Reply 20 of 27, by Chkcpu
amadeus777999 wrote on 2026-11-04, 11:04:
Dos 7.1 as in W9x. If I get the board at the end of the month I'll post an update and run the legacy exe of your info utility on […]
red-ray wrote on 2026-11-04, 09:36:
amadeus777999 wrote on 2026-11-04, 08:55:
The link concerning the board is https://www.kleinanzeigen.de/s-anzeige/asus-p … 628356-225-6330
I think the little tag reads "OR"...?
Good luck, a save from a SiS 496 OR would be good, AFAIK I don't have one. Which OSes do you plan to install? I have W2K + NT4 + 98SE my Intel DX4-WT (P24C) 120MHz @ SK096 (I have a selection of CPUs)
Dos 7.1 as in W9x.
If I get the board at the end of the month I'll post an update and run the legacy exe of your info utility on it.
I have a book by Hans-PeterMessmer describing pc hardware... maybe there's some hints regarding a "PCI configuration dump".
You guys are making me feel old! 😉
Don’t you have the PCI bus sniffer in your DOS tools collection?
After this tool has scanned the PCI bus, you hit the F2-key to write a full configuration space dump of all PCI devices to disk.
The attachment pcisnif071b.zip is no longer available
Enjoy, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 21 of 27, by amadeus777999
Chkcpu wrote on 2026-11-04, 12:10:
You guys are making me feel old! ;) Don’t you have the PCI bus sniffer in your DOS tools collection? After this tool has scanned […]
Dos 7.1 as in W9x.
Enjoy, Jan
Ok, Thanks!
Btw, the North-bridge is "OR" tagged.
Reply 22 of 27, by red-ray
Good luck, I am much more used to using NT, I will help if I can. For disks I got both of these https://www.ebay.co.uk/itm/257341160976 which are as big as I need and they "don't hang around".
Below is all I need to see, a Menu->File->Save Local file will contain this "with bells on".
file.php?id=251983
Reply 23 of 27, by red-ray
I would not be surprised if I am older 👴, I was writing kernel mode drivers for a twin PDP-11/70 system, main + hot standby, in the late 1970s.
Thank you for posting your utility.
amadeus777999 wrote on 2026-11-04, 12:40:
I have added PGD0 to OR - PGD0 - 95 - 30 - only FPM, time should tell if the 30 is correct
Reply 24 of 27, by Disruptor
@Disruptor
The board is a revision 1.0 from what I can see.
I asked the seller to take a look at the north bridge or send a picture.
It is unlikely that an ASUS PVI486-SP3 Rev 1.0 will have EDO support.
The chips are from beginning of 94 so it is like they one of the first revisions of the SiS 496 chipset.
And that board is overpriced too and neither has good VL nor good PCI performance.
Reply 25 of 27, by amadeus777999
Disruptor wrote on 2026-11-04, 17:03:
It is unlikely that an ASUS PVI486-SP3 Rev 1.0 will have EDO support. The chips are from beginning of 94 so it is like they one […]
@Disruptor
Ok, thanks.
Never had a PVI486 before, so I'm curious.
I currently have HOT433s and one GA-486AM/S.
Which board would you recommend?
Reply 26 of 27, by Disruptor
Depends on the HOT version, but this will go too offtopic now. And I don't want to hijack this thread by posting about UMC chipsets.
Perhaps you can use the search function of this message board. I've written something about the HOT board.
Basically I recommend 486 boards where you can use a PS/2 mouse - or somehow add PS/2 mouse support.
Reply 27 of 27, by red-ray
amadeus777999 wrote on 2026-11-04, 20:19:
A lot depends of what you want from the board, when I ask such questions I post the URL to the exact board, there are several differ HOT433 revisions.
The https://theretroweb.com/motherboards/s/asus-pvi-486sp3 has a SiS 496, the datasheet is available so such as SIV can report it well, I would choose this as a result
The https://theretroweb.com/motherboards/s/gigabyte-ga-486am there is AFAIK no UmC datasheet
The https://theretroweb.com/motherboards/s/shuttl … ot-433-ver.-1-3 is UMC
I would chose the one with a PS/2 mouse is all else was equal, I can't quickly tell how well SIV will do the the UMCs, less when than on the SiS, and I suspect other utilities will be similar
Update: On UMC you should get the timings + L2 cache size, but no per SIMM sizes or EDO/FPM flags.
