DFendX - the legend is reborn (again)
Reply 140 of 153, by AlfreX
To make it easier to understand and identify the error, I'm attaching a short video showing you the sequence.
The attachment Videocaptura de pantalla_20261119_182830.zip is no longer available
I'm also attaching a new, recent log (generated right during the video demonstration).
The attachment DFendX-Log.txt is no longer available
As you’ll see, after the error, when you click the OK button, the icon view doesn’t load—the screen stays black—but the program doesn’t close. When you switch back to cover art view, it reloads them.
Reply 141 of 153, by AlfreX
I found a major regression in the latest Linux builds!
It turns out that when I try to add a new profile, in the “Drives” section, it won't let me mount any folder or disk image—whether as the C: drive or an optical drive—and when I click the “OK” button, nothing happens. The same thing happens if I click ‘Cancel’ or “Help.”
Unfortunately, I didn’t realize this until it was too late because I had already added all my games to the collection and was just testing other features and bugs, but today, when I tried to add a new one, I noticed the problem. Unfortunately, I deleted the previous Linux build where this worked and which I had used to organize my entire collection.
I hope there’s an easy fix because now I’m left without DefendX on Linux
Reply 142 of 153, by kolderman
AlfreX wrote on 2026-11-20, 01:50:
I found a major regression in the latest Linux builds! It turns out that when I try to add a new profile, in the “Drives” sectio […]
Hi, that sounds strange, I have not touched any code relating to saving new Drive mounts. I will investigate that and fix it along with the index(0) issue. In the meantime, here's a previous build I confirmed does not have that issue. It undoes a few of the other fixes though:
https://send.bitwarden.com/#AJRITyY1m0SPGLUIA … SBUyDaJg2UQiL7Q
Reply 143 of 153, by AlfreX
Thanks, this version fixes the error.
Reply 144 of 153, by kolderman
I have another build that I hope fixes some of these issues.
- the OK not saving on the Drive screen has been fixed. It was a side effect of the theme update change.
- I have put in a lot more guards around loading icons that hopefully will fix that index(0) issue. However I could not reproduce that, so I still need you to test that for me.
- changes from 2.6.9 windows builds have been included.
Cheers
https://send.bitwarden.com/#PHyXg6i7vUij8LUIA … CUt1o4AysVLwL7A
Reply 145 of 153, by AlfreX
Hey! Great job! Everything's working fine now!
The views are fixed!
And the part about adding drives, too.
And it's great that it's updated to the latest version of Windows!
Thank you so much!!
Reply 146 of 153, by kolderman
AlfreX wrote on 2026-11-21, 01:41:
Hey! Great job! Everything's working fine now! The views are fixed! And the part about adding drives, too. And it's great that i […]
Thank you so much!!
Great, thanks for confirming!
Reply 147 of 153, by kolderman
Thank you so much!!
Hi, have a new build you might want to try out. Main addition is it restores Cover Image downloading from TheGamesDB. The UI cleanup of the program settings forms has also been completed.
https://send.bitwarden.com/#PQ-8h7u_YUagebUQA … vFzN6jPwR0p83Fw
Reply 148 of 153, by AlfreX
Hi again! Congratulations—great update!
At a quick glance, all the menus look great now, and I was able to download the cover art from GamesDB too!
The only things I’ve noticed so far are these minor issues:
1) The Help / About DFendX section (and the three tabs within it) are incomplete; the links don’t work, and the information displayed there looks wrong.
2) When you edit a profile, in the “Program Information” section there’s a button that says “Look up game at My Abandonware”—that button/link doesn’t work; it doesn’t open anything.
I also wanted to recommend the IGDB website (https://www.igdb.com/) since its cover art fits perfectly with the size specified by DFendX and there are no black borders or distortions.
I’m glad to see you’re continuing to refine DFendX. Keep it up!
Reply 150 of 153, by AlfreX
Congratulations! Keep it up!
Reply 151 of 153, by AlfreX
Hi, I have a question: Is there an option in DFendX to change the viewport? Because I couldn't find it.
If there is one, could you tell me where it is? And if it doesn't exist, could you add that option? Thanks!
In case you're wondering why I'm looking for this option, it's because the DOSBox Staging guide recommends setting it to 89% to get a more accurate representation of how the games looked back then on modern monitors.
Reply 152 of 153, by kolderman
AlfreX wrote on Yesterday, 13:17:
Hi again! Congratulations—great update! At a quick glance, all the menus look great now, and I was able to download the cover ar […]
Thanks for testing again.
1) Still haven't got to that yet. Focus still on the profile editor/program settings forms.
2) Will have a look at that
3) I would like to add more sources, but complex logon flows make that difficult. However, did you know you can changes the size of cover/screenshot icons in Program Settings to align with whatever image source you are using?
Cheers
Reply 153 of 153, by kolderman
AlfreX wrote on Today, 13:55:
Not aware of any viewport options in the dosboxs so far, will look into it.
By the way, might be a couple of weeks before I look at the Linux port again, as I am working through a large amount of work relating to RUST-DOS integration in the Windows port.
