It's an FIC PVT, the same one mentioned on the Red Hill guide.
It uses an Intel 486DX2. Heatsink with fan.
It has 32MB Ram, In four simms of 8.
It has a BusLogic BTC-44xC SCSI controller, located at IRQ 14, DMA 6. BIOS is at DC000H, card is at 130h, and is a VL bus controller.
Hard disk is a 1GB Quantum, CD ROM is from an apple machine.
The I/O is on a seperate card, and only one Serial port is active, at IRQ 4. I am admittingly not sure what the parallel section is using, though I beleive it is IRQ 7.
The Video card is an ATI 2MB EDO on the VL Bus. It uses IRQ 3
I do not know what IRQ the LAN is trying to use.
The CTCM program is the first thing run after the HDD driver is loaded.
There is no PS2 controller. There is no plug and play in the BIOS. This BIOS is not the last one for the board, but I do not have an avaiable 128k chip to burn the last one with.
I have tried pulling both the I/O card and the LAN card, and it will still set at 9 and 0.
The sound does work in Windows, as does the LAN. But I can't get sound to function in Jazz, becasue IRQ nine is not selectable.
I'm looking for a way to see what hardware resources are used in Windows.
EDIT:
Ok, noticed something else in that cfg file.
There is a place where I can list IRQs, BASEs, and DMAs to exclude. I put 9 and 0, respectively, on the exclude list, and wrote 5,1,5 where I needed, and it seems to have rebooted with the proper settings. I'll keep you posted. :p
