PowerVR-SGL-Wrapper v0.4.0 for Windows
Reply 60 of 79, by robertmo3
and in case the project accidentally goes out of basic it will just have to add another emulator support 😀
maybe it is worth choosing the right one at the beginning 😀
just thinking 😀
Reply 61 of 79, by willow
robertmo3 wrote on 2026-10-13, 05:40:
just thinking 😀
I don't know why you troll ?
Reply 62 of 79, by robertmo3
you are not using any arguments for pcem.
pcem is using accurate cpu cycles emulation which causes huge slow down
this accurate emulation is not even used in dosbox as it was needed only for some XT 8088 4.77 MHz CGA games
games were designed for this particular 8088 4.77 MHz cpu cause no other cpu speed existed that time.
once more intel cpus with different speeds appeared on the market (for example 8088 8 Mhz) such accuracy was no longer needed
for example Jungle Hunt (1982) needs it to properly display statistic letters colors (it is just a tiny corruption, game is still 100% finishable without it though)
i am not sure if even jungle hunt really needs that. i think just a more precise way to configure cycles in dosbox would be enough. (with fraction cycles)
https://www.mobygames.com/game/133/jungle-king/
even if you don't care about speed it is not eco friendly.
Reply 64 of 79, by willow
robertmo3 wrote on 2026-10-14, 20:46:
crime cities system requirements: https://www.mobygames.com/game/5689/crime-cit … 4/cover-971186/ […]
crime cities
deus ex
https://www.mobygames.com/game/1749/deus-ex/c … 4/cover-177726/
rune
https://www.mobygames.com/game/2662/rune/cove … 4/cover-186935/
For these games powervr wrapper is useless because are direct3d game and best version with direct3d.
Power sgl game are games from 1996 and 1997, perfect for cpu support in pcem.
Reply 66 of 79, by BitWrangler
willow wrote on 2026-10-16, 16:48:
They would be... if Power VR didn't need a lot of Mhz to scale to nice speeds. I think you said that 10 years too soon, because ppl struggling to get PII-400 out of PCem right now as far as I know and they smooth out best at 800 on real hardware.
Reply 67 of 79, by willow
BitWrangler wrote on 2026-10-16, 17:30:
power games in 96/97 worked well with pentium 200 and very well with penitum 2 266 that are cpu well emulated in pcem and well supported with actual cpu.
Reply 68 of 79, by robertmo3
ralonsoj aims at all powervr games, not just 96/97
Reply 69 of 79, by willow
So what? Nobody cares. We won't use the wrapper with PCem if the game requires a CPU that's too powerful. In general, games that use SGL and have a better version with SGL than with other 3D cards are from 1996/1997, not later, so they're perfectly suited to PCem in terms of CPU requirements.
PCem supports 3dfx acceleration, and yet plenty of games don't run on PCem. That doesn't make 3dfx acceleration any less interesting in PCem.
You have a really weird way of thinking that I just can't understand, or, as I said in a previous message, you're just trolling. If that's the case, it's pretty immature.
Reply 70 of 79, by robertmo3
3dfx is supported in dosbox and later qemu support was added as dosbox was not fast enough.
i suggest not making same mistake and saving a lot of work and just ignore pcem and dosbox and add only qemu support instead.
Reply 71 of 79, by willow
dosbox is fast enough for 3dfx dos game and early windows 3dfx game that don't works in native windows with 3dfx wrapper.
For 3dfx windows game, wrapper like nglide and dgvoodoo are present.
For all 3dfx glide game that I played, I have never had to use QEMU. PCem, DOSBox or windows with a wrapper have always been enough for all the games I've played.
I don't understand what you're trying to achieve in this discussion, but the longer it goes on, the more you convince me that you're just looking to troll rather than actually have a discussion.
To begin with, your whole argument is based on the false assumption that PCem is too slow for PowerVR games, which is simply not true for games from 1996 and 1997, for example. Period.
You're entitled to not want a PowerVR wrapper in PCem. That's your problem, not mine or anyone else's.
In the end, ralonsoj is the one who will decide, not you. Otherwise, make your own wrapper and then you'll be free to decide whatever you want. Other than derailing the thread and acting like someone who's deliberately pretending not to understand, you're not contributing anything.
Reply 72 of 79, by robertmo3
dosbox can use nglide and dgvoodoo too. qemu can use dgvoodoo too.
i guess you haven't played redguard or pyl. even qemu is too slow for pyl. they are both dos games.
here you have how rendition verite wrapper works with a 1996 game in dosbox (after a lot of time spent optimizing) (it uses gpu just like nglide and dgvoodoo)
https://youtu.be/fgUwpnWb88A?t=118
i am not insisting on the use of any emulator
i don't mind which ones of them will be used, none or all.
All is fun too of course.
just giving a warning signal to whoever will try to support them so they are not surpriced later.
or course barely working is always better than not working at all.
but if you have one choice only it is usually better to choose the best option 😉
Reply 73 of 79, by robertmo3
some more arguments:
lets say you are only interested in Flight Unlimited (1995).
but it will have corrupted gfx and the only way to fix it will be revealed by fixing a bug in crime cities (2000)
you want someone to struggle with crime cities in pcem to find that bug?
and you have to know that playing in debugging mode needs way more cpu power than simple playing.
Reply 74 of 79, by willow
Arguments that don’t make sense
Reply 75 of 79, by ralonsoj
Hi everyone!
I'm sharing version 0.4.0 of the wrapper. Here's what I've been working on:
  • Ultimate Race 1-track and 3-track → Both games are now fully playable without any major issues. As with everything in these beta releases, though, you may still come across a few glitches here and there. I'm really happy with the results so far, as these games gave me quite a bit of a headache, especially when it came to getting the headlights and streetlights lighting right. I've really enjoyed playing them, to be honest! https://youtu.be/smmovkOZEzk
  • Virtual-On → The big surprise was launching the game and discovering that so many things were already working thanks to the work done in previous versions. There were still a few things that needed tweaking, but it's now in pretty good shape. I recommend trying the bilinear parameter, as it makes quite a noticeable difference in this game. https://youtu.be/iwrR13JMiSQ
  • Nirgends → Getting the videos and dialogue working was pretty straightforward. I'd already done something similar for the Enigma translation, so it was mostly a matter of adapting that work. It now works really well for people like me who don't speak Japanese but still want to enjoy the game. I think most of the gameplay is already implemented, although I haven't had much time to play it... and I'm pretty terrible at it anyway! https://youtu.be/JuqTGTlx3vE
Important: Some games may work without the CD-ROM, while others may require it. Give them a try and see!
I also wanted to include MechWarrior 2, but I eventually ran out of time and decided to release the other games now rather than wait.
I've spent quite a lot of time fighting to get MechWarrior 2 running on Windows 7 and later. The problem is that it doesn't even reach ddraw.dll or sgl.dll, so I had to patch two of the game's files to get past that. Now that I think about it, I haven't actually tested this, but it might work without any issues on Windows 98, provided the machine is powerful enough.
Anyway, that's something to look into for version 0.5.0!
For that release, I'll also try to improve the code quality... you know, refactoring, SonarQube, and that sort of thing. So it will probably take a bit longer to release. Time to take a closer look at the code and clean things up, even if the results might not be as exciting or visible this time around.
That's it for now. Cheers, everyone!
Reply 76 of 79, by kon
ralonsoj wrote on 2026-10-19, 12:17:
Hi everyone! […]
Hi everyone!
thanks u r top of powervr wrraper 😀
Reply 77 of 79, by fla56
Hi team, (ex)PowerVR owner here
I too have been working on the PCX2 -this time a Vulkan compute-based Win11 launcher for VirtualOn, PureVex and UltimateRace, my 3 favourite games -think this might complement this wrapper nicely???
This includes supersampling / upscaling, up-filtering and texture packs with a full AI-based texture editor / generator as well as some attempts at gap-filling and other adjustments -if anyone is interested however it seems that VON is trapped by it's use of the Saturn's(!) math...
All comments and suggestions welcome -the package is a bit bigger than the wrapper but prob belongs on GitHub...again, any all suggestions welcome
Read more in the attached descriptor:
https://claude.ai/artifact/PwLqz93SPL4t3Arfkt … M#002d1e6b-9e39
Tech document:
https://claude.ai/artifact/VoxQPUMZ41HQ1ediTe … K#85aafb81-82be
Reply 78 of 79, by kon
fla56 wrote on Today, 12:34:
Hi team, (ex)PowerVR owner here […]
Tech document:
My old amd card (r7 250) only support vulkan v1.2 .170 anyway ,thanks for your share
Reply 79 of 79, by MadLynx
I'm very happy to be able to play those PowerVR exclusives with a help of wrappers, but has anyone considered making a port of the game render to Direct3D or something? I think, that today's AI are powerful enough for this task and it may be a far better option in a long run due to a very limited number of PowerVR exclusives.
