First post, by wildweasel
I'm loading up Alien Trilogy for MS-DOS on my recently-acquired "Silver Machine", but the installer has stopped me from actually installing the game. I insert the disc, change to the E drive where my CD-ROM resides, then type Install, and get this:
** ERROR **
Alien Trilogy requires 8 megabytes of RAM or more.
Press any key to finish.
Installation aborted!!!
Alien Trilogy may *not* be installed correctly.
Please run INSTALL again.
This is preposterous, as this machine has 64 MB of RAM inserted (one 64 MB stick). Is there a command line switch somewhere that I can force the game to install regardless of RAM?
Reply 2 of 9, by Davros
iirc it needed about 450k of conventional memory (type mem and look at largest executable program size)
and about 7000k of xms
Reply 3 of 9, by wildweasel
I have replaced EMM386 and HIMEM with JemmEx as provided from Dosfreak's link, and added the Max= line to its entry in config.sys:
DEVICE=C:\UTILS\JEMM\JEMMEX.EXE FASTBOOT I=B000-B7FF MAX=8192
Assuming, of course, that the MAX= parameter takes its argument in KB, I assigned it exactly 8 MB of expanded memory. Mem /C confirmed this. Yet the installer still complains that it needs 8 MB of RAM. Increasing Max to 16384 also didn't help, and assuming that the MAX= parameter takes its args in MB didn't work either (Mem /C reported 32 KB when I told it MAX=32).
This is a little bit confusing.
Reply 4 of 9, by MiniMax
Rank Moderator
Moderator
But what kind of RAM? XMS or EMS?
Will it install in DOSBox? If so, you could do the install there, and move the resulting installation over.
_________________
Reply 5 of 9, by wildweasel
Not going to be easy; the Silver Machine is in no way connected to the network and in fact seems to have difficulty reading some burned discs, strangely enough. I'd have to floppy it over.
Reply 6 of 9, by Davros
looks like you are providing ems memory not xms
try
DEVICE=C:\Windows\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE NOEMS
and also try (sorry i havnt done this for years i forget exactly)
DOS=HIGH,UMB
thirdly try
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE 2048
type mem /c to see what type of memory you have
im sure one of the above 3 will work
Reply 7 of 9, by Davros
wildweasel wrote:
I have replaced EMM386 and HIMEM with JemmEx as provided from Dosfreak's link, .
dosfreak told you to download himemx not jemmex thats why its confusing
Reply 8 of 9, by Moogle!
Try running Memmaker to free up conventional memory, and try the game again.
Reply 9 of 9, by tikbalang
get rid of setver.
get rid of "/L:?,????" options in LOADHIGH and DEVICEHIGH statements.
LH and devicehigh are ineffective without available UMB/HMA.
try these setting:
msdos 7.10:
DEVICEHIGH=\DOS\HIMEM.SYS /NUMHANDLES=128 /TESTMEM:OFF /Q
DEVICEHIGH=\DOS\EMM386.EXE AUTO RAM NOEMS A=32 D=64 H=128
remove "NOEMS" if you need EMS.
japheth.de:
DEVICEHIGH=\DOS\JEMMEX.EXE RAM NOEMS SB D=64 XMSHANDLES=128
no need for himem.sys and emm386.exe, jemmex does both jobs.
ESS PCI DOS Drivers
_________________
