Reply 32100 of 32115, by PTherapist
Today I set up and tested 8 retro gaming PCs, covering DOS & Windows gaming from 1993-2010, ready for a little LAN Party with friends this week.
Aside from 1 PC with a dead BIOS battery that required the BIOS re-configuring, everything else was absolutely smooth sailing. All working just as good as they did when I last used them all in January.
I did a quick test run with all 8 PCs running at once, so everything is good to go.
Reply 32101 of 32115, by lti
I was messing around with hard drives again.
I got my Windows XP system to boot again, but the hard drive is toast. I learned that the hard drive's firmware stores the reallocated sector count as a 10-bit value, and it's the first bad Toshiba drive I've seen that actually shows failing SMART status instead of "warning" (or suddenly clicking), including newer drives that are capable of logging more than 1023 bad sectors. I don't think that thing is worth putting a decent hard drive in because of its performance.
I was also making an image of a different drive, and the power cable that came with my IDE to USB converter is flaky again. The "Molex" connector (which is actually an Amp connector that Molex never even made as a second source) is an IDC type, and the wire is counterfeit "18AWG" that looks more like 26AWG (along with being that mystery high-resistance wire that's weakly attracted to a magnet and apparently only I have seen before). The connector on the other end is a JST XH that won't accept genuine 18AWG wire anyway. I might want to replace the entire converter because it doesn't read SMART data or pass a lot of ATA commands through to the drive.
Reply 32102 of 32115, by florian3
Dumping Waveblasters
Reply 32103 of 32115, by BitWrangler
lti wrote on Yesterday, 04:42:
I have seen that shit. Seems to actually be steel cores plated with copper.
Reply 32104 of 32115, by zapbuzz
florian3 wrote on Yesterday, 14:01:
now that's sensible that they are getting rare
if i had wads of cash I’d do that too keep a copy for a homebrew waveblaster, sell the donor waveblaster and post a copy of the dump on archive for good measure!
especially the Yamaha ones they are so expensive and rare now
Reply 32105 of 32115, by florian3
zapbuzz wrote on Yesterday, 14:44:
now that's sensible that they are getting rare if i had wads of cash I’d do that too keep a copy for a homebrew waveblaster, se […]
After the CT1910 Waveblaster 2 I am now dumping the CT1900. Plan is to support it on my homebrew daughterboard.
Reply 32106 of 32115, by rasz_pl
Im guesstimating $5 pico 2 would be fast enough for software emulation of a waveblaster.
Reply 32107 of 32115, by lti
BitWrangler wrote on Yesterday, 14:32:
There are two kinds that I've seen. Copper-clad steel is pretty well-known by now (and a legitimate material for certain types of cables, just not power), but there's also stuff that's a consistent oxidized old-penny color all the way through (not plated) and has higher resistance than steel. I guess I shouldn't say that nobody has seen it before because there were a bunch of videos about AC (mains) power cords and outlet strips made out of that stuff 10-15 years ago. The resistance across the cord was about 4 ohms, and none of them had the ground pin connected either.
I don't have a precision meter to properly measure wire resistance, but my multimeter shows 0.3-0.4 ohms from the JST crimps to the wires poking out of the not-Molex IDC contacts (6cm of wire and after canceling out the lead resistance), and all four IDC connections appear to be bad.
Reply 32108 of 32115, by Shader_BiH
Tested my Leadtek FX 5900 XT. Flashed it to prevent bit rott. And a breif post test with 3DMark and NFSU.
Reply 32109 of 32115, by darry
rasz_pl wrote on Yesterday, 16:04:
WaveBlaster 2 has an EMU8000 (32 channel mixing + fx engine) and a 68000 variant, AFAICR . That feels like it might a lot to ask of that Pi with two active cores at 150MHz, but that's just my highly unqualified opinion guess.
Reply 32110 of 32115, by kingcake
I bought a generic PCIe NIC from Ali Express and came in a knockoff Intel CPU box. Made me laugh once I realized what it reminded me of. Now it sits on top of my NIB Pentium.
The attachment IMG_7694.jpeg is no longer available
Reply 32111 of 32115, by rasz_pl
darry wrote on Today, 01:16:
rp2350 supports arm DSP Extension (simd SMLAD QADD16 SADD16 SSAT) and overclocks to 300MHz no problem. At stock 150MHz you have ~3000 clock cycles per output smaple at 48 kHz, twice when OCed, twice again when using both cores. Projects doing heavy audio on tiny pico https://github.com/WeebLabs/DSPi https://github.com/michi71/picovintagesynthcollection. Second one is already running Roland CM-32L on pico
https://github.com/Michi71/PicoVintageSynthCo … aceCM/README.md
Reply 32112 of 32115, by H3nrik V!
Did a repair job on my Targa branded Logitech 3 button serial mouse.
Left mouse button didn't work. It "beeped" out fine with the multimeter, however, it seemed that the signal didn't make it to the controller IC.
It was the "daisy chained" ground going across all microswitches, that was interrupted at the middle button. Hard to see in the image, but the solderpad didnt stick to the PCB, and the track on both sides were torn. (The hole in the solder blob is from my probe) So probably the middle mouse button didn't work either.
Adding a couple of images of the mouse. It may seem a little bit yellowed 🤣
Reply 32113 of 32115, by DaveDDS
H3nrik V! wrote on Today, 11:32:
Did a repair job on my Targa branded Logitech 3 button serial mouse. ...
Over the years I've had to repair a number of mice (both name brand and cheap ones) where the buttons basically "wore out" and either didn't make reliable contact, or "bounced" sometimes causing double "clicks" where you had intended only one.
These were always "cheap" internal switches, usually board mounted - I replace them with a much better quality board mount unit, sometimes having to modify the board and/or make a mounting bracket.
This almost always changes the "feel" from a mushy, maybe somewhat stiff "click" to a definitely more solid one. I've gotten quite used the "real" feeling!
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 32114 of 32115, by gmaverick2k
The low battery warning at startup was beginning to annoy me on my Yamaha MU90. Opened it up expecting to solder a battery holder (was looking to scavenge a CR2032 battery holder from an old motherboard) but pleasantly surprised battery holder already in place. Ordered a CR2450 to replace dead battery.
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 32115 of 32115, by H3nrik V!
DaveDDS wrote on Today, 12:13:
Over the years I've had to repair a number of mice (both name brand and cheap ones) where the buttons basically "wore out" and e […]
Honestly I thought that was what had happened. I had inteded to swap the middle and left button microswitches, since I use the serial mouse for retro rigs only, where the middle button is rarely used. Measuring revealed the problem was elsewhere, though.
