Rust-DOS, a new DOS emulator
Reply 140 of 157, by Dividebysandwich
Rust-DOS v1.7.4 is available -> https://github.com/dividebysandwich/rust-dos/ … ases/tag/v1.7.4
VFX1 emulation
(Inspired by https://github.com/LeonG-ZA/forte-vfx1-vr)
Enable VFX1 in settings and a headset will appear on the table. You can put it on and take it off at any time - just grab it and put it over your head to wear, and grab it from your head and put it away to remove. Running any VFX1 enabled game will render as stereoscopic 3D inside your VR headset while you are wearing the virtual VFX-1, and will render as left/right eye image on the VR monitor if you remove the VFX-1 from your head.
This is not really something that can be shown with a screenshot - you'll have to try this out yourself.
NOTE: Resolution and FOV are limited to the original as supported by the respective games. This feature only works in VR headsets, it wouldn't make much sense on a 2D screen.
Usable VR keyboard
If you just want to try something out quickly without a connected bluetooth keyboard, there's now a VR keyboard that can be used and grabbed with the VR controllers.
NOTE: The bedroom scene has been updated, please go to the scene list and download the update right inside Rust-DOS.
Improved Vérité and PowerVR support
Several texture and rendering issues are fixed and games should work better across the board.
New logo
By @Dominusprog, thanks!!
## Other fixes and changes:
* Read CD sectors whose EDC fails as errors, so copy protections that check them pass by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/116
* Round FBSTP as the control word says and store the BCD indefinite for what doesn't fit by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/117
* Say when a state's drive image has moved, not that the state is of another machine by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/118
* Document how Windows OpenGL games reach the Voodoo2 by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/119
* Translate MMX and SSE instructions on x86-64 by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/120
* Draw 3dfx OpenGL's raster states with variants that fix only the combines by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/121
* Translate SAHF and FILD of a qword by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/122
* Start blocks in a page's last 15 bytes on x86-64 by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/123
* Run SSE arithmetic without loading MXCSR where the guest's matches by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/126
* Read IDE disk blocks at once in REP INSW and INSD by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/127
Full Changelog: https://github.com/dividebysandwich/rust-dos/ … v1.7.3...v1.7.4
Reply 141 of 157, by dominusprog
Glad you liked it.
SVG+PNG
The attachment Rust DOS.zip is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 142 of 157, by hail-to-the-ryzen
An error is reported in-game by this dos port: DevilutionX DOS port (still being worked on). It shows a dialog box without a crash, but describes an error: "Lua error when loading lua\inspect.lua: table index is NaN". I press the Ok button in the dialog box and the application exits. I tested with both interpreter and dynamic cores. However, the game runs without an error in a version of dosbox-x. The port depends on SDL3 and a modification for multithreading.
I parsed the logs of Rust-DOS for these lines of interest:
Log
Error=03
[CPU] #PF(0006) at 00A7:00347A87 CR2=00AEEA8E
[CPU] #PF(0006) at 00A7:003441C5 CR2=00B00974
[CPU] #PF(0006) at 00A7:00347A87 CR2=00B0621E (later ones here not logged)
[CPU] #PF(0006) at 00A7:00347FD4 CR2=00B01BCC
[CPU] #PF(0006) at 00A7:00345B29 CR2=00B0A870 (later ones here not logged)
[CPU] #PF(0006) at 00A7:00348344 CR2=00B0DEDC
[CPU] #PF(0006) at 00A7:0034837C CR2=00B0C6AC (later ones here not logged)
[CPU] #PF(0006) at 00A7:00348344 CR2=00B0E2E4 (later ones here not logged)
[CPU] #PF(0006) at 00A7:003483F5 CR2=00B0B284
[CPU] #PF(0006) at 00A7:00347B4C CR2=00B10000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:003441C5 CR2=00B055D4
[CPU] #PF(0006) at 00A7:00347A3E CR2=00B15000 (later ones here not logged)
[CPU] #NM at 00A7:004512D7
[CPU] #NM at 00A7:0023D5A2
[CPU] #NM at 00A7:004512D7 (later ones here not logged)
[CPU] #NM at 00A7:0023D5A2 (later ones here not logged)
Reply 143 of 157, by Dividebysandwich
hail-to-the-ryzen wrote on 2026-10-17, 16:32:
You actually stumbled over some of my original (hand-written) FPU code from last year. In my defense, I was writing these instructions off of the book and the FCOM and FCOMP aliases are undocumented. Looking into how dosbox-staging helped. Yet another reminder how just how much knowledge is in dosbox that isn't documented anywhere else.
Reply 144 of 157, by hail-to-the-ryzen
Your work is appreciated on both fronts! The logging in both software is insightful and simple to parse, along with the powerful debugger and extensive unit tests that are engineered into your emulator. For testing the error, I rebuilt the binary from source, including cross-compiler (v14.2.0), sdl library, related dependencies, and the code for the port itself which is definitely robust. That procedure is reasonably documented but the various versions of each piece together make reproducibility more of an ideal than practice. However, this helped to confirm this above corner case and its sensitivity to number precision. Your unit tests will certainly self-document these above cases and are as invaluable as the formalized commits. As an aside, there is also another interesting base of code here: https://github.com/cyanbun96/qrustyquake. This may be adaptable to a similar pipeline as this above vesa-based port, but it may require a good bit of work on memory and performance constraints. Maybe it is simpler to backport its increased compatibility commits to an existing dos-based port, if only to see the influence of extending the software renderer on the frame rate.
Reply 145 of 157, by Dividebysandwich
Rust-DOS v1.7.5 has been released -> https://github.com/dividebysandwich/rust-dos/ … ases/tag/v1.7.5
3dfx Voodoo3 and Banshee
Finally, Voodoo 3 emulation! Simply set `machine=svga_voodoo3` or `machine=svga_banshee` . With 3dfx's Voodoo3 driver on Windows 98 SE you get the accelerated desktop, Glide, Direct3D and OpenGL through the ICD. Windows will correctly discover a Plug and Play monitor thanks to an emulated EDID, and the vertical retrace interrupt is there too. Thanks to @kibertoad for this one!
Note: Direct3D on the Voodoo3 needs DirectX 7 or later, as mentioned in the driver's readme. Windows 98 SE comes with 6.1, so install `dx70eng.exe` first. Games that ship 3dfx's MiniGL as `opengl32.dll` in their own folder need that file removed to use the ICD.
ATI 3D RAGE and 3D RAGE II
`machine=svga_ati_3drage` and `machine=svga_ati_3drage2` give you ATI's mach64 GT and GT-B, with the 2D draw engine, 3D triangles, the scaler and the video overlay. Windows 98's own driver runs the desktop, DirectDraw and Direct3D, and Wipeout for 3D Rage (the game ATI bundled with the card) runs through ATI3DCIF.
PowerVR PCX1
Next to the PCX2, there's now `powervr=pcx1` for the first PowerVR chip (VideoLogic Apocalypse 3D), so games with a PCX1-only version, like Tomb Raider's TOMBPCX1.EXE, now work too.
Vérité RISC emulation
Rust-DOS now emulates the Rendition Vérité's RISC processor, and this is the new default (`verite_risc=lle`). Instead of recreating the microcode's commands, rust-dos now runs the card's actual microcode, so games that bring their own, such as CGL titles like Battle Arena Toshinden, Rebel Moon, Flight Unlimited and Hi-Octane, now work alongside Tomb Raider and vQuake. Windows 95 also runs with both Rendition drivers. `verite_risc=hle` is still available in case you need the HLE-only emulation.
Rat Commander
Have a fresh installation of Rust-DOS but no Norton Commander at hand?
Type `RC` at the prompt for Rat Commander, a classic 2-panel file manager with the most importanat features built-in: marking, copy, move, rename, delete, view, edit, menus and mouse support. It can even work with `.ZIP` archives.
More accurate FPU
A series of fixes makes the FPU behave more like the real chip in edge cases: infinities, NaNs and overflow in FADD/FSUB, FPREM/FPREM1 quotient bits, FYL2X of 0 and negative values, FSCALE, FXTRACT, FCHS, out-of-range trig, and several register mixups in FCOM/FUCOM/FXCH. The recompiler now also translates CMOVcc, FSQRT and FIDIV/FIDIVR, and instructions that cross into the next page.
Windows 95/98 system image guide
There's a new guide, [docs/win9x-howto.md](https://github.com/dividebysandwich/rust-dos/ … /win9x-howto.md), that walks you through making a Windows 95 or 98 hard disk image and using it with game packages: as a desktop of its own, with games that run from a folder, and with games that have to be installed.
* Count IDE data port transfers as disk I/O for cycles=auto by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/128
* cycles=auto: give a program that keeps Windows busy all the host has by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/130
* Emulate the 3dfx Voodoo3 and Banshee, with 3D, EDID and the retrace interrupt by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/131
* Translate CMOVcc, FSQRT and FIDIV/FIDIVR by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/134
* Translate instructions that run on into the next page by @kibertoad in https://github.com/dividebysandwich/rust-dos/pull/135
* DOSBox configuration imports: rust-dos's own settings in the file now win over the imported ones, DOSBox's S3 is kept and `[rust-dos] machine=` is honored, the prompt says when a game has ended and its drives are back, and the libretro save folder is no longer nested (#129)
* The Windows 95 shutdown message now shows correctly when Windows leaves the screen in a graphics mode
* A windowed DOS box on the Voodoo3/Banshee desktop no longer switches the desktop off
* PCI cards can now share IRQ lines
* FindFirst only returns `.` and `..` when the search asks for directories
Reply 146 of 157, by hail-to-the-ryzen
Thank you. I ported qrustyquake to DOS via SDL3. It depends on several minor code edits, such as in the video output so the pixel format is correct. It works in a variant of dosbox-x, including the Arcane Dimensions mod (latest version). However, the performance is slow where the advanced feature set is active, while vanilla Quake runs better. It also runs in rust-dos v1.75, but not with the simpler AD mod maps. I believe the heap allocation is not sufficient. There are a few causes for this, including restrictions for accuracy in emulation, but I included an abbreviated log if it is of interest in the future (rust-dos is currently adding emulation that would support qrustyquake for win32 anyways, so this dos port has no advantage here). I also think the dos port has less compatibility with DOS era systems, so it is mainly for testing the advanced features and performance in vesa/32bpp. I also can post details on the patch which is highly experimental at this time. I am currently testing on why the dpmi provider, cwsdpmi (I also tested hdpmi32), is not able to allocate memory above a 32mb level in this setup. I have already tested various combinations of the emulator parameters, too.
Log:
[CPU] #PF(0006) at 0087:000003C5 CR2=00401800
[CPU] #PF(0006) at 0087:00000318 CR2=00800000
[CPU] #PF(0006) at 0087:00000318 CR2=00C00000
[CPU] #PF(0006) at 0087:00000318 CR2=01000000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:00001BDD CR2=0135ADF4
[CPU] #NM at 00A7:001FD544
[CPU] #PF(0006) at 00A7:001F7244 CR2=0135B370
[CPU] #PF(0006) at 00A7:001F7244 CR2=0135F3C8
[CPU] #PF(0006) at 00A7:001F5255 CR2=01356C70
[CPU] #PF(0006) at 00A7:00202EE1 CR2=0135445C
[CPU] #PF(0006) at 00A7:001F7244 CR2=0145F810 (later ones here not logged)
[CPU] #PF(0006) at 00A7:00202EE1 CR2=0135847C
[CPU] #PF(0006) at 00A7:001F724F CR2=02364000
[CPU] #NM at 00A7:000B07D6
[CPU] #NM at 00A7:0011BA1B
[CPU] #NM at 00A7:0011C410
[CPU] #NM at 00A7:000933FB
[CPU] #NM at 00A7:0011C410 (later ones here not logged)
[CPU] #NM at 00A7:00093400
[CPU] #NM at 00A7:001F4004
[CPU] #PF(0006) at 00A7:00010C6E CR2=01359C5C
[CPU] #PF(0006) at 00A7:00202EE1 CR2=013573FC (later ones here not logged)
[CPU] #PF(0006) at 00A7:0000B86C CR2=01355C40
[CPU] #PF(0006) at 00A7:0008C8C7 CR2=01360000
[CPU] #PF(0006) at 00A7:0008C8C7 CR2=01361000
[CPU] #PF(0006) at 00A7:0008C8C7 CR2=01362000 (later ones here not logged)
[CPU] #NM at 00A7:001F8266
[CPU] #PF(0006) at 00A7:00088861 CR2=0236F000
[CPU] #PF(0006) at 00A7:00088861 CR2=02370000
[CPU] #PF(0006) at 00A7:00088861 CR2=02371000 (later ones here not logged)
[CPU] #NM at 00A7:00088898
[CPU] #PF(0006) at 00A7:00088905 CR2=02386000
[CPU] #PF(0006) at 00A7:00088905 CR2=02387000
[CPU] #PF(0006) at 00A7:00088905 CR2=02388000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:0000B54C CR2=0133A9B8
[CPU] #PF(0006) at 00A7:0020DB5A CR2=01339F70
[CPU] #PF(0006) at 00A7:001FF721 CR2=02394000
[CPU] #PF(0006) at 00A7:001FF721 CR2=02395000
[CPU] #PF(0006) at 00A7:001FF721 CR2=02396000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:0008C3C4 CR2=01DB3000
[CPU] #NM at 00A7:00077D4E
[CPU] #PF(0006) at 00A7:00077E69 CR2=01EAD000
[CPU] #PF(0006) at 00A7:00077E69 CR2=01EAE000
[CPU] #PF(0006) at 00A7:00077E69 CR2=01EAF000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:0008C3C4 CR2=02029000
[CPU] #NM at 00A7:00017613
[CPU] #NM at 00A7:00066B27
[CPU] #PF(0006) at 00A7:00066C39 CR2=029C5000
[CPU] #NM at 00A7:00066C39
[CPU] #PF(0006) at 00A7:00066C44 CR2=029C6000
[CPU] #NM at 00A7:00066C44
[CPU] #NM at 00A7:000060E4
[CPU] #NM at 00A7:000748A4
[CPU] #NM at 00A7:000140A8
[CPU] #PF(0006) at 00A7:0006449F CR2=012BAB78
[CPU] #NM at 00A7:000644F5
[CPU] #NM at 00A7:00063F3F
[CPU] #PF(0006) at 00A7:000640B3 CR2=012BB000
[CPU] #PF(0006) at 00A7:000639A8 CR2=012BC000
[CPU] #NM at 00A7:00063F3F (later ones here not logged)
[CPU] #PF(0006) at 00A7:0006399B CR2=012BD000
[CPU] #PF(0006) at 00A7:0006398F CR2=012BE000
[CPU] #PF(0006) at 00A7:000639B1 CR2=012BF000
[CPU] #PF(0006) at 00A7:000639AE CR2=012C0000
[CPU] #PF(0006) at 00A7:000639A8 CR2=012C1000
[CPU] #PF(0006) at 00A7:0006399B CR2=012C2000
[CPU] #NM at 00A7:000163ED
[CPU] #PF(0006) at 00A7:0005F922 CR2=0132FE80
[CPU] #NM at 00A7:0005E24D
[CPU] #PF(0006) at 00A7:0001A6A3 CR2=01327E1C
[CPU] #NM at 00A7:000190E1
[CPU] #PF(0006) at 00A7:0005E21E CR2=01330000
[CPU] #NM at 00A7:0005E21E
[CPU] #PF(0006) at 00A7:0001944A CR2=01328018
[CPU] #NM at 00A7:00019588
[CPU] #NM at 00A7:0002F584
[CPU] #PF(0006) at 00A7:00015074 CR2=02546038
[CPU] #PF(0006) at 00A7:00015074 CR2=02547078
[CPU] #PF(0006) at 00A7:00015074 CR2=025480B8 (later ones here not logged)
[CPU] #NM at 00A7:0002F601
[CPU] #NM at 00A7:0002F584 (later ones here not logged)
[CPU] #PF(0006) at 00A7:0017B2E1 CR2=024E8000
[CPU] #PF(0006) at 00A7:0017B2E1 CR2=024E9000
[CPU] #PF(0006) at 00A7:0017B2E1 CR2=024EA000 (later ones here not logged)
[CPU] #PF(0004) at 00A7:0017C047 CR2=02551000
[CPU] #PF(0004) at 00A7:0017C047 CR2=02552000
[CPU] #PF(0004) at 00A7:0017C047 CR2=02553000 (later ones here not logged)
[CPU] #NM at 00A7:000DCA6C
[CPU] #NM at 00A7:001F07A6
[CPU] #NM at 00A7:00085908
[CPU] #PF(0006) at 00A7:000859C0 CR2=02536000
[CPU] #PF(0006) at 00A7:000859C0 CR2=02537000
[CPU] #PF(0006) at 00A7:000859C0 CR2=02538000 (later ones here not logged)
[CPU] #PF(0006) at 00A7:00085A10 CR2=02556000
[CPU] #PF(0006) at 00A7:00085A10 CR2=02557000
[CPU] #PF(0006) at 00A7:00085A10 CR2=02558000 (later ones here not logged)
[CPU] #NM at 00A7:0002399F
[CPU] #NM at 00A7:000B36F4
[CPU] #NM at 00A7:001EF9FB
[CPU] #NM at 00A7:000163ED (later ones here not logged)
[CPU] #NM at 00A7:00085908 (later ones here not logged)
[CPU] #NM at 00A7:001EF9FB (later ones here not logged)
[CPU] #NM at 00A7:0001E902
[CPU] #NM at 00A7:000644F5 (later ones here not logged)
[CPU] #NM at 00A7:0007821F
[CPU] #NM at 00A7:000DCA6C (later ones here not logged)
[CPU] #NM at 00A7:00071F90
[CPU] #NM at 00A7:00087977
[CPU] #NM at 00A7:0001E84A
[CPU] #NM at 00A7:00060A01
[CPU] #NM at 00A7:00072207
[CPU] #PF(0004) at 00A7:000856A8 CR2=02565110
[CPU] #PF(0004) at 00A7:000856A8 CR2=02566038
[CPU] #PF(0004) at 00A7:000856A8 CR2=025670E4 (later ones here not logged)
[CPU] #NM at 00A7:0001E902 (later ones here not logged)
[CPU] #NM at 00A7:00060ACB
[CPU] #NM at 00A7:0001EAB3
[CPU] #NM at 00A7:00062B17
[CPU] #NM at 00A7:00078238
[CPU] #NM at 00A7:00060CA0
[CPU] #NM at 00A7:00072727
[CPU] #NM at 00A7:0007824A
[CPU] #NM at 00A7:00060F40
[CPU] #NM at 00A7:0001FB5A
[CPU] #NM at 00A7:00063F60
[CPU] #NM at 00A7:001F0FAE
[CPU] #NM at 00A7:00060D24
[CPU] #NM at 00A7:00087770
[CPU] #NM at 00A7:000624E4
[CPU] #NM at 00A7:00072207 (later ones here not logged)
[CPU] #NM at 00A7:0001FB5A (later ones here not logged)
[CPU] #NM at 00A7:0001E828
[CPU] #NM at 00A7:000785A7
[CPU] #NM at 00A7:0002F601 (later ones here not logged)
[CPU] #NM at 00A7:00058E57
[CPU] #NM at 00A7:0007CE18
[CPU] #NM at 00A7:002042CB (later ones here not logged)
[CPU] #NM at 00A7:0009D883 (later ones here not logged)
[CPU] #NM at 00A7:00218AE4
[CPU] #NM at 00A7:000878B3
[CPU] #NM at 00A7:00011732
[CPU] #NM at 00A7:0007825C
[CPU] #NM at 00A7:000878BC
[CPU] #NM at 00A7:000239E5
[CPU] #NM at 00A7:000EA0C0
[CPU] #NM at 00A7:00078238 (later ones here not logged)
[CPU] #NM at 00A7:00218AE4 (later ones here not logged)
[CPU] #NM at 00A7:00074833
[CPU] #NM at 00A7:00078254
[CPU] #NM at 00A7:00218C4F
[CPU] #NM at 00A7:0007824C
[CPU] #NM at 00A7:001F0FAE (later ones here not logged)
[CPU] #NM at 00A7:00078257
[CPU] #NM at 00A7:00218C4F (later ones here not logged)
[CPU] #NM at 00A7:00011732 (later ones here not logged)
[CPU] #NM at 00A7:00078242
[CPU] #NM at 00A7:0007821F (later ones here not logged)
[CPU] #NM at 00A7:0007824F
[CPU] #NM at 00A7:0002399F (later ones here not logged)
[CPU] #NM at 00A7:000781B2
[CPU] #NM at 00A7:000877E0
[CPU] #NM at 00A7:00078242 (later ones here not logged)
[CPU] #NM at 00A7:0007CCEF
[BIOS] Switch to VESA mode 112h (640x480, 32 bits per pixel)
[S3] Back to the VGA's Graphics320x200
[BIOS] Switch to Text Mode (80x25 Color)
[CPU] #NM at 00A7:001FF6B1
[DOS] Program Terminated (INT 21h, 4Ch). ExitCode=01
Reply 147 of 157, by kibertoad
@dividebysandwich is it possible to reach out to you via twitter, email or something else a bit more direct than GH issues or forum? Wanted to sync a bit about the rust-dos priorities and direction.
Reply 148 of 157, by jh80
I finally had time to test out the "auto speed target" feature - it's fantastic!
I tested Heavy Gear in Windows 95 with Voodoo 1 graphics.
Heavy Gear seems to run correctly at around 30-35 fps. Setting the auto speed target to that and viewing the mech's running animation really makes it obvious. It's great that Rust-DOS lets you adjust the target fps and immediately see how it looks.
The game otherwise played well, as well. I always had trouble with it in PCem because the LOD on the Voodoo graphics was weird and ground textures wouldn't display correctly, but they looked normal in Rust-DOS.
Reply 149 of 157, by hail-to-the-ryzen
For testing in rust-dos, I prepared a shell script (WSL2 and Ubuntu) to build qrustyquake for DOS (tested in emulation). For this case, it shows that rust-dos is now on parity with dosbox-x. The script and a test-only binary are attached for development and reference only. User accepts responsibility for their use.
It should run where RAM is 32mb or 64mb in the vanilla Quake map sets, but the small to medium set of the modification Arcane Dimensions (latest) maps and the majority of maps where the bsp file size is ~10mb in Alkaline (v1.2) will load but depend on additional RAM/heapsize (test values 192/128mb or 256/192mb in the emulator); in this case: `qrusty.exe -heapsize 128 -game ad +map start`. See compatibility list as a rough reference guide at the official qrustyquake repository.
The binary relies on a file to load a dpmi provider: cwsdpmi.exe (`cwsdpmi -s- -p`, for no swap file and as resident provider) or test with hdpmi32.exe (`hdpmi32 -r`, for resident provider).
Reply 150 of 157, by hail-to-the-ryzen
This updated version of the client from above is for further testing of Rust-DOS, including its built-in dpmi provider which performs well. The larger maps, such as ad_tears and alk_tellus, require additional RAM (384+MB) to load and have high CPU requirements, so the following lines may help:
cwsdpmi -s- -p (if internal dpmi provider is off)
qrusty.exe -heapsize 256 -game ad
A log file should be created if an error occurs (QQERR.LOG). Rust-DOS also has excellent support for cd audio. So, for further testing, this archive includes a sample helper script to form a cd audio image from file-based music.
Edit: Updated the code to v3. Fix to music script and updates to the shell script, including in sound playback. May test for lower sound latency by lowering value of _snd_mixahead to 0.04. Note that there also may be a short screen pause near the start position of particular maps (alk_geo; udob mod start map).
Reply 151 of 157, by Dividebysandwich
FYI, we released v1.8.1 recently! https://github.com/dividebysandwich/rust-dos/ … ases/tag/v1.8.1
kibertoad has been busy and Rust-DOS now features experimental built-in Windows support similar to WINE. The idea is that you no longer have to set up a windows installation, instead your programs and games "just run".
Check out https://github.com/dividebysandwich/rust-dos/ … d#windows-games for more details.
Also, there's now an Almanac of game settings. You can quickly and easily search for and submit working configuration parameters for every game. For example if a game requires a Pentium CPU and a Voodoo card, configure your game and then upload your settings. Or search for the game you want to play and have the settings applied automatically.
The almanac can be found at https://almanac.rust-dos.com
Reply 152 of 157, by hail-to-the-ryzen
I have one issue. Qrustyquake/DOS starts in 320x200 mode, but subsequent video mode changes result in unmapped writes. However, it works in DOSBox-X.
Log of the PF(0006) lines:
[BIOS] Switch to VESA mode 100h (640x400, 8 bits per pixel)
[CPU] #NM at 00A7:000DDEE9
[CPU] #NM at 00A7:00088105
[CPU] #PF(0006) at 00A7:000147FE CR2=0FB615E0
[CPU] #PF(0006) at 00A7:000147FE CR2=0FB62264
[CPU] #PF(0006) at 00A7:000147FE CR2=0FB63160.
It may be related to the state of CR0.TS/EM after use of int 10h and the dpmi function 0x0800 for memory mapping.
In addition, below is a patched qrustyquake for dos with a set of recent upstream commits, along with Snes9x built to target Windows 95a and a Pentium-Pro. This port of Snes9x was used for testing the wonderful addition of win32 emulation in Rust-DOS, which showed excellent compatibility here. This archive also includes two scripts to build this port, one for building a cross-compiler in WSL2/Ubuntu to target i586/Win95, and the other script to run afterwards for patching and building snes9x.
Reply 153 of 157, by kibertoad
@hail-to-the-ryzen thank you, I'll take a look!
Reply 154 of 157, by kibertoad
Thanks for the report and the files. The black screen after the mode change is fixed in https://github.com/dividebysandwich/rust-dos/pull/556, which is merged, so it's in the next build.
The #NM and #PF lines in the log aren't errors. CWSDPMI fills in memory as the program touches it (demand paging) and switches the FPU in only on first use, so those exceptions come with every DJGPP program. CR0.TS/EM and DPMI 0800h behave as they should: the 0800h call maps the linear framebuffer, and the writes the log shows land in it.
What actually goes wrong is how SDL picks the mode. When Qrustyquake asks for 640x400, SDL3's DOS backend looks through the VESA mode list. rust-dos only offered mode 100h, 640x400 at 8 bits per pixel. SDL chose it and drew through a palette it never set, so it stayed all black. DOSBox-X also lists mode 213h, 640x400 at 32 bits per pixel, an OEM mode some real cards had (the Diamond Stealth64 Video, for example). SDL prefers it, so the picture shows there.
rust-dos now lists mode 213h too, on the default SVGA adapter, so SDL picks it the same way.
One more thing: Qrustyquake needs more memory than rust-dos gives by default, or it stops with "could not allocate the heap". Set memsize=64 (or more) under [emulator] in your config.
Reply 155 of 157, by hail-to-the-ryzen
@kibertoad thank you for all the help and patchwork! I definitely appreciate your thoughtfulness and expertise on uncovering the bug in qrusty and for the accommodation in addition of the 32bpp video mode. We resolved the palette initialization bug alongside the reworking of the video modes in DOS (tested in rust-dos). Attached is an update, with several upstream commits, too. Consequently, with these latest changes, loading some maps, such as the start map in the udob mod, may sometimes lead to a short to medium delay in screen initialization.
We are also thankful for rust-dos and its compatibility across so many computer systems. The win32 emulation is great and I hope to spend more time now in using this new feature!
I tested again a few of the vanilla Quake maps and, as you found, they in fact require 64mb RAM. We can try to lower this requirement, on request. The non-vanilla large maps require substantially more memory to load as expected.
Edit: Added v6. Improvement to delay time in loading some maps, along with clean up of unused/defunct code and a few recent upstream commits. Edit #2: Replaced v6 with v7. Further improvement to the handling of mouse motion after a video mode change and a table-based optimization for performance in lightmapping surfaces.
Reply 156 of 157, by willow
Good morning
is it possible to add voodoo 3 support ?
It would be usefull for news 3dfx patch (screamer 1, Hi octane, terminal velocity) released by tgamesFR Screamer 3DFX Voodoo 3 Patch (2026) but these patch detect only voodoo 3 and not voodoo 2 (I have tried the startH.exe patched and It runs in software mode with dos_rust and in 3dfx with pcem17 with voodoo 3 card emulated used).
Thanks by advance.
Reply 157 of 157, by xttx
It's already there! Works just perfect!
If it start in software mode - check the emulated video card in Settings -> Emulator. Pay attention that Voodoo 3 is not an add-on card (which is set with "3DFX Voodoo Graphics" option), but a standalone card (set with "Video Card" option).
The attachment rust-dos_screenshot_2026-11-08_18-26-47-B.jpg is no longer available
