whats the difference between...
Reply 20 of 57, by Duffman
hey Gubert?
does putting \basevideo before any other commands solve the distortion problem?
example?
\basevideo
nolfb.com
duke3d.exe
it worked for me.
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 21 of 57, by Schadenfreude
Well, according to the MS thing Grubert pointed to, /BASEVIDEO should only work if inserted in boot.ini on startup! Not when run during any old CMD window!
So, it may help, but I don't think it's doing what you think it's doing.
Still, what does Grubert think?
Reply 22 of 57, by HunterZ
That makes sense. It would be a horrible solution: you'd have to make the change and then restart Windows. It would come up in 640x480 with 16 colours until you took it out and rebooted. Yuck.
Reply 23 of 57, by MajorGrubert
I really don't know any command or utility called "basevideo" on Windows XP, but since I don't have a computer running XP right now I cannot double check.
Duffman, are you sure that nolfb isn't the one responsible for your success? By the way, are you running the .bat file with nolfb and duke3d through the launchpad? If you are using the launchpad, do you have the option to "Enable basic VESA support" enabled or not?
Thanks,
Major Grubert
Athlon 64 3200+/Asus K8V-X/1GB DDR400/GeForce FX 5700/SB Live! 5.1
Reply 24 of 57, by Duffman
Strangely, nolfb did not solve the problem by itself, for some reason my video card still had distortion problem. but when I use the \basevideo command, CMD says that it is not a valid command! something must be fixing it.
whats this launchpad you mentiond?
CPU: Ryzen 9 5950X
Reply 25 of 57, by MajorGrubert
I'll take a closer look at this as soon as I install a copy of Windows XP (too much work in the real world, too little time to spend inside the Garage).
It's the VDMSound Launchpad, a graphical interface for VDMS that allows you to create "VDMS shortcuts" for your programs. Each shortcut stores a different setup for an exe or bat file and you can run the program with a double click on the shortcut itself. You also get a graphical interface to change the configuration for each program, such as memory, sound and joystick parameters.
To get the Launchpad, take a look at this thread: showthread.php?s=&threadid=1226.
Regards,
Major Grubert
Reply 26 of 57, by Duffman
Gubert? are u a programer?
CPU: Ryzen 9 5950X
Reply 27 of 57, by MajorGrubert
I used to be, until the day someone called me a manager and I went shopping for a tie 😉
Ok, seriously, I have worked as a programmer for a few years, in Windows and Unix environments. Now, in my free time, I take a look at some open source projects to study them and see if I can learn something new and maybe fix a bug.
Regards,
Major Grubert
Reply 28 of 57, by Duffman
can visual basic or similar read a dynamic link library?
CPU: Ryzen 9 5950X
Reply 29 of 57, by Snover
I can answer this one for you: yes. DLLs are just program extensions, it all depends what their calls are and possibly what language they were originally written in.
Yes, it’s my fault.
Reply 30 of 57, by Duffman
what do u reckon the DLLs that windows depends to operate on were written in?
CPU: Ryzen 9 5950X
Reply 31 of 57, by Schadenfreude
Prolly' C++ and inline assembly, but I dunno for sure. There was some Europe or Asian country that made a deal with M$ recently, they'd install their products if they got to see the source. Go ask them! 😁
Reply 32 of 57, by guruman
If what you're asking is can VB call the functions in a DLL - yes, depending on how the DLL is written.
Visual Basic requires DLLs to handle their own stack clean-ups (also known as the 'stdcall' method'). A DLL written with the 'cdecl' method cannot be used with VB, as you will get a bad DLL calling convention error.
i.e.
__declspec (dllexport) void _stdcall function() -> works with VB
__declspec (dllexport) void function() -> won't work with VB
A fine example of this is the WNASPI32.DLL ASPI layer DLL; in order to use it with VB, a 'wrapper' DLL that calls the functions in WNASPI32 with the stdcall convention is required as a go-between.
Reply 33 of 57, by MajorGrubert
I did not know all the technical details about this when I wrote some VB code, but I do remember writing a C wrapper object in order to call a specific DLL in VB.
By the way, Duffman, what kind of DLL are you trying to call from a VB program?
Regards,
Major Grubert
Reply 34 of 57, by Duffman
would it be possible to write a vga DLL alternative driver to act as a secondary display driver for DOS THAT just emulates VESA DIRECTLY from the graphics card ignoring XP
CPU: Ryzen 9 5950X
Reply 35 of 57, by Schadenfreude
AFAIK, no driver can "ignore" XP. To program a device driver, you must use the Windows XP Device Driver Development Kit.
Still, I like the idea of the solution being a "secondary" display driver. neato!
But you can't write this thing with Visual Basic, so I fail to see where that fits.
Reply 36 of 57, by Duffman
What about any of the microsoft visual languages? or wont they work either?
CPU: Ryzen 9 5950X
Reply 37 of 57, by Schadenfreude
You program a device driver using Microsoft Visual C++ and the Windows DDK.
It doesn't seem that you know how to do this... at least to me... or you would know this already.
To amend what I have said:
You CAN write a program that goes through Windows XP's protection against giving programs direct access to hardware. GIVEIO.SYS and other drivers do this for memory and I/O. And AdvanceMAME/AdvanceCAB has done this for video (and VESA1, but not VESA2 yet...). But it can potentially make the computer unstable, which is why Windows XP does not permit it in the first place.
... which is why a different sort of driver and method is necessary, we think.
Reply 38 of 57, by Duffman
I only started on programming 2 months ago, guess VESA is too advanced for me yet
CPU: Ryzen 9 5950X
Reply 39 of 57, by Harekiet
Rank DOSBox Author
DOSBox Author
Much better would be to emulate vesa using directdraw, combine a kernel driver with a vdd and a small tsr .
