WM 0.10 - a window manager for DOS XT/286
Reply 20 of 34, by zyzzle
theelf wrote on 2026-11-09, 11:38:
Please decompress the zip file to c:\WM
then run setup, then WML.COM
Does it have to be installed to that directory? I want to run it entirely from the root of a ramdrive, no /WM directory. In my case, the ramdrive is D:
Otherwise this looks lean and mean. Perfect. No bloat and very functional. I love it.
Reply 21 of 34, by analog_programmer
Very nice! Your Noname Commander is also a killer app for XTs.
Please revisit your EN translated version of NC and Hoja. If I'm not mistaken, "agenda" is not the English word for "calendar" 😉 I didn't check everything, but noticed this one at first glance.
And I have a question: How to use the menu keyboard shortcuts? The menu is activated through <F9>, but why not <Alt>?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 22 of 34, by theelf
analog_programmer wrote on 2026-11-10, 00:42:
I dont remember used ALT for menu, always F9 in NC, alt was for alternate commands, but maybe yes, if you just press alt with no functions key was going to menu? i need to cheeck NC
If you like this NC, just use for some days, tellme all the strange stuff you find, or whatever you want better and i will fix it. later when i had time i will put code in github
I have too many old projects Ive made in my life that I never published, but I think they are not worth letting die on my HD
Reply 23 of 34, by analog_programmer
theelf wrote on 2026-11-10, 00:57:
Opps, <Alt> is occupied for the alternative <Fx> functions activation. But <F9> for menu activation is super inconvenient and close to <F10>, which is for direct exit. What if <Shift> is for alternative <Fx> functions activation and <Alt> for the menu activation/shortcuts?
Your Noname Commander is instantly my new favorite "DOS Commander" for XTs 😉 If you release the source code anywhere with public access, we could do such tweaks and bugfixes without bothering you to do it for us.
Reply 24 of 34, by theelf
analog_programmer wrote on 2026-11-10, 01:06:
Opps, <Alt> is occupied for the alternative <Fx> functions activation. But <F9> for menu activation is super inconvenient and cl […]
Ok, i will upload to github no problem
here is with ALT for menu
The attachment nc.zip is no longer available
Reply 25 of 34, by analog_programmer
theelf wrote on 2026-11-10, 01:31:
Thanks for your effort, my friend, but this version is a keyboard shortcuts mess and not what I tried to describe. I'll just wait for the source code release.
Reply 26 of 34, by theelf
analog_programmer wrote on 2026-11-10, 09:07:
I tested and do exactly same behavior as volkov for example, what is a mess?
Like i said before i think norton use only f9 for menu, but volkov for example add alt like i did, and is not a mess
Just tellme what you found strange and i will change because will never be a next version, this is software i use just for me
Reply 27 of 34, by analog_programmer
theelf wrote on 2026-11-10, 09:13:
There is no key for alternative <Fx> functions activation - I suggest <Shift> for this, so these combos to become <Shift>+<Fx>. <Alt> is now overlapping <F9>, but only partially. <Alt> activates the menu, but doesn't deactivates it - I suggest <F9> to be reassigned to another useful function, and <Alt> to inherit the original <F9> function for activating the menu + menu shortcuts like <Alt>+<L>, <Alt>+<R>, <Alt>+<F>, <Alt>+<C>, etc.... Also these <Alt>+<L>, <Alt>+<R>, <Alt>+<F>, <Alt>+<C>, etc... combos do not work at tall.
Do not waist your time in "fixing" this. I will adjust those key-shortcut combos for myself, when the source code is available.
Reply 28 of 34, by theelf
analog_programmer wrote on 2026-11-10, 09:30:
morning, OK, I get it, but then how would you do the quick search by name? Right now that is Alt+letter, and those letters would open menus
For me doing you a alternate keys are easy, 10minutes of my life, because in code is just change some variables, but you will need to bring me all alternatives one by one
Reply 29 of 34, by analog_programmer
theelf wrote on 2026-11-10, 09:51:
For example <F9>+<letter> will remain active only for this quick search function and this will be the "new" old assignment for <F9> function.
It is not your fault, it's difficult to explain what exactly I have in mind. I could change/add some key scancodes or ASCII codes for triggering the key assigned functions, if I have the source code. So, do not waste these 10 minutes again 😉
Back to the main topic.
What's the purpose of WM256.EXE? Is it needed for 256-color VESA mode?
What's the purpose of WORKSPC.NEW? WORKSPC.NEW very much resembles WORKSPC.INI, so is it really needed for anything?
Do we need to keep SETUP.EXE after the initial file renaming?
Do we need to keep the empty ICONS folder?
Reply 30 of 34, by theelf
analog_programmer wrote on 2026-11-10, 10:07:
For example <F9>+<letter> will remain active only for this quick search function and this will be the "new" old assignment for < […]
here you are, enjoy doing strange key combinations
https://github.com/TheElf01/NonameCommander/tree/main
About WM, the only REALLY tested mode is 16 colores, in fact i left 256 color mode just for future testing, WM256.EXE is Wm in 256 color modes
I need to split because 256color mode need more ram, even is not used
We are talking about desktop! even in 16color mode fullscreen can be 256 colors, like chips in fullcreen, video player, geiss effect, or paint in both modes
WORKSPC.NEW is just a original copy of WORKSPC file, and if new things are add there, will update the INI, i made in case i want to do a "installer" for a software, but not write ini directly. You can erase if your ini is alreeady working or you like do change stuff by hand
Reply 31 of 34, by analog_programmer
Thank you very much for the NC source code!
P.S. A minor bug in UTILS.C - leftover form ES to EN translation:
write(1, "UTILS -agenda | -ascii | -diff file1 file2\r\n", 50);
If we do not want to "print" 6 bytes (characters) with garbage at the end of the line, this line should be:
write(1, "UTILS -agenda | -ascii | -diff file1 file2\r\n", 44);
And there's even more critical bug, which messes correct hex and bin ASCII codes values showing:
        case 'u':
v = lng ? va_arg(ap, unsigned long) : (unsigned long)va_arg(ap, unsigned);
num:
The fix:
        case 'u':
goto num;
case 'x':
case 'X':
base = 16;
num:
Reply 32 of 34, by OzzFan
I really like your UI design. It looks great!
Hobbyist Developer : https://www.shelteringoak.com/du/
Reply 33 of 34, by theelf
Guys!! next version i port the covox driver from my VGMDOS player, not only wav files... midi too!!! i made a small midi software player long time ago, and ported very easily to WM
The attachment wm_000.raw1.png is no longer available
analog_programmer wrote on 2026-11-10, 11:07:
Thank you very much for the NC source code! […]
        case 'u':
num:
The fix:
        case 'u':
goto num;
case 'x':
case 'X':
base = 16;
num:
Thanks! i upload the fixeed nc to github https://github.com/TheElf01/NonameCommander/r … eases/tag/v1.02
OzzFan wrote on Yesterday, 23:39:
thanks a lot! im a big fan and long time user of OS/2!
Reply 34 of 34, by Cyberdyne
Best version of tetris. Looks like Windows 3.1 version, but controls are smoother.
Solitaire is so wooden and user unfriendly.
256 color mode just hangs with black screen with blinking cursor. (P166 MMX with S3 Virge)
