Problem mounting CUE image
Reply 20 of 22, by wd
Rank DOSBox Author
DOSBox Author
TOC Information: Session 1... (LBA: 0 - 257168) -> Track 01 (Mode 1, LBA: 0 - 257167) -> LeadOut (LBA: 257168) […]
TOC Information:
Track Information:
Session 1...
-> Track 01 (LTSA: 0, TS: 257168)
But the cue sheets are identical except for the mode1/mode2 thing, right?
Are you able to create some mode2-cuesheet with mixed mode cds or
regular data cds? As that's what i failed at, always came out as mode1.
Reply 21 of 22, by MiniMax
Rank Moderator
Moderator
Problem is, can't figure out how to create a cue-sheet directly from the CD using ImgBurn, only from an already created image. And that seems kinda pointless doesn't it? If the info is already in the image-file, why create a cue-sheet?
wd wrote:
Are you able to create some mode2-cuesheet with mixed mode cds or regular data cds? As that's what i failed at, always came out as mode1.
I wouldn't know how to identify such CD's. The only time I managed to have ImgBurn create a cue-file directly from the CD was with an normal audio CD.
Reply 22 of 22, by wd
Rank DOSBox Author
DOSBox Author
I'm talking about that IsoBuster only, as that one seems to be the app that generates those mode2 sheets.
