First post, by Pr1ha
Hi everyone,
I'd like to share a small project that improves Voodoo Rush performance in Carmageddon on low-end Pentium 1-class machines when the game is started with the -vrush switch.
I noticed that on Voodoo Rush, if the game is started with the -vgraphics switch, performance becomes much higher, but this causes heavy flicker of the interface, since that switch is intended for Voodoo1 only.
I made a patch for the DOS version of Carmageddon (3dfx/Glide build) that solves this problem. It is applied to your own copy of the game, CARMAV.EXE, and creates a new modified file, CARMAVR.EXE.
The patch changes the behaviour of the standard -vrush path and increases its performance, without causing interface flicker. HUD elements may disappear, become darker or lighter depending on what is displayed on the screen, but it looks much better 😀 Tested on a Voodoo Rush ViewTOP 3D VULCAN and AMD K5 PR166.
The attachment carma.jpg is no longer available
Description of the fix:
The attachment img_patch.png is no longer available
The attachment img_flow.png is no longer available
USAGE:
Put CARMAV.EXE, MAKEVR.BAT and PATCH.COM into the game directory.
Run MAKEVR - it creates CARMAVR.EXE (the original file is never modified).
Start CARMAVR.EXE -vrush (or without any key).
Visit https://github.com/Pr1ha/carmageddon-voodoo-rush-patch to learn more about how it is done.
I will attach the patch file. I hope you find this useful!
The attachment CARMAVR.ZIP is no longer available
Reply 1 of 1, by mgtroyas
Great work, I remember getting the 2D elements flickering many times when trying to run it in 3dfx mode under patched DosBOX builds and a glide wrapper.
