Atlantis The Lost Tales on Vista?
Reply 20 of 59, by gidierre
detroit wrote:
There is no such subdirectory on the cd.
which explains the
D:\>cd \atl_dos
failure
then
what's in dosinst.bat
what happens in d: if you tipe : dir
where would install.bat be
what's the contents of install.bat
after mount d e:\ -t cdrom -noioctl
did you see a message stating something like cdrom drive mounted as drive d:
are sure your installation files are complete
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 21 of 59, by detroit
See attachment
Reply 22 of 59, by gidierre
good (not quite 😉 )
now what's in that dosinst.bat ?
atldos is an exe
there's no atl_dos subdir anyhow
of course
D:\>cd \atl_dos
won't work, I'd be surprised if it did
where did install.bat go ?
The good part :
mount seems fine
P.S.
read the readme
Reply 23 of 59, by detroit
dosinst.bat
cd \atl_dos
install.bat
there doesn't seem to be a install.bat file.
Reply 24 of 59, by gidierre
detroit wrote:
dosinst.bat […]
dosinst.bat
cd \atl_dos
install.bat
yep, that corresponds to your earlier report (about what happened as you kicked dosinst.bat off)
the problem is that dosinst apparently issues commands which can't fit the cdrom contents
only if you found install.bat somewhere on the cd and saw what it (install.bat) is supposed to do afterwards the haze could rise over the maze 😜
is it around ?
Another thought
what if you run atldos.exe ? Maybe (a huge maybe) it's got to be done first ?
Or do open that readme of yours that's there and search for some enlightenment within
Reply 25 of 59, by detroit
1.There is no install.bat on the cd.
2.Running altdos gets me to that black screen.
3.The readme file says nothing about dos.
Reply 26 of 59, by gidierre
you know what that means don't you
it takes 2 to tango
it takes an installer to install (well, not always with dos games that's true)
probably altdos.exe might have been good after some install procedure, I ought to know the game to tell,
surely your cdrom appears defective to me
what if it's a windows only version, some dos install things chopped off
just a sensation, I don't claim to be right all the time
Reply 27 of 59, by detroit
Yeah, I was afraid we were heading that way.
Thanks anyway.
Reply 28 of 59, by gidierre
hey detroit
you still hanging around
have you seen this
http://www.adventuregamers.com/forums/showthread.php?t=23773
there's this ATL_DOS.zip
containg 16 files including one install.bat which reads
@echo off
md c:\atlgame
copy *.* c:\atlgame
c:
cd \atlgame
setsound.exe
echo .
echo . La prossima volta che vuoi giocare, digita:
echo . C:
echo . CD \ATLGAME
echo . ATLDOS
echo .
pause
atldos.exe
the sentence "La prossima volta etc." is curiously in Italian 🤣
were the Atlanteans from Italy ? I never met one so far though
and means:
next time you want to play, type:
(my special translation is free for you 😜 )
and look, the
md c:\atlgame
copy *.* c:\atlgame
lines
and the smell of that setsound.exe of course
might really be what you need for the zip to work for you in dos
that's for the 1st time
next time(s) once it's installed, carefully read my lips and do exactly as I say :
La prossima volta che vuoi giocare, digita: 😜
etc.
what about that
(and then don't go around saying I didn't think about you 😉 )
Reply 29 of 59, by detroit
Hey, those files were just what I needed, I am able to play the game now. Thanks a lot gidierre and the others who replied for your time (and patience). I would not have been able to get this thing going by myself, glad I tried finding help here. I´ll surely have a lot of fun playing this game.
Thanks again and best wishes for 2009. 😎
Reply 30 of 59, by Veenin03
Hey there!
Maybe I should start a new subject on this one...
I did not because of the experts all seem to de hanging over here 😏
My english is not great so please forgive me; I will try to explain myself as well as I can!
The posts over here have put me to run the dutch version of Atlantis the lost tales (Atlantis de verloren legende) on my Windows vista laptop by using DOSbox 0.72.
Just like detroit you guys have helped me very much so far; so thanks for that 😀 !
Now I run into a problem. In the first screen I see a mouse-cursor, which I need to control to start and play the game.
Look at the attachment >
Now here's the thing; it will not be moved 😳!
I work with a touchpad and a keyboard on my laptop...
No one key neither the touchpad does anything to that darn thing.
As you wise men have been of such a help, I thought I should ask you 🙄
My question for Detroit > have you ran into the self problem?
My question to all of you > have you got any advise on solving this one?
I'm sooooo very happy I can finally normally SEE the game atlantis on my screen again... Now this 😢
Greatfull hugs in advance
A girl in serious need !
Kisses from the beast!
Reply 31 of 59, by gidierre
saluut to you 😀
I don't have the game,
but have you tried the run-of-the-mill mouse faq check
Q: The mouse doesn't work. A: Usually, DOSBox detects when a game uses mouse control. When you click on the screen it should […]
the screen it should get locked (confined to the DOSBox window) and work.
With certain games, the DOSBox mouse detection doesn't work. In that case
you will have to lock the mouse manually by pressing CTRL-F10.
Reply 32 of 59, by Veenin03
Hi!
It's a good suggestion...
Unfortunately it doesn't work.
That is; my normal mouse disappears but the one in the game will still not move...
Reply 33 of 59, by gidierre
have you tried connecting a usb "real" mouse (as opposed to your touchpad) ?
Reply 34 of 59, by wd
Rank DOSBox Author
DOSBox Author
If that screen occurs, can you type "exit" followed by a return, and dosbox
exits then? You'll have to do that blind (the exit text won't be displayed on
the screen) as it's still in a graphics mode.
Reply 35 of 59, by red_avatar
Just two cents: for me, I can move the mouse perfectly in the intro but no-one seems to ever be able to properly play the game because the movement when you look around in the game is so extremely slow that it's too painful to play. So even if you managed to use the mouse, I'm afraid the game is still not playable.
Reply 36 of 59, by gidierre
cycles=?
Reply 37 of 59, by red_avatar
Okay, the problem with the slow movement while looking around is caused by setting your cycles too high. If I set it at 40.000 cycles it's playable - 80.000 makes it much harder to look around.
Reply 38 of 59, by rcblanke
If I remember correctly, the (patches scrolls's) patch might also help. And try increasing mouse sensitivity to 300 or so.
Reply 39 of 59, by red_avatar
The problem is not a slow mouse but rather the game not moving at all if you move your mouse too quickly. Lowering the cycles is the only thing that helps it seems.
