First post, by Susi81
Hello, from Germany.
I have a big problem. I want to play the game "Dunkle Schatten", but it dont work. I habe downloaded this:
http://www.arno-fleck.de/werbespiele/download/ds_1.zip
I have done it with dfend and without dfend (mounted it as c).
Kann someone help me?
Reply 1 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
works in the next version of dosbox.
Water flows down the stream
Reply 2 of 11, by Susi81
Ok. Thx.
When is the release of the next version?
Reply 4 of 11, by Susi81
Yes, thank you. It works. But the mouse ist very slow and the sound hangs.
Edit: The Startscreen work good, but the game is unplayable.
Reply 5 of 11, by IIGS_User
How do you detect this?
Graphics too slow, game too fast, or any different?
Klimawandel.
Reply 6 of 11, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
set cycles=10000 in dosbox.conf.
1+1=10
Reply 7 of 11, by Susi81
... dont works.
Here is my error report:
1. The first (advertisments, menü) 3 Screens works with sound etc.
2. Then the boy tells a story - works
3. The Boy disapperes and then the start menü comes. - works.
4. I select "New Game". And here ist the Problem. The Sound hangs and the mouse too. Unplayable.
I have the Sound emulation switched off. The problem ist the same!
Greetings from Germany
EDIT: The Sound ist the Problem! It works, when I switch it of in the game Menü. What can I do?
PS: Sorry for my bad english!
Reply 8 of 11, by wd
Rank DOSBox Author
DOSBox Author
Side remark: this game might not be stable even in the next dosbox version.
... dont works.
Please be elaborate, "doesn't work" does not help much in determining what's wrong.
Reply 9 of 11, by Susi81
... dont works.
Nothing change, if i use CPY cycles 10000. Mouse an Sound are still unplayable.
Reply 10 of 11, by wd
Rank DOSBox Author
DOSBox Author
From hal9000:
You can run PSMCFG4 in the SCHATTEN directory and choose [7] Adlib
Reply 11 of 11, by Susi81
Yes. Everthing works! Thx
