First post, by Ere
I know the title's a little misleading, but I'm running DOSBox on a mac.
I've got a mounted disk image, not an actual disk, since I accidentally backed up the files on the disk when I switched computers. I'm glad I did.
Anyway, I've been trying to run Daggerfall through DOSBox on my OSX 10.4, but I can't even get anything started. I haven't even gotten it close enough to working to get a black screen or a crash.
If anyone can give me any assistance, it shall be much appreciated.
Here are my specs:
OSX 10.4.11
1.07 GHz PowerPC G4
512 MB DD SDRAM
There you go.
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
read some guide on how to operate dosbox ?
Water flows down the stream
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
Since you are using disc-images, use the imgmount-command instead of the ordinary mount-command when mounting the CD-ROM.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 3 of 5, by Ere
Agh, I just found out my problem lies within the ISO I made. It says it's a CSS encrypted file, and that means it appears as an audio disc, which is worthless to me. If I ever get another copy of the game, this thread'll come in handy, I guess.
Reply 4 of 5, by ADDiCT
You're not saying you destroyed the original data on a CD-ROM by overwriting it with other data, are you?
Are you talking about this CSS? If you are, then your post is even more mysterious than it looks at first glance. Either there's something really strange going on in your machine (like Gremlins forcing a copy protection/DRM scheme that works for Video DVD only unto your poor CD's or CD images), or you have a broken image. Just recreate the ISO image from your original CD, which i hope you do have.
Reply 5 of 5, by Ere
Nope, I don't have the disc anymore.
And yeah, I'm as confused as you are about the CSS thing. Maybe I botched the whole ripping process or something.
