First post, by oldschool45
- Newbie
i get the same error every time - "Assertion failed : count++ < 8, file ai_expir.cpp line 319 abnormal termination" i have no idea what the heck that stuff means but would like to fix it
Yeah strange. What did you do?
I installed the game and mounted it in DOSbox then played it it will work fine for a random amount of time then crash then i have to use task manager to close dosbox
how?
i tried to install it using dosbox but it would only see 110mb so i went to my computer and explored the cd and ran the setup from there and then it saw enough space to install after i installed it i used dosbox to run it after trying the compatibility options tab on M.A.X. it runs fine for a little bit then crashes
sorry wrong.
start over. delete what you got.
but when mounting your C drive add a -freesize 800
and install then
Water flows down the stream
how do i add a "-freesize 800" is that something i type in or something i change in the dosbox config
it's something you add to the mount line
example:
mount c c:\dosgames -freesize 800mount d d:\ -t cdrom
that worked for a while then i came up with the same error message except in red this time instead of orange also this appeared
[/img]http://i279.photobucket.com/albums/kk152/dude915/error-1.jpg
