First post, by theelf
- Oldbie
Hi all,
I am writing a small window manager for DOS, for 286 ,i would like to use extended memory for some things
I have some questions for you guys im not sure
1. Does HIMEM.SYS use LOADALL (0F 05) on a 286 for the XMS move function, or does it use INT 15h AH=87h?
2. Is LOADALL really faster than INT 15h AH=87h for block copies?
3. Is it a bad idea to use LOADALL myself with HIMEM loaded? I think I would be touching memory that HIMEM has already given to other programs, so I plan to use the XMS API instead. Is that the right way?
My plan is to measure XMS move against my own LOADALL test, but I prefer to ask before I break something.
Thanks!
