First post, by Yellig
Motherboard: HP Pavillion dv9500 Notebook PC, x-64 based, BIOS F.31, System ID 30D1, Version 85.26
Processor: AMD Turion 64 X2 Mobile Technology TL-64, Dual-Core @ 2.2 GHz
RAM: 2 GB (2 x 1 GB DIMMs)
Video: NVidia GeForce 7150M / nForce 630M, 64 MB VRAM (also shares System Memory)
Sound: Conexant High Definition SmartAudio HD2
OS: Vista Ultimate SP1 (64-bit)
Game: Star Trek: Pinball (1.00)
Problem: Game crashes with DOS/4GW General Protection Fault (see attached image)
Reproducibilty: Almost always; usually occurs after opening movie, occasionally before opening movie; have only gotten to gameplay once
Sound mode used: SB16
Video mode: Surface; Screen is 1440x900, game is 800x600, DOSBox set to aspect=true
Emulator: DOSBox 0.72
Steps taken: raised and lowered memory inside DOSBox; used different drive letters for mounting CD-ROM; set DOSBox to report DOS version as 6.22 (version required by game); yes, read the README file 😀
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Try different kinds of memory (XMS=true/false, EMS=true/false), different cores (normal, dynamic), loadfix, and finally DOS32A instead of DOS4GW.
_________________
Reply 2 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Also, try fixed cycles.
1+1=10
Reply 3 of 3, by Yellig
Thank you for the help. Fixed cycles ended up being the key.
