First post, by arkhanari
I'm recording video with DosBox and it works perfectly - except for one thing. The videos contain all Sound FX but not the midi music from the game. Is this a known problem and if so - how do I solve it?
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
it is a known problem. select a different sound source than midi.
Water flows down the stream
Reply 2 of 4, by arkhanari
So if the game has nothing but midi music I'm screwed?
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well you could capture the midi music using a different program and merge the video and audio together with some editor.
But as far as dosbox you are screwed.
Reply 4 of 4, by ripa
You could also capture the MIDI data (CTRL-ALT-F8) and afterwards "render" the recorded MIDI file into an audio file (with for example midi2wav) and add it to the recorded video.
