB - Graphics Winmark:
The attachment Diamond Stealth 64 DRAM Vision868 1MB vs. 2MB @ 640x480 256 Colors.png is no longer available
800x600 @ 256 Colors 1MB vs. 2MB - Graphics Winmark:
The attachment Diamond Stealth 64 DRAM Vision868 1MB vs. 2MB @ 800x600 256 Colors.png is no longer available
640x480 @ 16-bit (64K) Colors 1MB vs. 2MB - Graphics Winmark:
The attachment Diamond Stealth 64 DRAM Vision868 1MB vs. 2MB @ 640x480 64K.png is no longer available
Also note that Fastdoom VBD modes for both 320x200 VESA and 640x400 saw a boost of about 2 fps.
So if anyone is out searching to see what sort of differences a RAM upgrade might make with this chip, I hope this data helps.
Reply 1 of 7, by RayeR
I have a Tseng ET4000/W32 VLB with 1MB in 8x DIP 44256 chips in sockets. On PCB they are marked as BANK0. There are also unpopulated footprints for another 8 DIP chips marked as BANK1. So I was thinking the same if adding the 2nd bank also gains some speed. Not sure if extra DRAM will be find automatically or I will need to change/add some jumper or resistor somewhere...
Reply 2 of 7, by CkRtech
Hmm. I believe you would need a W32i or W32p to do interleaving. I don't have any Tseng ET4000 cards yet, so I cannot confirm.
Reply 3 of 7, by RayeR
Maybe that's the reason why 2nd bank sockets was not populeted. I just soldered them on but I don't have enough fast 44256 DRAMS (only 8 pcs of 70ns and then some 100ns). I could try put 4 chips to bank 0 and 4 to bank 1...
Reply 4 of 7, by mkarcher
RayeR wrote on 2026-11-04, 02:05:
That configuration is not supported, and likely would not help anyway. The ET4000 series of chips is meant to be used with a 32-bit wide memory bus, which needs 8 of those 4-bit chips per bank to get the preferred bus width. They can work in a degraded 16-bit mode for entry-level cards with only 512K of video memory (four of your chips in bank 0), but there is no support for two interleaved 16-bit banks, which would very likely be significantly inferior to a single 32-bit bank.
Just for completeness: There is a VRAM mode on the ET4000 series that no one uses. That mode splits the 32-bit data bus in two 16-bit busses, one for drawing (using the random access port of the VRAM) and the other one for display (using the serial port). I don't expect that mode to be implemented in the W32, but I'm not sure. I have no idea whether there are any theroretical advantages of the 16-bit VRAM configuration over the 32-bit DRAM configuration. There most likely is an advantage at 512KB (16 bit VRAM vs. 16 bit DRAM), though.
Reply 5 of 7, by RayeR
Ok, so at least I could get more colours in VESA modes. BTW is there some video BIOS upgrade for VLB card that has implemented VESA VBE? Currently I have to run some Tseng TSR. There are multiple versions and dunno what's the latest/best one. But all ca do only VBE 1.2 not 2.0. Maye even LFB mode not supported by HW?
Reply 6 of 7, by CkRtech
You probably want to create a separate thread for that to get more eyes on the question and to keep this thread on topic.
Most of the cards I've tested are all pre-VBE 2.0 video BIOS implementation, and VLB started to sunset before those writing the BIOS planned to implement VBE 2.0. There is quite a bit of variance in terms of which cards are supported well via TSRs - native TSRs, univbe, and univbe versions are going to be quite different from card to card.
Reply 7 of 7, by RayeR
You were right. My card is exactly this one: https://theretroweb.com/expansioncards/s/his- … 2-non-i-version
with only W32 chip so no interleaving. But the card manufacturer prepared the PCB for W32i and 2MB. I did a bit of RE over PCB and found that CAS# pins of unpopulated DRAMs goes to CAS4-7# of W32i. I can't find pinout of W32, that pins are not NC but has some unknown meaning but not simply possible to expand it to 2MB non-interleaved. I also tried with 100ns chips and it works too, maybe memory controller is smart and flexible to accomodate to slower DRAMs...
So maybe if I would find some suitable donor of W32i I will swap the chip...
BTW even that NI card performance is not bad, Doom timedemo: ET4000/W32 - 41,56 FPS vs S3 Trio64V+(VLB) - 42,93 FPS...
