First post, by Vresiberba
It works flawlessly if I stick it directly onto the motherboard IDE connector, but as soon as I use the cable, same settings, same CF card, nothing works.
https://www.sybausa.com/shop/it-products/memo … t-sd-cf-ide-di/
Reply 1 of 4, by kingcake
Are you using a 40 conductor or 80 conductor IDE cable?
Reply 3 of 4, by wierd_w
Is this gender changer 'straight thru', or does it invert the order of the pins as well?
IDE needs the pin order inverted to change the gender.
Reply 4 of 4, by keenmaster486
Try turning off DMA to force it into PIO mode. There may be a jumper for it on the adapter.
World's foremost 486 enjoyer.
