A.I. Bubble about to burst in 3...2...1...
Reply 280 of 286, by darry
Ozzuneoj wrote on Today, 05:50:
X3D CPUs can make a huge difference in situations where processors with less cache choke. Simulators of all different types tend […]
X3D CPUs can make a huge difference in situations where processors with less cache choke. Simulators of all different types tend to really perform well on them.
If your monitor is limited to 60Hz or even 120Hz there will be fewer situations where you'll see the massive gains, but they are still there. A 5800X3D with a 240Hz monitor and a decent GPU is a great combo for someone who loves high frame rates. I have mine paired with an RTX 4070 Ti Super, and I was running it with a 3080 10GB before that and both provided an excellent experience, even in games that are known to really thrash the processor hard.
This video has some benchmarks for iRacing at the end and the performance difference of a 5800X3D over a 5800X is massive... often 50-70% faster, despite the X3D having lower power consumption and clock speeds.
https://www.youtube.com/watch?v=DseH5Ixp4f4
The difference can also be huge in MS Flight Simulator, and other CPU heavy games of different genres.
https://forums.flightsimulator.com/t/amd-5800 … ance/510937/413
My use cases are running multiple VM clusters (homelab hosts ) and photo processing, dabbling in local AI, some VMs and some older gaming (workstation PC), for the most part. More threads vs more cache seemed like the better choice for me (more debatable for the workstation).
On the workstation front, Cyberpunk 2077 is likely to be the most intense game that I will be running for the next few years (at 2.5k 60Hz, on a 16GB RX 9060 XT). I suspect that specific scenario would have benefited from a 5800X3D chip vs more threads on a 5900XT. Whether that would have perceptibly affected my gameplay experience, rather than just benchmarks, is another question.
Reply 281 of 286, by Ozzuneoj
darry wrote on Today, 06:12:
Yeah, for most of those things more threads will be better.
As far as gaming goes, if you're at 2560x1440 at 60Hz, you could probably have a Ryzen 5 3600 and rarely run into a CPU bottleneck, outside of some specific games known for being CPU heavy.
If you don't mind 60Hz, sticking with that is by far the best way to keep your PC from feeling like it needs an upgrade. 😀
Reply 282 of 286, by BitWrangler
23" screen at 3ft @ 1080p is my sweet spot. Going larger, higher res etc is pure self delusion as to benefit, you'll end up moving back from it so you don't have to move your head around. Then the res and size may as well be 23" @ 1080p @ 3ft. Anything you have a chance of reacting to has already been on screen for 4 frames at 120hz. Events shorter than that won't even get registered unless in lab conditions where it's the only event and of sufficient contrast. i.e. you might see a light blink for only a few nanoseconds with a significant pause before and after, but you won't see an illuminated light drop out for shorter periods than about 1/1oo of a second. You won't pick out blades on a fan at 500rpm and that's about only ~42 blades per second passing your eye/focus for a 5 blade. (Ignoring stroboscopic help from AC powered interior lighting)
Ergo I contend that gaming hardware pretty much maxed the limits of human perception a decade ago. The next phase of enshittification from hardware manufactures to strongarm game devs I expect "yoU caN't LicEncE ouR apI unLesS yoU foRce 1440P miNimUm rEs."
Though that could be why they went all in on AI, because of diminishing returns on gaming graphics advances. The gamerbro hype machine had too much momentum to realise when it hit "good enough" but had the last 5 years happened differently and we were at 8k on 64GB GPUs, a lot of people would be going "Wait a minute, this is not even any better."
Reply 283 of 286, by rmay635703
BitWrangler wrote on Today, 16:05:
I prefer a 23" screen because it fits the desk, mine is 1920x1200 which is barely adequate for teams presentations but...
If you had to use many of the non-configurable collaboration and presentation programs you would quickly learn that FHD sucks due to the ideotic layout and locked proportioning,
If anyone made a reasonable 23" 4k screen that wasn't 15 years old and didn't require a trade of your first born I would jump on it, not because I would always run 4k but because specific applications fill up most of your viewpoint with non scalable garbage at FHD, worse they handle undocking elements into another screen very poorly (if at all), in those cases 4k even if I have to turn on a bit of scaling is better.
And FHD looks great on perfect integer scale to 4k.
FHD has been obsolete at least 14 years, the cost difference to manufacture higher resolution vrs lower went away a decade ago, the cost to make a panel is almost entirely based on weight/raw material costs, at least until you get into the ultra high end, at this point it would be cheaper if every screen was 4k and use standardization to drop price.
Heck, the 1600x1440 screen found in such things as the analog pocket is said to cost under $10, and that little thing is far higher ppi than the smallest 4k screens.
The cost to add resolution is minimal as we are fully commoditized, it's too bad manufactures learned they could save a few dollars by removing all the various video inputs leaving only 1, getting them to put low latency legacy ports and commoditize that into the pennies range would be where I would rather seem them to go, too bad there are no niche makers that have the same sensibilities
Trashbytes wrote on Yesterday, 20:49:
rmay635703 wrote on Yesterday, 19:11:
Lots of that stuff and pc4200 floating around from the Chinesium sellers. If pc3600 is $50 and a more reasonable speed $500 I g […]
VanillaFairy wrote on Yesterday, 18:24:
from the admittedly very little I know, I've heard DDR5 has poor latency compared to DDR4 and DDR3 but usually makes up for it with faster read/write speeds?
So I think DDR5-3600 would probably run embarrassingly poorly.
Lots of that stuff and pc4200 floating around from the Chinesium sellers. If pc3600 is $50 and a more reasonable speed $500 I guess that is the question.
And yes I would assume slow ddr5 would be worse than fast ddr3/4
Dual ranking and banking for ram interlacing might make it "good enough" for low end modern machines.
I wasn't suggesting this stuff get used in your home PCs, but rather the other plethora of IOT devices that chew into the Dram supply by using the faster stuff when they would work just as well with the slower stuff. PCs by their very nature will always want the faster JADEC kits but stuff like TVs, Fridges, tablets, phones Etc don't always need it...even office PCs would work just fine with the slower modules.
We are long past going into the looking glass,
Considering 6gb memory modules, multi-tier onchip cache, efficiency units all as illogical as they are exist
Its certainly not beyond designing a motherboard specifically to using multiple speed grades of ram at their full speeds with a small amount of active area ddr5 ram like 4gb of extreme overclock stuff combined with 16gb + of cheap slow ram.
Making ram hierarchical so software priority gets it slotted into an appropriate speed of memory certainly isn't complex considering all the other more complex hardware decisions we just accept as normal.
Interlacing 2 sticks of pc3600 may not equal pc7200 but you may almost achieve pc4800 speeds on certain workflows
Reply 284 of 286, by BitWrangler
Productivity is a different matter when you want to lean in and use one area of the screen at a time. But at that point you only need reasonable 2D perf.
Reply 285 of 286, by rmay635703
BitWrangler wrote on Today, 17:39:
I would prefer one screen to do it all, that's why I'm disappointed all the legacy ports died, heck getting more than a single HDMI on a screen is a thing now, which is irrating for those of us with multiple devices plugged in.
I have a screen with both DP and HDMI, that makes upgrading and swapping systems less frustrating but a lot of makers are terrified of even that driving an adapter
Reply 286 of 286, by BitWrangler
I do see 4K hdmi switches around nowadays, dunno what those cost in lag, assume they've probably got something like a 2ns gate delay at logic level, but number of gates in the chain is hard to figure.
