First post, by ubertrout
Upfront: AI was a major part of my workflow here.
I've long wanted a way to properly enjoy A3D audio on a modern PC but to my knowledge although there were attempts none were fully completed. A few years ago I was given an original Aureal Vortex SQ2500 (aka the Vortex 2), and after making a emulated PowerVR in 86Box and as a wrapper I wanted to try the Vortex 2 next.
It turns out that it hasn't been quite as easy, in part because it's a lot harder to pin down differences in audio. That said, after a few revisions this is version 0.3 of the 86box fork I've made and...this matches the real card rather well: https://github.com/z2k-retro/86Box/releases/tag/vortex-v0.3
My goal here is accuracy first - others can and should build on this in things which may be more useful for actually playing games, but I wanted to create a sort of synthetic baseline so people can test their projects against what it actually sounded like. There are numerous options for logging in the card configuration, including both a basic log option and a full trace dump option for advanced debugging. Comparing those trace dumps to running the real card traced in QEMU - and also comparing the recordings - has been the basis of much of the project.
As with the PowerVR project I've created a tools repository with information about the project and card. The goal is to allow others to build on this and make their own things: https://github.com/z2k-retro/aureal-vortex2-tools
All of that said, if you have a fairly recent PC install Windows 98 with a Voodoo3 for video and the Aureal Vortex 2 SQ2500 for sound, and try playing some Half-Life, or your other favorite game with A3D support. There were a lot of them: https://www.dosdays.co.uk/topics/3daudio_games.php
Reply 1 of 8, by tyrells
Amazing work! This is something that I've wanted to see for a long time, and it's very exciting to see the technical implementation covered in so much detail, as well as a working 86box implementation.
Reply 2 of 8, by ubertrout
tyrells wrote on 2026-11-12, 18:34:
Do enjoy! And if you notice any bugs that would be helpful.
Reply 3 of 8, by ZanQuance
Check your PMs, I have exactly what you need for this project.
Reply 4 of 8, by ubertrout
Version 0.4 released. ZanQuance played a massive role in making this happen: https://github.com/z2k-retro/86Box/releases/tag/vortex-v0.4
In short this won't sound that different but underneath it's gone from mimicing the Vortex 2 to actually working like it. Also lots of bug fixes.
Reply 5 of 8, by xtreger
Potentially silly question, but is it possible to approximate Aureal A3D in real hardware but with other sound cards like intel HDA or creative SB Live/Audigy? You've worked on this extensively so you may have an idea
Reply 6 of 8, by ubertrout
I don't think so, the Vortex 2 has 16 hardware channels for positional audio. It's possible to emulate but without that it would be hard.
Reply 7 of 8, by ZanQuance
ubertrout wrote on 2026-11-15, 19:23:
Only if massive means being the "guy in the chair" assisting the real Hero do their superhero work. Glad to be of any help I can 😀
xtreger wrote on Yesterday, 09:02:
Of course it is, however it entirely depends on how much those audio chips allow custom DSP code to be written for them and would ultimately require driver level modifications to make possible.
If software sits between the game and those audio drivers, then you've only implemented a wrapper not a hardware accelerated version of your target device.
So ultimately, not likely.
[edit] Ah I should add here that Sensaura has already done this and proved it's possible, but that wasn't so much emulation of the hardware as it was a wrapper/translation layer, but fits the "approximation" you specified, it was ultimately a software solution done at the driver level but could be uploaded as DSP code to supported chips like the Santa Cruz.
