First post, by DarkVamp
I just installed my old SYSTEM SHOCK 1 CDROM Version.
The game runs great even in FullScreen 640x480 but I got no INGAME sfx 🙁 The intro runs perfect with speech but ingame I only got music ...
Are there any hints ?
Greets -DarkVamp-
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
What type of sound device did you choose when you configured the game?
_________________
Reply 2 of 11, by DarkVamp
The only one that worked was SB PRO...
SB16 doesnt seem to work 🙁
Greets -DarkVamp-
Reply 3 of 11, by MiniMax
Rank Moderator
Moderator
For the Sound Blaster - which settings did you choose for IO, IRQ, DMA(s)? Do they match the settings used by DOSBox? The DOSBox defaults are:
sbbase=220
irq=7
dma=1
hdma=5
_________________
Reply 4 of 11, by DarkVamp
Thats really not the problem because the intro of the game has fine speech...
I use A220 I5 D1 and that are my settings in dosbox.conf
Greets -DarkVamp-
Reply 5 of 11, by wd
Rank DOSBox Author
DOSBox Author
Then please revert to the default dosbox.conf values and configure the game accordingly.
Reply 6 of 11, by DarkVamp
I´ll give it a try
Greets -DarkVamp-
Reply 7 of 11, by DarkVamp
Works fine now with IRQ 7 🙁)
Greets -DarkVamp-
Reply 8 of 11, by wd
Rank DOSBox Author
DOSBox Author
🙁 means there's still a problem?
Reply 9 of 11, by DarkVamp
No everything is fine now ! Thx ! 😉
"System Shock" runs really smooth in fullscreen 640x480 !
Greets -DarkVamp-
Reply 10 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
good.
then the only questions that remain are: why didn't it work with irq 5 and more importantly why did you think that changing the dosbox irq from 7 to 5 was a good idea
Water flows down the stream
Reply 11 of 11, by ripa
CD System Shock works fine with SB16 and IRQ5 if you set both dosbox.conf and System Shock's installer properly.
