Lotus 1-2-3
First post, by Larawen
Good Morning, I am attempting to get Lotus 1-2-3 R 2.3 running on either dos box, or Windows 95 SE in a VM instance. What is strange is both attempts to get the software working yield the same result. Which usually means a user error (hurray for me!)
I can run the install file and setup the driver set, I set it the way it was configured on another PC.
Text Display: Universal Text Display
Graphics Display: (None)
The rest of the options do not seem relevant to the problem, but i will list them
Text Printer
Graphics Printer
Keyboard
Port Interface
File Translation
Collating Sequence
Math Coprocessor
Add-in Function
Dynamic Driver
When I launch the program it is black and white, and I cannot see the menus on top unless I mouse over them. Because this is in a VM instance, the hardware is generic and I cannot list very much. I allocated 128mb of ram for Windows 95
Reply 1 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
this looks like some windows based lotus ?
I've only ran 123r4 on DOSBox and that worked as far as I can remember.
Water flows down the stream
Reply 3 of 29, by Larawen
I have tried windows 95 dos mode, and in a all out attempt to go as native as possible, i spun up a dos 5.0 vm instance. Unfortunately it did the same thing. At this point I'm nearly convinced it probably has to do something with the hardware, virtual as it may be.
Reply 4 of 29, by wd
Rank DOSBox Author
DOSBox Author
What options are available? How do you run the app in dosbox?
Reply 5 of 29, by Larawen
Text display drivers:
CGA with B&W Monitor
CGA with Color Monitor
Compaq VGA 132X25
Compaq VGA 132X28, 43, 50, 60
EGA 80X25
EGA 80X43
GRiDCase Series
Hercules Card (80X25) Mono
Hercules Graphics Card+ (90x25)
Hercules Graphics Card+ (90x38)
IBM 3270, Mono
IBM Monochrome Display
Multi-Color Graphics (MCGA) Color
Multi-Color Graphics (MCGA) Mono
Toshiba 11000 Plus and 1200 LCD
Toshiba 3100, 3200, 5100 (80X25)
Toshiba 3100, 3200, 5100 (80X50)
Toshiba 5200 (80X25)
Univ. Text Display ASCII No LICS
VGA 80X25
VGA 80x43
VGA 80x50
VGA Plasma Display (80x25)
Graphics Display Driver:
AT&T 6300 Hi-Res monochrome
EGA Black background
EGA White background
GRiDCase Series
Hercules Card (90X38) Mono
IBM 3270-PC Hi-Res
IBM 3270-PC Med-Res
IBM 3270-PC/GX Hi-Res
IBM 3270-PC/GX Med-Res
IBM Color Monitor Med-Res
IBM/Compaq Hi-Res
Toshiba 5200
VGA Black background
VGA Plasma Display
VGA White background
I run the app in dosbox by simply mounting the 123r24 folder and running lotus.exe.
Reply 7 of 29, by KeithS
I am having the same problem. I have DOSBox 0.73, Lotus 123 R4. The correct screen colors come up briefly, but then switch this greyed out verion. I have Windows 7 Professional. I've tried many different settings: DOSBox cga, VGAonly, SVGA_s3 with no luck. Any ideas or tips for debugging? BTW: I'm helping an older gentleman in my community - he has these lotus spreadsheets that he's been using for 15+ years and wants to keep using them but his Windows 98ME machine is dying... I'm about to go out and buy him an old W95 machine, but thought I could get this to work!
Reply 8 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
ldgfxrom? boot dos in dosbox?
1+1=10
Reply 9 of 29, by wd
Rank DOSBox Author
DOSBox Author
Besides hal's recommendation i'd start off with 0.74.
Reply 10 of 29, by Davros
Do you absolutely need to use 123 ?
open office (its free) has a spreadsheet
Reply 11 of 29, by JensMammen
I have an old Family Tree program CTREE, more precisely Cumberland Tree - Version 3.1 from 1991, which runs well under DOS and also on my old Windows 98 computer. I have installed DOSBox 0.74 on my HP Pavilion dv6 with Windows 7, and it runs fine with my old basic-programs, MSword 5 and other oldies. However have problems running CTREE. The program file ctree.exe and the datafiles, fx. individ.dat, are all installed in the same directory c:\ctree. When starting the program the program halts and an error-box pops up telling: "CLARION Version 2.0 Batch 2000; c:\\individ.dat; ERROR CODE:45 INVALID FILENAME; DOS ERROR : 0". Apparently the problem is the two backslashes before "individ.dat" in stead of one. As the program functions well in a genuine DOS-environment the problem must be about the definition of directory in DOSBox. What can I do?
Reply 12 of 29, by wd
Rank DOSBox Author
DOSBox Author
Since you get the same thing in a VM as well, you simply installed it wrong
or forgot some integration step of that application. Check the app's docs.
Reply 13 of 29, by JensMammen
Thankyou, but what is "a VM"?
Reply 14 of 29, by wd
Rank DOSBox Author
DOSBox Author
Oh sorry, I didn't see you're not the original poster.
You may want to try a VM (virtual machine) like vmware, vpc, virtualbox
if you can't get it working in dosbox using the regular installation of both apps.
Reply 15 of 29, by Qbix
Rank DOSBox Author
DOSBox Author
I never tired c:\\something
as path. Not sure how dosbox will react.
Have you tried mounting c c:\ctree ?
Reply 16 of 29, by JensMammen
Following your first advice I actually found a bug (in relation to DOSBox, anyway) in the program's configuration file ctree.cfg, where "c:\\" should be changed to "c:\". But now the program halts with a new error-message box saying: "CLARION Version 2.0 Batch 2000; C:\CTREE.CFG; ERROR CODE:8 INSUFFICIENT MEMORY; DOS ERROR : 0". Can I make some change in DOSBox' configuration file dosbox-0.74.conf, which solves the problem ?
Reply 17 of 29, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
try loadfix
1+1=10
Reply 18 of 29, by JensMammen
I tried in the command line (before running ctree):
loadfix
loadfix -f
set dos ems=off
memsize=32
But nothing worked. Would it make a difference instead to include the commands in the DOSBox configuration file? When writing the command MEM I get a reply like:
633 Kb free conventional memory
63 Kb free upper memory in 1 blocks (UMB 63) ?
15168 Kb free extended memory
15168 Kb free expanded memory
Reply 19 of 29, by DosFreak
If you want to try turning off/on UMB,XMS or EMS then you need to type in :
umb false
ems false
xms false
at the DOSBox CLI
Also check the memory configuration of the working computers. Check config.sys for any odd emm386 values and also check the amount of used/free memory.
Make your games work offline
